Question about SpeakerCraft MZC-88 Amplifier
SpeakerCraft MZC-88 Amplifier quit working
I have two of the above amplifiers on my home audio system. Some of the zones still work; however, most have suddenly stopped....
SOURCE: Speakercraft DBB12100 Amplifier, Circuit problem
Sounds like its a problem with over heating. open unit clean out all dust and dust bunnies wich compressed air. check that all fans are opperating. (fans on 6x100 amp units or thermal controled). If amp goes into protection prior to fans turning, there is your answer. the @ power supplies will have a green light on the output side. if the light in on power supply is good. or you can check that the output voltage is at 48Vdc on both units.
Posted on Sep 18, 2009
  • 30 Answers
SOURCE: I have the same SpeakerCraft
I repair these:
http://calgary.kijiji.ca/c-buy-and-sell-electronics-Speaker-Craft-MZC-and-BB-Series-Amplifiers-Repair-Service-W0QQAdIdZ229607818
So they never fail again...
Posted on Feb 03, 2011
  • 11800 Answers
SOURCE: I have Nuvo Essentia D amplifier. Worked for 6
The clicks are generated by 2 causes:
1 - the arrival of the electric current thru the amplifier circuit in the speaker in a large amount- it's supposed to happen, after that the current drops to the stand-by value very quickly. If a zone doesn't click then the amplifier of that zone has failed and when connected it draws so much power that the overall voltage drops so low that the processor of the unit is no longer capable of working and the system freezes.
2 - inside the unit there are also small relays that are used to power the amplifiers on command . If one of them is shorted the corresponding amplifier will not work and the relay will draw a lot more current than usual.
From what you describe it appears that several amplifiers hare in different states of failing: 3 completely, 2 already has secondary bleeding and is close to complete short, 4 has just started to fail. The unit will have to be tested, the failed amplifier circuits replaced and the power source inspected for damage. The job isn't complicated but it requires a basic electronics experience.
Posted on Jul 24, 2011
  • 30 Answers
SOURCE: SpeakerCraft MZC-66 , all zones just buzz\ need to
I fix these. Please see this link for details.
Posted on Oct 25, 2011
hbsurfdawg
  • 95 Answers
SOURCE: What causes cracking, popping sounds on most zones of a MZC 66 amplifier controller?
Try this to isolate where it is coming from. Either the zone amps are defective, which is not likely, or the main amp is at fault. Hard to believe they are mis-wired, they typically are foolproof in this area.
At the main controller, try the two zones that are good and plug them into the 4 bad zones one at a time and see if you get the same symptom. If you do, then it is not the main controller and something common to the 4 zones is causing the issue. If they are wireless, then you my have interference so check if you can select different channels.
e
Posted on Nov 20, 2011
Cracking Sounds in Speakers
I can fix it for you. Please contact me at ken_more@netzero.net
May 23, 2013 | SpeakerCraft MZC-66 Amplifier
SpeakerCraft MZC-66 , all zones just buzz\ need to find a repair person that know and understand this brand
That's is probably the main IC chip got busted already that causes the hum.
Hope that gives you an idea...
Jul 08, 2011 | SpeakerCraft MZC-66 Amplifier
I have the same SpeakerCraft mzc-66 Model. Installed 2005. About 2yr later on one of the zone that was rarely used, it started to just put out a clicking noise. It is now down to only zone 1 and 6 that are...
I repair these:
Jan 17, 2011 | SpeakerCraft MZC-66 Amplifier
Looking to have one imput play through all 6 zones using a single keypad
simple to program the single keypad to initiate all zones on a single source at a pre set level using the ez tools software
Nov 26, 2010 | SpeakerCraft MZC-66 Amplifier
Another Speakercraftt failure
I repair these so they don't break anymore
Aug 28, 2009 | SpeakerCraft MZC-88 Amplifier
Mcz88
If your installer is an authorized agent or dealer of speakercraft product, it has a 2 year warranty. What type of problems are you experiencing with the system? Do you have a single 8 zone system or are you daisy chaining two units? post a comment, and I can do some research for you. I am an integrator and it's quite possible to have system failures do to a number of causes relating to all sides of the product. Firmware, Software, Hardware, Programming, as well as power failures and wiring issues all can play a part in creating a real headache. I have had systems in the hundreds of thousands of dollars crash due to one conductor of one wire in a 30,000 + sf home. And it is very time consuming as well as aggrivating to all concerned. If I can help in any capacity, I will gladly do so. If your installer has your confidence, that's 80% of the battle.
Jul 02, 2009 | SpeakerCraft MZC-88 Amplifier
265 people viewed this question
Top SpeakerCraft Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
Ronny Bennett Sr.
Ronny Bennett Sr.
Craig Butler
Craig Butler
Are you a SpeakerCraft Audio Player and Recorder Expert? Answer questions, earn points and help others
