Question about Samsung RSG257AARS (241 cu ft) Side by Side Refrigerator
How to replace the ice chute door
I don't know how to access the area to replace the ice chute door.
  • 5 Answers
I'm no expert but because of the problems I've had with this product, I'm getting better. It depends on the model Samsung that you have. I don't know if yours is the same model as mine so it may be a different set up. Mine is a RFG297AARSXAA. Look at your owner's manual for the model number and then go to http://www.searspartsdirect.com. Then enter your model #. Click on the parts tab & look at the schematic for your ice chute. It sounds like you need to replace the Route case (E.g., for my refer, it is PART NUMBER: DA97-07361C [Substitution: DA97-07361T] for my model of refer. It cost about $68.00.
Unplug your refer and shut off the water feed for safety reasons.
You need to remove the old ice chute. You do this by pulling forward (by hand only) on the front display panel from its underside. You will notice a small rectangular hole on the right underside that is large enough for the tip of a wide flat blade screw driver. You can insert it here to assist in pulling the panel forward. Don't insert it too far, only enough to give you some purchase on the panel. Start pulling on this right side and work your way over to the left side being careful not to break the tabs that hold the panel in place. There are two tabs on the right and two tabs on the left and one at the middle top. Once you work out the two tabs on the right, the other tabs will release more easily. Once the panel is removed, it is just "plug & play." Unscrew (2 or 3 screws) the old Route Case and install the new one. Just match up the wire connectors & plastic tabs the same way they were on the old route case. When the new chute is mounted, insert the LCD panel on to the left tabs first making sure that the wires are tucked into place properly and not "pinched" then work your way over to the right side and pressing the panel on the edges (press around the edges only, don't press the LCD screen) to make sure the panel is seated securely on to the tabs on both sides and the top. Turn on the water and plug it in and you should be good.
Posted on Nov 29, 2014
Underside of ice bin freezes up built up with frosty ice, dispenses no ice. numerous times we have defrosted with blow dryer, removed, cleaned bin, replaced; cleaned out ice that was built up in lower part...
W10224328 Dispenser Door Spring
The chute door is the reason your ice bin is freezing up and also the chute door being open draws warm moist air inside your freezer compartment causing massive amounts of frost and keeps the compressor runing all the time between defrost. You really n eed to get the chute door fixed. What is the correct model number? For the model KSRX25FT dispenser parts click HERE The chute door spring may be broken but you will not know untill you open the dispenser housing. I'm here should you post the correct model number or have questions, Sea Breeze
Oct 17, 2013 | KitchenAid Architect ® Series II KSRX25FT
Heavy frosting around ice maker area
Mike, check your ice door chute in the freezer door to make sure it is closing all the way. Ice/frost buildup is usually a sign of warm air getting into the unit from somewhere. If you identify that as your culprit, let me know and I can try to help you with installing replacement parts if you'd like.
Jun 14, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
WATER DRIPPING IN DISPENSER TRAY DUE TO ICE MELTING AT FRONT OF DISPENSER
Hi Don,
Typically this occurs when the dispenser door does not close all the way.
The dispenser door is located in the freezer door in the chute that the ice dispenses down.
With the freezer door open shine a light up from the outside and look down into the door from the inside. If you see light around the door flapper, you will need to replace the dispenser door, if there is a large gap between the dispenser door and the chute you will need to replace the mechanism that controls the door.
Apr 18, 2010 | Electrolux Refrigerators
GE Monogram -- Ice freezes IN THE CHUTE and blocks the chute
My ice cube chute kept freezing, and I realized the Access Door was stuck open. I was able to replace it without taking the door apart.
Sep 26, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
How do I replac the clear plastic cover over the ice shute on the
order the chute assy old pull out and down holding the lever as to not break it other snaps in reverse order
Aug 19, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Water leaking from behind ice chute door & freezes under ice bin
You will have to remove the unit and access the rear of freezer. Check that the filters are not plugged as well as drain.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile 26.6 cu. ft. side by side is frosting in the shoot
Oddly enough, the problem is with your ice dispenser. What happens is that the door at the bottom of the ice chute is probably not sealed. This is likely because there is a solenoid that is supposed to hold that door open when you push your cup against the dispenser arm, and THEN, close it again when you release. If the chute door is not sealed, warmer, moist air from outside the refridgerator will be canstantly drawn up the chute where the moisture will freeze as frost. Gradually, this frost builds up in the chute until there is no longer enough room foir the ice to fall. You can usually look up at the chute from outside and see that the door is not sealed. In my case, I left it unsealed because the door would not open to let the ice out. It took me about 3 months to figure out that this was causing my frost-clogging problem. The solution is to replace the solenoid that is supposed to open and close the chuite door. If you remove the despenser panel, you will see that this solenoid is probably all rusted up and not working. The following link will allow you to enter you model number and see a diagram of the offending area. http://www.pcappliancerepair.com/model-display.php
Jun 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice chute door does not open
the solenoid is right beside the ice chute door. there is an arm coming off he door to the side and the solenoid has a stirrup hooked to the arm. you have to remove the trim surrounding the dispenser area to access this stuff. you don't repair the solenoid you replace it. ca. 20 bucks for the part
Apr 25, 2008 | Maytag MFD2560HES Bottom Freezer French...
Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Samsung RSG257AARS (241 cu ft) Side by Side Refrigerator Logo
150 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
