Question about Sewing Machines
Needle cant grab thread in bobbin
When the needle goes down to the bobbin, the needle is not picking up the bobbin thread. Instead, it is coming in front of the bobbin? What can I try to fix this?
    Problem Solver:
  • 5 Answers
Make sure you get a new needle, put it in RIGHT. usually flat side to back. Make sure your bobbin is turning in the case CLOCKWISE
Usually it is a bent needle, or it is in wrong. Also, make sure your thread in going through the eye of the needle, and not twisted around the needle.
Posted on Mar 25, 2014
lavon82931
  • 17 Answers
SOURCE: needle won't grab bobbin thread
Check the position of the needle. Some machines have to have the needle in a certain way or they won't pick up the thread from the bobbin. Make sure the screw on the bobbin is tight but not to tight you may have to adjust it a few times to get it where it needs to be. Also make sure the bobbin is wound tight
Posted on Oct 14, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
SOURCE: sewing thread won't pick up the bobbin thread
are u holding the end of the top thread hen needle goes down?
it helps :)
Posted on Mar 17, 2009
SOURCE: Model 3205 FA not picking up bobbin thread, needle
- check ifu are using same needle model.
- check hight of needle bar is ok
- check timming between needle bar and hook.
- check if your material is very stritch or no
- check blad point of hook is ok or no
best regards
Posted on Aug 20, 2009
Sewtech1
  • 69 Answers
SOURCE: The thread from the needle that goes down to pick up bobbin doesn
make sure your needle's flat bit shows to the back and it is in deep anough. else your timing is out.
Posted on Jan 22, 2010
I have a pfaff 2040 and when the needle goes down to pick up the bobbin thread the main thread wraps around the bobbin housing and jams. Doesnt grab the bobbin thread. How can I fix this?
Be sure to use a brand new needle because a bent needle could miss the bobbin thread.
Search the internet for sites and videos relating to sewing machine timing or take it for service.
Dec 02, 2016 | PfaFF Tiptronic 2040
I am having problems with the bobbin its not picking up the bobbin thread through the needle
thread the upper part and the needle put presser foot down hold loose end of thread with felt hand and turn the wheel with right . the needle goes down shuttle wraps the bobbin thread around the upper and when needle comes up the bobbin thread will be with it . OR have yo MOMMA SHOW U HOW
Feb 18, 2015 | Sewing Machines
My bobbin thread won't come up with the needle. so, I can't sew. how do I fix it
First, make sure the needle is installed correctly. Then when you thread through the needle, it should go through the hole so that the thread basically lies inside the groove that runs down the side of the needle. These two steps are critical to being able to pick up the thread properly!! Typically the thread feeds from the left side or some from the front.
Secondly, make sure the bobbin is loaded correctly and firmly attached in place. The thread should just hang off the outside of the bobbin.
Hold onto the upper thread and manually turn the machine through the start of a cycle. When the needle goes into the top plate and down toward the bobbin, a hook should grab the top thread, rotate it about straight down (6 o'clock position) and then release it to grab the bobbin thread. Continue slowly turning the machine manually until you see (hopefully) the thread from the bobbin. Use something thin to pull both threads to the rear, under the foot, and all should be good. When you first start to sew, you might need to hold onto the top thread so it is not pulled out of the needle.
My guess is if you have done all the above, you could have a timing problem that needs to be adjusted at a repair shop.
Mar 08, 2014 | Singer Sewing Machines
Needle goes down but don't pick up the bobbin thread. It come up and tell me that my upper or lower thread is cut.
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide-this is improtant for the
thread tension
make sure the bobbin is turned correctly in the bobbin case
also could be a problem with the computer motherboard
or there could be a problem with the timing
Dec 03, 2012 | Brother PE-150V Computerized Sewing...
It stopped picking up the bobbin thread while sewing. In the middle of a zig zag sewing project, it stopped picking up the bobbin thread. I cleaned the bobbin area and needle area and tried again and it...
You can take the slide plate off, that your needle goes through and watch to see if the arm grabs the bobbin thread, if you can get it to pick up, than slide scissors or something flat under your needle and manually pull both threads through, replace the plate.
Your bobbin thread could be wound to tight or spliced threads on it, and your tension needs to be adjusted. If your using a pedal, try setting to a slower speed.
I would try a different bobbin and thread it manually as in the step I mentioned, if you can't see the arm grabbing it, you will need to check to see if you have loose threading jammed in youir machine, if this isn't the case and adjusting the tension dosen't help...than you will need to replace the bobbin casing.
Kind regards!
Sep 12, 2011 | Janome 2049LX Mechanical Sewing Machine
Top threaded needle will not grab bobbin thread so I can begin sewing.
you might check your needle to see if it's bent
check in the bobbin area for any lint or loose threads
make sure there is a bobbin tail at least 2 to 4 inches long
hold the top thread tail ( at least 2-3 inch tail) as the needle goes down
Aug 03, 2010 | Brother XL-5130 Mechanical Sewing Machine
Sewing thread won't pick up the bobbin thread
it helps :)
Mar 17, 2009 | Euro-Pro 1260DX Mechanical Sewing Machine
Needle won't grab bobbin thread
Jun 17, 2008 | Kenmore 15208 Mechanical Sewing Machine
Machine wont pick up bobbin thread
needle won't pick up thread I think the timing is off, how do I retime it?
Aug 25, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
109 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
