Logik mp3 driver
My pc doesn't recognise my logik mp3 player. It's loading power but no access to files. Can I fix without a disc, no idea where that could be
SOURCE: always shows 40% and will not load
Plug in your player in USB port.After the system reckognizes it right click on My Computer.Select Manage.Computer Management should open.Go to Disk Management.There you`l have disk 0(your hard dribe) and another disk drive which should be YP-1.Right click on YP`s disk folume and select format.Wait a bit,then a dialogue will pop-up.Select format,start the operation and wait until it finishes.After the format is complete your player should work fone.It helped me some months ago and i hope it`ll help you too cuz the situation is exactly the same
Posted on Jan 04, 2007
ganns1980
  • 9 Answers
SOURCE: file error
With your mp3 player not playing any music, press and hold Search/Menu until the menu comes up (1-2 seconds). Scroll to the last chioce, which is Advanced Menu. Press your Play button to select it, select Format, select OK, and your mp3 player will be formatted. This WILL erase all of the music that you have on there, but reload it all with SonicStage, and you should be good to go.
Posted on Nov 15, 2007
SOURCE: ilo mp3 driver
I had the same problem but on different computers, home works great, office won't detect it.
Try using some other computer just to see if it the players fault.
I am loving my ilo, but its just day 2 so hope it stays good
pwatson
Posted on Jan 14, 2008
SOURCE: problem playing music files with new Goodmans mp3 player (GMP34G5)
i got mine about an hour ago and it works fine. don't drag and drop music files, sync them to the mp3 player using windows media player.
Posted on Jun 02, 2008
SOURCE: Samsung T10 Mp3 player to be recognised by pc
Heres how I solved this problem
- I was running XP SP2 with WMP10
(Windows Media Player 10)
- Windows will not recognise the T10 unless it has the right MTP (Media transfer Proticol) drivers. This is the little yellow flag you may see on the task bar adter Windows detects the device and trys to install the driver. The drivers are only found in WMP11. Therefore unless you are running WMP 11 your T10 won't sinc or be recognised.
- The Samsung software wont help- so don't bother even installing it as WMP11 has the drivers and does everything the Samsung software does + more.
- I tried to download and install WMP11 directly from the microsoft website but my PC failed the authentcation so I saved the file to my HD instead.
-I then unpacked the WMP11.exe file using WinRAR which i downloaded for free from http://www.download.com/WinRAR/3000-2250_4-10745708.html.
- I individually ran the WMP11 install file and then all of the other unpacked files by double clicking on them (it takes some time). This installed WMP 11
- I then shut down the PC, plugged in My T10 and WMP/windows recognised the T10!
I had a friend who alos did the above but had a couple of problems- he uninstalled WMP10, Installed WMP11 using the WinRAR method above and it didn't work. After uninstalling WMP11 and then reinstalling it again using the WinRAR to un pack it it finally worked after a couple of re boots.
Note: Prior to using the above method i googled and tried several other ways to get the T10 recognised and none worked. From what I can tell you Need WMP 11
Hope this helps
Posted on Nov 14, 2008
My computer wont recognise my MP3. I have recently moved home and have lost the disc that came with it. Can you help me without it costing money ?
could you search for driver with the make and model of the mp3 with google include driver and try and download it from the makers website this small file is allways free and esaly avlibale
Jul 13, 2013 | Matsunichi MF326 MP3 Player
My e-machines had windows 7 and became unusable. I had to use my pc and resorted to installing linux on it. I got the recovery discs from e-machines and after I put in the 1st recovery disc, it said...
You are getting this error because linux is installed on it.
Windows doesn't go well with linux.
Format your harddrive using any 3rd party formatter tool.
I mean, it should be like a blank hardrive without any files in it.
Then try to use the recovery disc.
Oct 02, 2011 | E-Machines eMachines Desktop PC
Files where lost on my logik mp3 player after changing the batteries, can they be retrieve?
Hi.
You might get something back if you can access the unit as an external drive when you plug it into your computer. A programme such as Recuva (http://www.filehippo.com/download_recuva/). Save to your hard-disc and then rewrite to the player after examining recovered files.
Best of luck,
ChrisPZA.
Mar 14, 2011 | Audio Players & Recorders
Hi I tried loading music onto my safeway 2gb personal media player and when I try paly it it says "no authority" - any ideas?
try checking that the format of the mp3 files are compatible with the player. some encoders don't use same format mp3 player natively recognises. try a converter program to "normalise" the files to the same format
Feb 08, 2011 | Audio Players & Recorders
I have a Telefunken TMP-444B, 4GB MP3/4 player. The setup soft ware disc does not load to any of my computors. Where can I download it. Cannot load music onto the player
Hopefully you got a solution already, but here goes mine: I also had a Telefunken TMP-444B, 4GB MP3/4 and i found you don't need a cd (my cd also didn't work). Try connecting it to your pc via usb-cable and access it on your PC. Simply copy your Mp3 or mp4 files onto it and see it should work. Mine did. Hope yours will.
