Question about Plantronics Calisto Pro Series Cordless Landline/VoIP Phone
No dail tone on landline
No dial tone
Will not dial out on landline in the tone mode but
There's something wrong with the base unit that connects to the phone line. It's not sending any audio to the phone line, which would explain why tone dialing doesn't work and people can't hear you. (Pulse dialing doesn't need the audio tones so it will still work.)
I've never run across one doing this before. The problem is almost certainly some electronic failure, and I doubt there's anything you can do other than replacing the thing. If this is still under any warranty it should be up to the manufacturer to repair or replace it. If you got this from VoIP service provider, contact their customer service department.
Feb 03, 2010 | Philips VOIP3212G/37
My at&t landline has a dial tone but cannot call
check dialing mode matches what exchange is set to DTMF suspect phone is set to dec = decadic or pulse
Apr 17, 2009 | Vtech DECT 6.0 Cordless Phone with Digital...
Phone is on pulse when dailing a number
open the on screen menu of the phone there should be a selection for dialing rules.. the tone dialing rule should be in that selection..
Jan 08, 2009 | Uniden Cordless Phone
2 beeps, no dial tone
hand set no dail tone cant all out on the hand set due to no dail tone
Dec 05, 2008 | Uniden Cordless Phone
Home phone
my phone has a dial tone but wont dial out or recieve calls.
Sep 23, 2008 | Motorola Mobility AT&T Prepaid Free2Go...
TC1200 TONES/PULSES
There is usually a switch to change it from dial pulse to touch tone.If there is no switch check your user manual to see if there is a screen option.
tk46
Jun 19, 2008 | Panasonic KX-TG1033S Cordless Phone
No dail tone report
some dial connections dont like the filters attached. does the new modem have more then one ethernet connection on it? have u tried it on another connection if u have on in the house? it may just be your settings in the computer. are you using the same computer for both broadband and dial up? if you are then you may need to adjust the settings in your computer, your isp should have done all that for you.
Nov 29, 2007 | Computers & Internet
Plantronics Calisto Pro Series Cordless Landline/VoIP Phone Logo
14 people viewed this question
Top Plantronics Lands Phones Experts
Andrew Taylor
Andrew Taylor
Are you a Plantronics Lands Phone Expert? Answer questions, earn points and help others
