Question about Jensen VM9510 Car DVD Player
The harness of my jensen dvd/mp3/wma receiver the yellow wire and the ground wire came off i know how to put them back but i dont know where it goes (the yellow goes by the red or under
  • radames0309 Jun 14, 2009
    if it goes by the red that leaves 2 emty spaces witch one is the ground and whats the other one for?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
By the red, i doubt it goes under
Posted on Jun 14, 2009
Wire diagram for DEH-P3700MP
usually is on the deck under the sheath on top or bottom.yellow is battery back-up this goes to power all the time to keep your clock and settings right,red is to power that goes off when ignition turned off,black is ground,blue is amplifier remote turn on,blue/white is power antenna,orange is dimmer that makes display go dull at night when u put headlights on.purple wires and green wires are rear speakers,white and grey wires are front.as for sides im not sure
Jan 04, 2010 | Pioneer DEH-P3700MP CD/MP3/WMA/WAV...
Yellow wire unpluged from radio
Sure. The wire u are looking 4 is located in the bottom right side of the plug. Under the Bat (Red) and Ground (Black). On the last hole on the harness. Had same problem. Hope this helps you.
Jul 18, 2009 | Jensen VM9410 Car DVD Player
Help need bypass code or instructions
There should be an extra wire on your wiring harness, labeled for the e-brake light. Find that one. On my Jensen, it's a peach colored wire. In your manual, take a look and see what it says is required for activating the DVD playback feature. If you simply have to pull the brake handle to make it work, then yes, just ground that wire and you're in business.
On my Jensen, there was a sequence that had to be done - the brake had to be applied, released, and reapplied for it to work. What I did initially was to ground the wire and put a switch inline on it. To simulate setting the ebrake, I'd close the switch (completing the ground), then flip it open to break the connection (same as releasing the brake), then flip it back again, and the DVD would play.
I found a little while ago that there is a hidden feature menu on the player that allows the e-brake sequence to be bypassed with a code, which I put in and now it's not an issue.
Take a look at your instruction manual and let me know if it just has to have the e-brake on, or if there's some sort of activation sequence like my Jensen has, and I can firm up the answer.
Dec 26, 2008 | JC Whitney - Pyle 7" Tft/lcd In-dash...
Jensen double din dvd monitor uv8020
Here's what you need to know: DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On the Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In mine, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in the manner of the e-brake cycle I mentioned earlier.
Sep 11, 2008 | Jensen VM9510 Car DVD Player
I installed my in dash my self but i dont know how to bypass the e brake screen?
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Aug 18, 2008 | Car Audio & Video
Iva-d300
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
Jul 10, 2008 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Jensen dvd receiver model#vm9311ts
There isn't any code that I know of. Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
Jun 03, 2008 | Panasonic CQ-VD7001U Car DVD Player
Jensen VM9510 Car DVD Player Logo
135 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
