Sharp washing machine won't unlock door
I have a brand new Sharp ES-V80HA washing machine. As per the manual I started doing a 12 minute rapid cycle with no laundry in it but the washing machine hangs after filling and rinsing and spinning (it should take 12 mins to complete but is hanging after 3 mins, leaving 9 minutes remaining). It will not unlock the door despite stopping the cycle, or turning the unit off and on again. How do I get this washing machine to open the door again so I can put a load in, as it should have flushed out any residual water from manufacturing.
  • Kazza Mar 22, 2014
    I have resolved the issue by turning off the machine for a time.
    Top Expert:
  • Washing Mach... Master
  • 21,522 Answers
I was going to suggest switching t off for a while, allowing the thermal lock to release.
Posted on Mar 22, 2014
  • Kazza Mar 23, 2014
    Thank you :)
Master_Tech
  • 770 Answers
SOURCE: Washing Machine Door won't open
did that work?? you may have a bad or stuck door lock
Posted on Jan 24, 2008
SOURCE: washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Posted on Aug 18, 2008
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
  • 119 Answers
SOURCE: Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Posted on Aug 21, 2009
  • 744 Answers
SOURCE: In the Spin cycle, after 9 minuts, it will stop with a "UL".
"UL" means "Unbalanced Load" - make sure the washer isn't overloaded first or if you are doing rugs, blankets, or lots of jeans, split the load. You can also try running an empty or light load and see how the machine behaves.
If you still have the problem, you may have some issues with the drum bumpers, etc., but try the easy things first.
Posted on Jul 12, 2010
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Unlocking sharp
These machines are set that way. Once started, even if you stop it you have to wait for a timer to unlock it which takes about 3 minutes.
Jun 30, 2013 | Washing Machines
How do I reset and unlock the door on my Kenmore Elite quiet pak 4 washer?
Press and hold "end of cycle" at the right end of your panel for 3 - 5 seconds. The machine power should be on.
Try the door 2 minutes after this.
Mar 29, 2013 | Kenmore Elite 45986 Front Load Washer
WFW94HEXW door won't unlock and Door Lock isn't lit
if you machine is warranty you must call to the whirlpool, and get the assistance via online chat. However you must wait about 180 seconds since you did the command STOP, and stop the motor, fi the water level is higher must be drain before the latch door unlock.
2) if do not obey press and hold END OF CYCLE, wait about 10seconds
3) reset the machine unplugged from wall by 45 minutes, and then plug again, and turn on and unlock the door
God bless you
Jun 21, 2012 | Washing Machines
Hotpoint WMA62 washing machine door won't release
If the machine didnt finish the cycle due to the pump being clogged the door will remained locked also if the lock mechanism went bad, the machine will stay locked. Remove the top of the machine by taking the screws from the top back out. Once removed look down the right hand side and you'll see the lock mechanism, usually with a plastic tab you pull to manually release the lock.
Apr 24, 2012 | Hotpoint WMA64 Front Load Washer
Whirlpool duet washer door will not unlock or complete the cycle
  • Oct 13, 2011 | Whirlpool Washing Machines
    I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
    Hi!
    The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
    If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
    Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
    The Lexus car remote key control model ES300
    try this:
    1. Start with key out of ignition, drivers door is open all others closed and
    drivers door is unlocked.
    2. Insert key into the ignition (DO NOT Turn) and Pull key out.
    3. Perform these steps within 40 seconds.
    A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
    starting with lock. Use an even pace and try to go about one cycle per second.
    (1Cycle = 1 lock and 1 unlock).
    B. Close, then open drivers door.
    4. Perform these steps within 40 seconds.
    B. Insert the key in the ignition cylinder.
    C. Turn the ignition to ON (Do NOT Start) then back to OFF.
    D. Remove the key from the ignition.
    5. Press any button on remote for a minimum of 1 second.
    System should now lock and unlock doors once.
    6. Close and open drivers door.
    7. Press any button on remote for a minimum of 1 second. System should now lock and
    unlock doors. Once to confirm programming, twice to indicate programming failed.
    8. Repeat steps 5, 6 and 7 for additional remotes.
    Mar 23, 2009 | 1997 Lexus ES 300
    Washing Machines Logo
    164 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
