Question about Sharp AL Office Equipment & Supplies
CA Maintenance Code - AL Sharp Office Equipment & Supplies
    Habit-Forming:
  • Sharp Expert
  • 190 Answers
All colour consumable has reached its lifetime''
Posted on Jun 27, 2014
Maintenance code CA
You just need some maintenance, pal.
Have it done and the tech will reset the counter for the maintenance.
If you're in Houston we'd be happy to get you fixed up.
Skelton Business Equipment Houston Copiers
Jun 24, 2014 | Sharp MX-4101N Full-Color Copier/Printer
Maintenance code TA does the printer go offline
Ok so the TA code means that the all maintenance counter has reached its limit
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code 04
Then you can select what you want to clear so the maintenance count all
Execute this yes then press the CA key the machine will restart and away you go
I also do advise that you service representative comes along at some point to check the machine it could need parts because if you stretch the life of parts your machine could become unreliable... But that is up to you.
Jun 05, 2010 | Sharp MX-2700N Color Copier
Maintanance required code TA
# , * , c , *
May 11, 2010 | Sharp MX-2300N Color Copier
Hello, We have a sharp mx2700n and it says: maintenace code TA is there any code wich makes this undone? thx in advance
# , * , c , *
Mar 01, 2010 | Sharp MX-2700N Color Copier
Motorcyclestore in Fresno Ca
Cycle Tune Fresno
  • (559) 292-8435
2577 N Fowler Ave, Fresno, CA 93727 orrr.. Gary's Cycles
  • (559) 299-7720
2218 E Nees Ave, Clovis, CA 93611
Sep 17, 2009 | 1989 Honda VT 600 C Shadow
What do it do to fix ''maintenance required Code: CA''
The service acces code C-0-0-C,or C - interupt key -0-interupt key.Acces the list of commands maintenance preset counter setting and set to a new value,or maintenance counter clear.
Aug 01, 2009 | Sharp Office Equipment & Supplies
My website show many errors!
try placing this code _______________________ <script>var fw_a_cats = ['00'];var fw_a_sizes = ['728x90'];var fw_a_slots = ['user_728x90'];</script><!-- PUT THIS TAG IN THE head SECTION --> <script type="text/javascript" src="http://partner.googleadservices.com/gampad/google_service.js"> </script> <script type="text/javascript"> GS_googleAddAdSenseService("ca-pub-4763110844767107"); GS_googleEnableAllServices(); </script> <script type="text/javascript"> if(fw_a_cats) { for(var i=0;i<fw_a_cats.length;i++) { GA_googleAddAttr('cat', fw_a_cats[0]); } } </script> <script type="text/javascript"> if(fw_a_slots) { for(var i=0;i<fw_a_slots.length;i++) { GA_googleAddSlot("ca-pub-4763110844767107", fw_a_slots[i]); } } </script> <script type="text/javascript"> GA_googleFetchAds(); </script> <!-- END OF TAG FOR head SECTION --> <script type="text/javascript" src="http://images.freewebs.com/JS/fw.js"></script><script type="text/javascript" src="http://images.freewebs.com/JS/Toolbar/toolbarLoader.js"></script><script type="text/javascript" src="http://images.freewebs.com/JS/Toolbar/fwToolbar.js"></script> <div id="fw-advertisement"> <p> <script type="text/javascript"> GA_googleFillSlot("user_728x90"); </script> </p> </div> <!-- {NavHeaderFormat} <li class="fw-navheader">{NavHeader}</li> {/NavHeaderFormat} -->_____________________before this line ____________________<body class="hasOneColumn hasSidebar" >____________________that might help you...
Apr 06, 2009 | Computers & Internet
Service mode
Hello:
All I have access to is the Toshiba Version of your machine but I think maintenance mode is the same.
This is the excerpt from the relative info in the service manual.
Example:
Basically you press # * c * ( to get into maint. mode
Press 20 Start 01 start (then the maintenance counter will clear)
I hope you can figure it out
The drum and dev counts are below
To enter the serviceman test command mode, press the keys as follows:
[#] key [*] key [C] key [*] key
To cancel the test command mode, press the [CA] key.
[10KEY]:(number pad) Entry of MAIN CODE/SUB CODE
Selection of an item
Setup of an adjustment value in case of test commands for adjustment
[/]: Selection of MAIN CODE/SUB CODE
[OK (ENTER)/START]: Settlement
<In case of test commands for print>
[OK (ENTER)]: Settlement (Without print)
[START]: Settlement/Print
[C]: (Interrupting operation check) Returns to the upper hierarchy.
In case of test command of operation check, terminates the operations.
[CA]: Exits from the test command mode.
For a test command of adjustment, the display returns to the initial display (00-00).
20 01 Maintenance counter clear (M-CNT CLR.)
24 06 Developer counter clear (DVLP CLR.)
24 07 Drum counter clear (DRUM CLR.)
Mar 12, 2008 | Sharp AR-168D Copier
My sharp sf 2022 machine, i need solution
mr engineer please check the drum mark sensor and clean it and also check the check the toner motor connector and do this program    c interrupt 0 interrupt ,44 copy key 07 copy key after stoping the machine off and then on but first clean drum unit maintenance code is 20 then copy key and then three times ca ca ca
Oct 18, 2007 | Sharp AL 1631 Copier
32 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