(Just take care when deleting files, because i don't know if important files are protected on your mp3/4 player). Take care anyway ;-)
Cheers
Feb 05, 2011 | Audio Players & Recorders
DRIVER DISC - NOT RECOGNISED BY COMPUTER ON WHICH I,M TRYING TO INSTALL
CD/DVD player is no good (does it play other discs and are they DVD or CD that it plays, could be a dirty laser use cleaning disc), the disc is not compatible with your player (DVD disc in CD player), corrupt disc, no auto-run on disc, no files on disc. The list is quite long. have you tried to read the disc in my computer screen (presuming your using windows) as the files might be in a compressed format (.zip or .rar) in which case you might have to unpack them. If the disc is not recognised at all try it on a different machine (a friends) and see if it will read on that if it does then copy the files to a new disc and try again. other than that you can always go the the makers web site and download any drivers from there support area's. Any further help required let me know.
Feb 04, 2011 | Computers & Internet
Sony walkman will not recognise VLC files
Sony Walkman will accept converted video file and it's format should be MPG-4 or MP4. other format will no be played and be sure you have to put that in your "Video" folder of your Walkman.
Feb 04, 2010 | Sony Walkman NWZ-S616F MP3 Player
Frozen screen
The fault could be down to firmware or a faulty hard disk.
First of all, install and run the Philips Device Manager from the product CD.
Connect the player to the power supply and PC.
If the player is recognised by the PC, select the repair/restore option in Philips Device Manager, and follow the on-screen prompts.
This will format the player and re-load the firmware. NOTE: THIS WILL DELETE ALL TRACKS ON THE PLAYER.
If this doesn't help, or the player is not recognise, then the following might work:
Download the factory software from the following link:
https://www.p4c.philips.com/cgi-bin/dcbint/sget?url=/mprdata/060421/060421185016_12769.zip&ofn=HDD6330-17-v1.3.zip
Unzip the file to a new folder on your desktop, and open the folder to show the installation files and folders.
Connect the HDD6330 to the power supply and the PC. Before the HDD6330 registers on the PC, press and hold [VOL+] & [POWER ON] to reset the player.
As soon as the player resets, press and hold [VOL-], until PC recognises the player as a removable drive.
Player will show the connection icon on screen but without the bar and battery indicator at the top of the screen. You may need to try this several times to get it right.
When the player shows as "GOGEAR" or "MDJUKEBOX", right click on the drive from My Computer and click format. Click on "Quick Format" and complete the process.
If the player does not allow you to access or format the hard disk, then the disk is probably faulty.
Copy ALL of the files from the new folder exactly as they are (not including "New Folder", into the HDD6330.
When the copy process has completed, safely remove the HDD6330 from the PC, but leave connected to the power.
The player will restart and eventually show "Burn Success"
Press and hold [VOL+] & [POWER ON] to reset the player. The player will restart as normal, and hopefully go into the main menu.
If this still doesn't work, but the process worked ok and the player still froze on "Loading" then the PCB is probably the cause.
You can obtain a replcement from www.cheapestelectrical.co.uk
They are not listed on the site, but they definitely have them available. Unfortunately, they don't have the PCBs for the HDD6330.
Go to the about us page and contact them by phone or e-mail.
May 10, 2008 | Philips GoGear HDD6330 MP3 Player
Phillips mp3 player
Connect the player to the power adaptor and connect to the PC.
On the player press and hold "Power" & "Vol +", this should reset the player.
Wait for PC to recognise player.
If this doesn't work try the following:
Connect the HDD6330 to the mains adaptor and the PC.
Before the computer has a chance to recognise the player, press "Power" and "Vol +" to reset the player.
As soon as the player resets (screen goes blank) press and hold "Vol -" until the PC recognises the player as a removable drive.
Try to access the player through "My Computer" as you would the main hard disk.
If the computer recognises the player, then it can be restored by copying the system files directly on to the player.
Feb 14, 2008 | Philips GoGear HDD6330 MP3 Player
Klackitey Klack
If the drive is ticking, it suggests the actual HDD is dying. You can try the following to see if you can fix any disc errors through your PC, however if your PC does not recognise a drive has been attached you may be unable to do anything other than have it repaired elsewhere. If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
Apr 04, 2007 | Archos Gmini XS 100 MP3 Player
15 people viewed this question
 Grubhead
Grubhead
