Question about Panasonic Microwave Ovens
Panasonic nn5050b service manual
F16 fault code on display
Amw528 error5
Microwaves have fault codes to help us determine the problem. Click the link below, it will take you to the Panasonic Combi Microwave site. Look at the manual closely. Either the fuses are blown or the microprocessor board is fried. Good Luck and be careful! Safety first! Commercial Microwave Ovens Large Microwave Commercial Kitchen Appliances...
Feb 05, 2016 | In Microwave Ovens
Why my microwave NN GD371M will run for 4 seconds then shut off. display shows code h97?
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Jun 17, 2014 | Panasonic NN-T990SA Microwave Oven
Panasonic inverter 900w microwave fault code h97
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
Fault code FO9
F09 means that it's running on the wrong power frequency.
Is this a model designed for a different country than the one you're using it in?
Does your owner's manual show a way to select a different power frequency?
If for some reason you don't have your owner's manual, see Panasonic.net for support.
Oct 10, 2009 | Panasonic Microwave Ovens
Panasonic Pro II NE2180 no fan code f 14 shown
Code F14 is not shown in the service manual, which is at our site here for your convenience.
If the service manual is no help, please verify the fault code and reply back.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | Microwave Ovens
MESSAGE DISPLAY H98
The H98 fault on a Panasonic can be a bad magnetron, inverter or control panel.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 27, 2008 | Microwave Ovens
Panasonic Oven repair
The oven is Normaly service by board and parts swapping. The processor board would be difficult to service without proper diagnostics. If you take in consideration of the time and the extent of the diagnostics to analyse the fault, it would not be cost effective.
The most common causes of failure is the power supplies, and safety switches. Follow the information in the service manual to take voltage reading and test the switches.
If you have to work in the high voltage section, take great precaution. This is very dangerous to work on. You will need the proper high voltage test meter probe to check for proper high voltage operation. The service people swap out parts to test. This is the fastest, safest, and easiest way to service these.
Normally, outside of warranty we found these not worth to service unless the fault was very simple.
Jerry G.
Apr 09, 2008 | Panasonic NN-S753 Microwave Oven
Microwave Ovens Logo
76 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
