Question about Behringer Bcd3000 B-control Dj Mixer Scratch Mp3s New
Deck a wont work anymore
Deck A will not load. It reads Audio Through. Deck B works fine.
    Scholar:
    New Friend:
  • 125 Answers
Check the midi signals being generated against what your program expects. You'll possibly find a control has ceased working in which case it's likely a bin job. If however the setting is wrong you can normally change it in the program.
Posted on Apr 15, 2014
I have vms4 decks, when i play a tune on my right deck i get serious crackling noise out of my speakers and headphones...any advice please guys?
Have you tried isolating the problem, like switching cables from the left side that is not making noise? Also check connections,
I say this all the time and use all the time.... electronics spray contact cleaner, usually takes care of crackling noises
really hope this helps?
Mar 04, 2015 | American Audio VMS4
How do you connect tape deck to pmp 4000
Hi, use the RCA/Phono connections for the Tape In & Out. The level will be set by the Master/Main fader. If that is not so convenient (& assuming it's a PMP4000?) there should be a "Main 2" output & connections with the level controlled separately to Main 1 via a Knob / Rotary control over to the right above the "Mono" fader... Hope that helps... Good Luck!
Jul 11, 2014 | Behringer Pmp3000 16 Channel Audio Mixer
Kmx02 disk spins fast, does not read
Educated guess is the deck cannot read the disc for some reason and is trying to find the index to start reading it. Try another disc and see if you have the same problem. Some discs will not play on some machines especially if you copied them yourself due to data duplicating copy guards installed in some machines.
Mar 04, 2014 | Numark Industries Numark KMX02 Dual Deck...
M-Audio Xponent wont initialize (Track lights wont boot/load up) after it turns on. All of the knobs stay lit up and thats the only thing that happens. I also opened up the xponent to see if it was sitting...
I have the same problem except mine worked out of the blue then stop after a minute whilst mixing, m-audio/avid are no help what so ever, as they want me to pay to speak to a support advisor.
Sep 11, 2011 | M-Audio Torq Xponent Digital Dj Deck...
Hi, I have a cortex DJ Mix 300 but only some of the songs on my ipod are being picked up on the database when I load it up. It doesn't seem to make a difference whether the files are MPEG or other...
There are different digital formats and some are not compatible to transfer file names... It is frustrating isn't it?... run into this all the time. To fix the probllem you would probablly have to buy a music editing software packaage that you could edit the files and put them all in the compatible mode.
Aug 06, 2011 | CORTEX DMIX-300 Mixing Deck For iPod, MP3...
Hi. How do I fix a CD deck that wont open if I press eject? The deck refused to open with a CD inside. The deck wont play the CD if I press play and wont eject if I press eject. please help. Thanx TC
To retrieve the CD safely, the safest way is to open the unit. A common problem is that a tiny belt from a motor that drives the eject deteriorates and slips so there isn't sufficient drive to move the mechanism. The unit is probably in a mode expecting to eject and has commanded the motor but it doesn't complete... Do as I say and open the unit to do the retrieval. Then get unit serviced.
Dec 04, 2010 | Gemini Sound Products Gemini CDM-3700G /...
I have the Fostex MR-8 mk II without the burner. I'm having trouble as of late at exporting my finished song to a laptop computer. It's worked fine in the past. Could it be my USB cord is bad? The computer...
USB cords are cheap and can often be found even in Thrift stores... try a new one to eliminate that possibility... I will say they RARELY go bad unless they have been abused.
Remember that reading a USB stick by the computer is FAR different than transfering data from the Fostex...
MAKE SURE the driver for the Fostex in your computer is intact...
OFTEN the stupid DLL files that were working get CLOBBERED by new software and suddenly old things that used to work don't anymore... Thank MS for the stupid thing of allowing new software to change DLL's.
Jan 07, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
How to use Audioline Pro DJ Multimedia Mixer M Dex 3.0
I have been recently using this Cd Dj deck at parties and have some general knowledge of the product, it has alot of potential. Is there anything in particular that you need help with? Or is it the general concept of using them.
Currently, i don't think there are that many websites that explain how to use the Cd decks, however i can provide you with some basic information. Most of the information here could be worked out by trial & error.
- Pitch control on the right of each cd deck can be slid up ( slows it down %) and slid down (speeding the track up %) i think the pitch control has a range of either +-10% or +-16%.
- Cue button, has the potential for Cue'ing or setting up the cd to instantly jump to the "cue'd" point with the press of this CUE button. This is done by either pressing play/pause button and rotating the jog wheel to a point of time in the track which automatically sets the cue point OR holding down the >> or << search button to find a spot within the track at a greater speed.
-Vinyl mode. Pressing this button will set the deck to the "vinyl mode" to simulate scratching or even backspins. pressing this button again will change the mode back.
- the Crossfader (or 'X' fader) button will select the left cd track if the x fader is all the way to the left and the right track if the x fader is all the way to right. having the X fader in the middle will play both tracks together.
- Low, Mid, High. These nobs on the middle section of the deck change the individual track by which it is corresponds. (Left side = left cd track, and vica versa) Low refers to the Bass of a track which can be essential for mixing two tracks and elminating excess bass noise. Mid refers to the drumming and even synth of a track, and changing this can result in some cool sounding effects. High refers to the 'high' frequencies of the track playing, such as snares, hi hats and possibly vocals. All these controls are crucial to understand in order to mix 2 songs together successfully. It's good to get a chance to muck around with these cointrols. The middle of each control resets the setting to normal or default.
- Channel fader. the two controls that slide up & down on both sides of the mixer on the deck. This is also referred to the volume setting. Useful for mixing seamlessly one track into another.
- Gain. This control at the top of the mixer refers to the volume level or 'gain' of the cd track that it corresponds to.
- Jog wheel. Serves 3 purposes. firstly it can be used whilst a song is playing to temporarily speed up or slow down the track to match with the song on the opposite side. secondly, whilst holding down the 'search' button, operates as a control to quickly find a spot in a song. and lastly when selecting "vinyl" mode, can simulate the reaction of a vinyl turntable. The scatch function, and backspin effect.
- The pitch button, is just another control to speed up or slow down a song temporarily whilst holding down the '+' or '-' button.
- Reverse button, for a certain amount of time will play the song on the left or right in reverse.
- Time. this button is essential to change the time selection on the cd deck, to either "Time elapsed", "Time remaining" and "total time remaining on the cd".
- the "tap" button, allows the user to physically "tap" the button in time with the song's beat, which calculates the Beats per Minute (Bpm) of that song. which is essential to work out the bpm of 1 track to mix the speed with that of the opposite deck.
- Cd/usb/sd, changes the mode of system reading. from CD to USB or SD card.
I really hope this general guide to using the Audioline ProDJ MDex3 has helped!
Peace. Marc.
Apr 03, 2009 | Music
Behringer Bcd3000 B-control Dj Mixer Scratch Mp3s New Logo
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
