Question about Cameras
I want to instal a 4 or 8gb memory card on my Nikon 8800. Can the camera handle it. thanks john
  • johnrygh233 Jun 14, 2009
    Thank you for the info. Find it very helpful and enlightening.
  • 10,594 Answers
4GB would be more then enough for this 8 mega pixel camera. I would recommend 2GB memory card because camera will take much time to read/ write on 4GB memory card.
please do not thing about 8GB for this model as its hardware will not support it and you will get card error message.
Thanks.
Posted on Jun 14, 2009
Message in display says that the memory card is not formatted. I Have tried repeatedly to format. The results are the same with a new memory card. I have removed the battery for 24 hrs. but the card will...
There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article fix memory card not formatted error and learn how to fix it step by step. Best regards.
Aug 25, 2011 | Nikon Coolpix 8800 Digital Camera
When I shot each photo, the "system error 2" appears and I have to turn off the camara,
System Error 2 on Nikon Coolpix 8800 is usually after blow, even the small one, when you or somebody kick the camera and yes, FULL RESET on Set Up mode is just one solution. It's camera's error not the card.
From Nikon website:
Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
  1. Use the memory card that originally came with the camera (or a Nikon approved card) [/*]
  2. Remove and replace the battery [/*]
If the error is still displayed, contact Nikon's Service Department (below). If the above tips do not help the camera must be sent to Nikon Service, there are no user serviceable parts on Nikon Coolpix cameras.
We apologize for the inconvenience and will do everything we can to repair your Nikon camera as quickly as possible.
Good luck.
Jun 03, 2011 | Nikon Coolpix 8800 Digital Camera
Error 2 in my coolpix 8800. I bought a new battery in the store they said to do that, didn't help an I changed the memory card as well, didn't help
hi your camera has system error, usually the lens unit doesn't reset after taking picture. it cause error message. you should contact to nikon service center and ask them repair cost. usually they will tell on the phone. thanks and best regard!
May 23, 2011 | Nikon Coolpix 8800 Digital Camera
I got message "system error
Mar 05, 2011 | Nikon Coolpix 8800 Digital Camera
How do I transfer images from my Nikon 8800 to my computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Nikon Transfer or any other photo cataloging program.
You can get the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
Dec 08, 2010 | Nikon Coolpix 8800 Digital Camera
I have a nikon coolpix 8800. i have a 6gb card installed. I have the latest firmware. I recently took over 1000 pictures on a trip without downloading any of the photos. Once the picture count got over...
Try this...go into the menu and try to find an entry for "reset" to get back to factory default settings. Then, assuming you've safely downloaded any pics from the card, insert it into the camera, go into the menu and find "format"....follow the on-screen instructions to erase and optimize the card. Let me know how this works for you.
Nov 16, 2010 | Nikon Coolpix 8800 Digital Camera
I have a nikon d8800...when i take a photo the camera displays an error message. the only way to clear the message is to turn off the camera. when i turn it back on i see that the photo was saved...
In the absence of the contents of the message, I am going to guess that it is having some issue with the memory card. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. Some cameras seem to work with too-large memory cards at first, then throw a serious tantrum as the card starts to fill.
I think you need to try formatting the card, using the camera's own function to do so. This will establish whether the card is compatible with the camera. BEFORE you do this, save your pictures to your computer, as they will be deleted by the format.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 08, 2010 | Nikon Coolpix 8800 Digital Camera
I have a Nikon Coolpix 8800 with a "System Error 2"
Check the memory card. It's probably damaged. If not it should be a software error, and you have to take it to the dealer where you purchased it from
Apr 06, 2010 | Nikon Coolpix 8800 Digital Camera
Memory card
Hi Janet, do this:
To fix this, remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
Jan 02, 2009 | Nikon Coolpix 8800 Digital Camera
Nikon coolpix 5700 shows no memory left after purchasing a new card & batteries
The largest CompactFlash card that Nikon approved for the 5700 is 256MB, which is what I'm using in my 5700. That's small by today's standards and you probably won't even find it in stores. I see some web sellers have 256MB cards for only $6 or so. Other commercial card sellers on the web claim that the 5700 will handle CF cards up to 1GB capacity. That's what I might try since online they're selling for as little as $8 plus shipping. Given that the 5700 was introduced in 2002, any cards bigger than 1GB probably won't work.
Jul 21, 2008 | Nikon Coolpix 5700 Digital Camera
Cameras Logo
22 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
