Question about Mackie ProFX12 Professional Compact Mixer
Some channels stop working
8 channel
Hello, I am new to forums, this is my first time. I have a Peavey 696f power mixer, last night the left speaker channel stopped working, what do you think is causing this problem?
the pa1 or the pa2 input jack on the front of the unit is dirty, or you have a cracked solder somewhere, as these units are gettting old.
Jun 18, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Recording problem
1. Press and hold down the ASSIGN A button (the light should be blinking) then (simultaneously) press the REC button above channel number 1. The light should blink when you do this.
2. Release the ASSIGN A and the REC button
3. Press the REC button above channel 1 (the light should be blinking by itself)
4. You should see the meters moving with in the display above Input A and Track 1 when you speak into the microphone.
5. Press the REWIND button twice until the display reads ABS 00.00.00.00
6. Press and hold the RECORD button and press the PLAY button. The REC light above channel one, the PLAY light and the RECORD light should become solid.
7. After recording press the STOP button.
8. Press the REWIND button twice until the display reads ABS 00.00.00.00
9. Press the PLAY button.
Apr 16, 2014 | Tascam DP 008 Digital Portastudio
My behringer pmp3000 doesn't seem to have much power to use my two peavey 12" speakers and use a mic. I have to push the gain and faders up more than I think I should have to, to get a decent level of...
Where do you have the gain control set on the Mic channel ?
If you have no issues with either the speakers or the Mic, and the gain control for the channel you have the Mic plugged into is set at a somewhat "normal" position, you might have a problem with the mixer itself.
Oct 28, 2013 | Behringer Pmp3000 16 Channel Audio Mixer
Clip light on
Does all the "Clip" lights are on? or just certain channel? if all "Clip" lights are on you have to check the +15V and -15V at Operational amplifier ic that is a 8-pin integrated circuit, pin 4 should have the -15V and Pin 8 should have the +15V, if just one channel shows the light constant on then its an opamp in that particular channel, let me know further to improve help.
Oct 24, 2013 | Peavey PV8 Mixer
Behringer pmp4000 keeps dropping an ouput channel while playing live!
The PMP has an electronic overload protection. If you overload one or the other of the outputs, it trips the protector and you have to cycle the power off for a bit to reset it. You haven't mentioned what speakers you have. Be aware that the impedance can be no lower than 4 ohms on either channel. In addition, I have seen some particular speakers that have transformer attentuators in them that this amp is NOT happy driving. You could not attach more than two 8 ohm speakers to each of the outputs without tripping the protector.
Feb 21, 2012 | Behringer Europower Pmp5000 Powered Mixer...
How can i setup mu xenyx 802 with my pc? i also hve fca202...
You can do it one of two ways when coupled with the FCA202. First, You can just come out of the main outs on the 802 via 1/4 in to the 202s 1/L in and 2/R in. Second, you could do two separate channels (ie. Vocal channel and Guitar Channel) using the L/R out on the 802. Use the pan knob to send the instrument to the selected channel. So, If your Guitar is on channel 1 pan hard left and you will only get it out of the left channel sending to channel 1 of the 202, and your vocal is in channel 2 pan hard right and you will only get it out of the left channel sending to channel 2 on the 202. Good Luck, Cody J.
Dec 17, 2010 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
Our 32fx mixer has intermittant channel faiures. The symptoms are the channel faders and tones controls stop working but the audio continues to be routed to the lr outputs. The channel level can the...
If your setup depends on the USB to the computer, I suspect the problem is in the computer, possibly a throughput probllem if you have antio-virus programs running. They take a lot of throughput and often come in at random times.
If you happen to be using a PC with this, check the usage of computer resources from the process listing.
May 15, 2010 | Peavey 32fx USB 32 Channel Mixer
Our 32fx mixer has intermittant channel faiures. The symptoms are the channel faders and tones controls stop working, but the audio continues to be routed to the LR outputs. The channel level can the...
Try performing a full firmware re-install, or update if your not already on the current firmware. Click on the "Downloads" tab to access the latest firmware. http://www.peavey.com/products/browse.cfm/action/detail/item/116194/32FX™.cfm
Mar 29, 2010 | Peavey 32fx USB 32 Channel Mixer
Mackie ProFX12 Professional Compact Mixer Logo
18 people viewed this question
Top Mackie Music Experts
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
