Question about Panasonic Tc-p50g20 Viera G20 Series 50" 1080p Wifi Plasma Hdtv Hdmi
Proscan hd tv has picture no soud shut it off then get sound no picture
Had only 1 year then tv started not to work like I would turn it on then no picture only sound then shut it off and back on then have picture and no sound
3 Suggested Answers
nfandres
  • 168 Answers
SOURCE: Blinking light
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, vif,sif, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician.
Posted on Jan 16, 2007
  • 17 Answers
SOURCE: My tv is working with sound and was fine. I shut
Your picture is missing- after 5 days call 911
Posted on Jul 15, 2009
"Fan lock"
Use the below link to locate ur nearest service centers ...
its an hard ware cognitive factor u alone cant rectify it ..
http://maps.jvc.com/cAscList/index.asp
Dec 23, 2007 | JVC HD-56FN97 56" Television
Sanyo dp42848 with soud no pic
There is sone short circuted components at its main board. Contact a technician. This is not a user repairable work.
Apr 27, 2013 | Televison & Video
When i try to turn the tv on it does it just clicks over and over
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Jun 21, 2011 | Proscan 55LC55S240V87 55 in LCD TV
When using an HDMI cable there is no sound
Unplug,replug the tv about an hour reset the audio back to factory setting.Should work if ur main tuner signal board is good.
Jan 16, 2010 | Proscan 26LB30QD 26 in. LCD HDTV
Picture & sound shuts off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Oct 06, 2008 | RCA L32WD14 32 in. LCD Television
Proscan ps52810 52 inch projection - composite/HD problem
I want to know where is the fuses because I can't start my t.v. manual or with the control I open the back and front can see no image no contact nothing what can I do?
Mar 10, 2008 | Proscan PS36600 36" TV
Tv: why do I only get sound when I turn the TV on?
Exactly i do no the problem in the video section.
Feb 19, 2008 | Proscan 32LA30Q Television
Remote Code
The code 11178 worked for us for our Comcast remote.
Lauren
Jan 13, 2008 | Proscan 26LA30Q 26 in. LCD Television
Panasonic Tc-p50g20 Viera G20 Series 50" 1080p Wifi Plasma Hdtv Hdmi Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
