Question about Neff Dishwashers
C6 error code
My Neff dishwasher I'd showing error code C6. What does it mean ?
bobotfel
  • 236 Answers
SOURCE: air conditioner
Remote control units have diagnostic program in the
control, after 3 to 5 minutes of operating if the diagnostic
tools detect abnormal operation, then its shutdown the unit
to protect from damage. Thermistor sensor is one of the
parts that detect the operation of the unit. Out of range
or defective thermistor can shut the operation of the unit.
- If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
- Out of range thermistor sensor in both return air and freeze up sensor can cause the tripping “off “ the unit. The resistance of both thermistor is 8 to 10k ohms@25 deg. C temp. , so can test by using ohm meter.
- Try also to check the voltage in you area if normal, loose ac outlet.
- Be sure that unit is clean no obstruction in your air out and air in.
- Unplug the unit to reset the c6 error.
Posted on Jan 12, 2008
  • 3422 Answers
SOURCE: ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL NUMBER LSZ244VM4
The first thing i'll say is you will need to get it repaired by a technician and i strongly recommend you not to do it by urself.
Goodluck..
Posted on Mar 22, 2008
Brinip
  • 16 Answers
SOURCE: bumatic dishwasher bdw13 showing error code 1
Ok I think I can really help you here.
This is your error code, sounds like it has problems filling, might also be blocked.
‘E1’ LONGER FILL TIME. FAUCET IS NOT OPENED.
Ensure that inlet hose is not
kinked or crushed
Found the online manual for this model, it is a PDF file so you will need 'Adobe Reader' to read it. (click on link)
http://www.tlc-direct.co.uk/Technical/DataSheets/Baumatic_Manuals/BMBDW13.pdf
That should help you
Bri
Posted on Feb 07, 2009
SOURCE: c6 error
Error C-6 appears on photocopier
Posted on Apr 10, 2009
  • 37 Answers
SOURCE: What does the error code LE mean on my LG Dishwasher
MAin wash motor needs replacing
Affordable Appliance Repair
Lake Forest, CA 92630
Posted on Aug 22, 2009
Hi please can you tell me what error code drying 4 means on neff wadher dryer v438oxogb please? Many thanks
By chance are you getting error E04 ? If so that means
(temperature sensor) shorted or open circuit
  • Check wiring
  • Check wash NTC
Nov 08, 2016 | Neff Dryers
Nested IF functions in excel
Your first IF condition is “=IF(C6>6000,0.15%*(C6-6000),0)”
Where:
C6>6000 is your logical condition
0.15%*(C6-6000) would be the value if your logical condition is TRUE, and
0 would be the value if your logical condition is FALSE.
Your 2nd IF condition is “(IF(C6>30000,0.3%*(C6-30000)))”
Where:
C6>30000 is your logical condition
0.3%*(C6-30000) would be the value if your logical condition is TRUE, and
? would be the value if your logical condition is FALSE.
You are missing the value if it is FALSE.
Hope this be of some help/idea. Post back how things turns up or should you need additional information.
Good luck and kind regards.
Oct 26, 2007 | Excel (SS8SATAS5128400R)
Error code C6
On a later model, 6800, C6 indicates hardware error. Not user fixable. http://www.manualowl.com/m/Konica%20Minolta/Fujitsu-fi-6800/Manual/284852?page=149
Jun 07, 2014 | Fujitsu fi-6130 Flatbed Scanner
Bosch she45 dishwasher code c6
Fan -Related Problem code c6 Means the Fan Rotation to too low Durning Operation
Jul 09, 2012 | Bosch 24 in. SHU43 Built-in Dishwasher
What means error e23
I can't find any results for this error code. I would contact Neff's customer support line for assistance.
May 26, 2012 | Neff 24 in. S5453X1 Built-in Dishwasher
Neff dishwasher error code e25
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Oct 13, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
Dishwashers Logo
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
