Question about Smeg A3-5 Gas Kitchen Range
Smeg a3-5 opera main door does not sit right on it's hinges. How do I adjust
How do I remove - replace door on tese hinges?
2 Suggested Answers
SOURCE: fitting ne hinges on a smeg 90 oven door
very easy unscrew screws on doors the one on inner glass attaches to hinges be careful when lifting off as door handle will come off took me 15 mins and i took it easy
Posted on Feb 27, 2010
Unable to remove oven door (to fix misalignment). Old Smeg oven
burnt grease make things sttick really well . try some wd40 on it for a day or so then open part way and pull up on the door .
Nov 09, 2016 | Ovens
Driver side door does not close. Latch broken and door sits down below catch on body of car.
may need new hinges on door and body of vehicle, if so it is about 600 -700 to replace , may be able to get new bushing and pins , without replacing hinges
Sep 09, 2010 | 1998 GMC Jimmy
Oven door will not remain fully closed
Noiselab is not correct for all cases. As Buzz says, if the springs are strong then the foil fix works and works really well. Refer to attached photo for guidance in conjunction with instructions below. Note my possibly simpler answer at bottom.
I cut some short narrow strips (about 4mm x 20 mm) from a tin can and folded them over into a flattened "U". You can back off the large Phillips head screw on the frame of the oven where the door hinges are inserted and sit the tin over the little plate that is held by these screws and then tighten so that one end of the "U" sits between the oven chassis and the adjustment plate. If it still doesn't quite close add more tin as required. Refer photo for terminology.
Now the simpler solution which I didn't try but which would probably work after I contemplated the problem in retrospect is this. The reason I didn't think of this was that I thought the hinge went into a tube or slot. Later I realised it is just a simple cantilever design which is why the tin foil solution works (ie lifting the middle support of the cantilever produces a corresponding closure of the door). When I inspected the large Phillips head screws to insert the tin foil these were completely loose. Try this first then. Slide the adjustment plate up as high as the tolerance of the Phillips screw allows and then tighten it off hard. This will raise the bottom edge of the plate just as the tin foil method does. If not enough then proceed to the tin foil method.
Jul 09, 2010 | AGA ILVE M-90F-MP Dual Fuel Range
How do I remove Smeg FAB 28 Fridge door,as I have bought a new replacement but it has not instructions
remove the top of the fridge by removing the two screws on the back of the top and sliding the top to the back. that gives you access to the doorhinges. remove the three screews of the lower hinge, which allows you to remove the door from the upper hinge too. (sorry, non native speaker)
Oct 05, 2009 | Smeg FAB28
I have a Smeg A1-1 Cooker. The main oven door does not shut properley - it hangs open a bit and so lets out lots of heat?
you have to replace the door hinge's an easy fix but you have to strip the doors apart so a good time to clean.
Jul 13, 2009 | Smeg A1A.1 Gas Kitchen Range
Replaced hinge on smeg double oven but now oven doesn't heat
I have the SMEG F170-5 and had this problem after cleaning and replacing the door. It wouldn't heat unless I banged it shut. This action made the internal switch trigger, so I had to remove the oven (4 screws, slide out) and remove the right side panel (4 screws). The switch is actuated by the right hinge strut and it must have become bent slightly. I bent it a bit towards the door so that it would just a little bit more likely to make the switch trigger with the door closed and it now works fine.
Jun 12, 2009 | Smeg S351X/5 Electric Single Oven
Fitting ne hinges on a smeg 90 oven door
Mar 25, 2009 | Smeg SUK91MFX5 Dual Fuel (Electric and...
Top hinge has just broken off my smeg fridge.
found an old smeg at the local junk yard and took of the hinges and other parts... cheapest way.
Mar 16, 2009 | Smeg FAB28NE6 Refrigerator With Ice Box
Doors on my truck
You probably need new door hinges. Open the door, lift up on the door while watching the hinges, you should not see any movement at the hinge location. If there is play there, replace the hinges. To remove door hinges, place a floor jack under the door for support while u remove hinges. There should be some adjustment at the hinges, and door latch to fine tune the fit and how it closes. Good luck, let me know how u make out.
Nov 11, 2008 | 1999 GMC Sonoma
Smeg Fab 32 door problem
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
Jun 08, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Smeg A3-5 Gas Kitchen Range Logo
Top Smeg Kitchen Ranges Experts
Joseph Mueller
Joseph Mueller
Your Consultant
Andrew Taylor
Andrew Taylor
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
