Question about Metra Ford F 150 Truck 1999
Electrical my truck wont start when I turn the key it just clicks.sometimes it doesn't even click,
    Sergeant:
  • 182 Answers
Bad battery, bad cell, not enough voltage or amps to power the starter, have the alternator checked also. Usually alternator goes then the battery dies.
Posted on Nov 16, 2014
Replaced starter new battery fuel and air filters blown fuses wont start only click click
'Click Click' means not enough electricity is making it to the starter. This could be bad or dirty connections, a bad starter relay, a weak battery (even if new), bad electrical leads, a misaligned starter (jammed bendix or bad flywheel)...
Sometime DIY means do it again....and again...and again, until you get it right(ish)
Apr 02, 2015 | Cars & Trucks
Mitsubishi repair
Almost sounds like a problem with the electrical portion of the ignition switch.
Jan 15, 2014 | Cars & Trucks
2000 dodge ram 1500 electrical issue
When you turn key on does it click repeatedly? When an alternator is going bad the electrical goes all kinds of crazy sometimes, you may want to start there if you havent chkd that yet.
Oct 31, 2012 | Cars & Trucks
Car wont start, NOT battery
sometimes a rubber mallet doesn't work on the stater, you actually have to hit it with something stronger, like a hammer while turning it over. If not check to see if you have a pro lock on your vehicle because if that becomes just a little loose it won't start.
Apr 23, 2012 | 2004 Chrysler PT Cruiser
When my truck gets hot it doesn't want to start. Sometimes if you wiggle the key it will start, but when it doesn't start, it makes a clicking noise.
the clicking noise is most likely coming from the solenoid on the starter motor, the solenoid is like a big switch with contacts inside of it,when you turn the key to start the engine these contacts come together to transfer the power to the starter motor,if the solenoid can't be taken apart & the contacts cleaned or replaced it will have to be replaced.......hope this helps....cheers
Jun 15, 2011 | 1991 Toyota Pickup
My 08impala makes knocking or a clicking sound after I remote start it and then turn key. What is the knocking or clicking sound it sounds like its coming form them where radio is at. Is that my starter...
I have heard this click. It's electrical interference. When you remote start it doesn't turn everything on like the key would. It really shouldn't do this, but it doesn;t seem to hurt anything. If you had the remote installed recently ask the company about it.
May 18, 2011 | 2008 Chevrolet Impala
When I go to start my 93 Bonneville it loses all power and sometimes wont even crank, just click. I can jump it and once started it runs fine at 14 volts. I've changed the starter, alternator,negative...
Quick question, does the "security" light illuminate on the dash when you put your key forward and when it wont turn over? Do you have a little black chip in your key?
Mar 28, 2011 | Pontiac Bonneville Cars & Trucks
98 chev blazer wont start or make any noises...
Listen for a click from under the steering column when you turn the key on. If you hear no electrical click then your ignition switch could be bad. If you hear an electrical click the you starter soleniod is bad.
Jul 13, 2009 | 1998 Chevrolet K1500
Wont start unless jumped or restarted within 30 mins
When trying to turn my truck on only clicking noise under hood and in dash. Sometimes even after key is pulled out clicking noise in dash continues for a couple of seconds. Battery and alternator was check at Advanced Auto parts they say both are good
Jul 05, 2008 | 2005 Ford Explorer Sport Trac
Metra Ford F 150 Truck 1999 Logo
44 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
