Netgear r6300 bought as referb.Cannot connect to HP 3050 via wifi ?Also small window keeps popping up wanting user name and pass word (will put up 5 or more of these) apparently wanting to connect to
Also cannot seem to turn wifi on .
  • 3,320 Answers
Look in your manual How to reset the router.
Posted on Apr 06, 2014
I need how to set a password on the wifi AC1200
login to the router main interfacew normally by 192.168.0.1 the user and password are on a sticker on router somewhere and then there will be a tab in interface that will say Wireless the pass word can be changed via there. another alternative is if the router has WPS just press button on rpouter and on device find WPS connect in wifi settings and it will auto connect.
Sep 17, 2016 | NetGear Universal WiFi Range Extender...
Router keeps resetting
Router is probably overheating. Make sure there is ventilation around it.
Apr 06, 2014 | NetGear R6300 WiFi Router
Have to reset wireless access point several times a day
Make sure it's not getting too hot. That is usually the problem.
Mar 21, 2014 | NetGear R6300 WiFi Router
Must reset R6300 daily
You have posted your work around not the problem.
What activity is going on when you have to reset?
What have you tried to do to fix it?
Is it at the same time everyday?
Is your ISP's equipment working ok?
How long has this been going on?
I need my wifi to work...it has never been set up
Connect your computer directly to the router via the Ethernet cable. Turn your computer on and make sure your router is also powered up. type 192.168.1.1 in your URL bar, a screen will pop up asking for log in credentials. Your default user name is admin and password is password. After youved logged in go to wifi settings and create a network name and password.
Mar 08, 2014 | NetGear WNR2000 Wireless Router
My ipad ask for a password, I put in my net gear pass word and will not connect
Ipad password first. then make your connection to router access via work preferences I think can't remember, it is menu where you set your emails and info look under wifi setup you will need your security code that comes with router, should be on the router bac/side.
Oct 01, 2013 | HP Netgear Wn2000rpt Ieee 802.11n - Draft...
Hard reset
You can return the router to its factory settings. the end of a paper clip or a similar object to press and hold the Reset button on the back of the router for at least 7 seconds. See Manual
http://www.downloads.netgear.com/files/GDC/R6300/R6300_UM_1Jun12.pdf
May 02, 2013 | NetGear R6300 WiFi Router
I have a LG 47 inch Smart TV Mod No 47LM6200 TV. I connect to the TV to my Wi-Fi. My router is a new Netgear R6300. I am able to stream movies and YouTube videos to two or more laptops at the same time and...
I would try connecting a network cable to the TV and router directly. Sometimes the WiFi connection can be limited by interference or the conversion process. I personally for fixed devices use a direct physical connection and WiFi only for true mobile devices.
May 04, 2017 | Computers & Internet
Dear sir i want to use my netgear wgr614 router as access point. please give me suggestion how can i do that
In Your web browser type in 192.168.0.1,it will ask you for a user name and password,user name is admin and password is password,once you enter the netgear setup utility find the section that ask you if you would like to use as an access point,check it,save changes-you will have to download the user manual on detailed step by step instructions from netgears website in order for it to work-i would download the user manual before you do anything at all and read first what has to be done-Good Luck-Access points are not easy to configure and must be connected via an ethernet cable when doing the initial setup-Have Fun
Jan 22, 2011 | NetGear WGR614 Wireless Router
Netgear WGR614 router with USB Cable Modem
When working with routers, CAT-5 cables are the more usual cable used. Your modem's Ethernet Port --- connect it via cable to the router's WAN input. Connect one of the router's LAN outputs to your computer's LAN input with another CAT-5 cable. Go through the appropriate Router Setup by putting http://192.168.1.1 into your Internet Explorer, with ' admin ' for User Name, and no password (just press Enter in Password frame). Once you are in to the router setup, you can select your Network Name (SSID) and then implement whatever Security you might want to use. You should be up and running by now, nhave lots of fun!
Dec 18, 2009 | NetGear WGR614 Wireless Router
Computers & Internet Logo
David Payne
David Payne
