Question about Vizio M401i-A3 40" 1080p LED-LCD TV - 16:9 - 120 Hz 178A / 178A - 1920 x 1080 - DTS Studio Sound, DTS TruSurround, DTS TruVolume - 3 x HDMI - USB - Ethernet - Wireless LAN - PC Streaming - Internet Access - Media Player
Tv shuts off all of a sudden
All of a sudden screen will go blank and i have to hit the start up button again
I hit the wrong button on the remote, and the tv now saids no signal. How do I get back to the channel the tv was on
hit the source button again that is for your scat press down to 1 HD should get you back on.
Jan 10, 2015 | Televison & Video
My Laptop will not start up goes to a blank screen.
Try running Last Known Good Configuration which should fix your problem.
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: your PC will boot to the windows. I
Jan 16, 2011 | Acer Aspire 3680 Notebook
Blue light is on and a blank screen on tv remote does nothing tryed hard reset with no change
Hello! Daniel Busa here with Dish Network customer service. The blue light simply means tv2 is up and running, you need to get the green light on. If it's still down hit th sat then power. If that doesnt work, hit the channel up button on the box system info should appear hit record three times, and then select, then power and it should start running again.
Dec 11, 2010 | DISH Network 322 DTV Receiver
Acoustic Solutions TV/DVD P1480 has stopped working
Doh me, daughter had accidently hit the standby button without realising, had a brainwave after posting above and tried that, everything working fine.
Oct 01, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Jun 05, 2008 | Sharp Aquos LC-32D40U Television
Is my lamp out on my LG?
Most likely you can have 1 or 2 problems.
1! the light is busted and you will have to replace that. You might also need to check your cooler fan bearing as you indicate it makes noise.
Please open following link( you need acrobat reader)
this is the service manual for your TV
ru-44sz61d
Apr 30, 2008 | LG RU-44SZ61D 44" TV
Sudden shut down
go to settings and go to initial setup, and click on master reset. the code is normaly 00000 or 12345
Aug 23, 2007 | Motorola Mobility RAZR V3
TV wont turn on and blank screen & no sound
this unit is dead ,possoble power supply problem. you must have warranty on this unit if its only 8 months old,if not contact place of purchase and ask wath is the life expectancy of their products and your tv set it start them thinking about repairing or replacing.
Aug 22, 2007 | RCA F27650 27" TV
Vizio M401i-A3 40" 1080p LED-LCD TV - 16:9 - 120 Hz 178A / 178A - 1920 x 1080 - DTS Studio Sound, DTS TruSurround, DTS TruVolume - 3 x HDMI - USB - Ethernet - Wireless LAN - PC Streaming - Internet Access - Media Player Logo
59 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
