Question about Reliable 234 Thread Portable Overlock
Using one needle
One needle
What is causing tension and needle position problems?
If the machine is new, it is probably still under warranty. Contact the manufacturer.
Apr 04, 2016 | Singer 7258.CL - Stylist 7258
How do i set timing on singer 4423
unscrew the bottom and left side of the machine and : Set the pattern selector dial to " zig zag".
Turn the stitch width dial to "6", Set the needle bar at its lowest point when
it swings to the left. Place clamp around
the needle bar, tighten its screw (a) but still
allowing movement.
- Set the timing gauge (4 mm) on the
needle bar so that piston touches bottom
of needle bar cradle without forcing and
tighten screw by hand.
- Turn the handwheel gently towards you
until gauge stops at 4 mm.
Turn the hand wheel until the shuttle hook
holder point is on the right side of needle,
the distance between needle hole and it
should be 0.5~1.0 mm.
- If the distance is incorrect, loosen the
screws of lower shaft gear , and
adjust shuttle hook to correct timing, and
tighten the screw.
It's not that complicated and, if you don't have gouges then, you will need a lot of patience. Good luck :)
Mar 09, 2014 | Singer 4423 Heavy Duty Sewing Machine
Tefal repairs
follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in wat
Nov 29, 2013 | Irons
The green light does not come on and it does not steam
follow this adjustment and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
Nov 04, 2013 | Oreck Steam-It Steam Wand
Does red light suppose to flash
follow this section troubleshooting and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 15, 2013 | Rowenta Effective DX1900 Iron with Auto...
Model gh3000 spool will not release for removal
Clean an iron:
  1. Unplug the iron.
Oct 09, 2013 | Irons
Floor steamer not getting hot
GOD BLESS YOU
Clean an iron:
  1. Unplug the iron.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Sep 30, 2013 | Conair Compact Garment Steamer Iron
Pump wont run
Clean an iron:
  1. Unplug the iron.
  4. God bless you
Apr 04, 2013 | Rowenta DG-980 Iron
II replaced and now handwheel difficult to to turn and cannot catch bobbin.
did you get the machine from a dealor or individual? not all machines put their needles in the same way. do you have a manual? it sounds like the machine needs to be cleaned (serviced). the oil is probably thickened, and will freeze the machine up. make sure the needle is in correctly, and threaded correctly. bobbin too.
Feb 08, 2013 | Singer 4423 Heavy Duty Sewing Machine
Singer Professional 5 keeps breaking needles
This should be in the sewing machine area. If you just paid $150 to have this repaired and it's still not right. Take it back and insist that they fix it properly at their expense.
The timing on sergers is pretty complex I would not attempt it myself.
Nov 10, 2012 | Singer 14T968DC - Professional 5 Serger
Reliable 234 Thread Portable Overlock Logo
29 people viewed this question
Top Reliable Irons Experts
Are you a Reliable Iron Expert? Answer questions, earn points and help others
