Question about Altec Lansing MX6021 200 Watts RMS 2.1 Expressionist Ultra Speaker System
Mx6021 power supply burn
How to get the power supply board and how many out put voltage & amper
  • Altec Lansing Master
  • 3,320 Answers
The cost to repair these speakers would be prohibitive. Get a replacement system on ebay.
Posted on Mar 30, 2014
Hi power supply whent pop. PC worked on battery for 20 mins. got new power supply but will not charge. Is there any voltage protection inside and how do I get inside My Eeee900
It is very important to check the power output produced by the ac adapter. Make sure that the output voltage and ampere of the new power supply is the same with the original power supply provided with the laptop. The new power supply you purchased may be producing lower or higher ampere than the required power to turn on the unit and charge the battery.
I suggest to purchase ASUS Eee recommended power supply or ac adapter for your laptop before it gets damage by incorrect power voltage or ampere used.
May 06, 2011 | ASUS Eee 4G Notebook
6 bottle unit model cwc-600 died after 6 months. Acts like it isn't plugged in or a blown fuse. But no fuse!
The fuse is on the circuit board, behind the rear cover. It's a 2.5 ampere metric fuse. These boards are very voltage spike sensitive, and chances are you need a new board, as the rectifier diodes in the switching power supply blow and short out easily. If you get a new board, use a voltage spike power strip to protect it.
Nov 02, 2010 | Cuisinart Private Reserve CWC-600 Wine...
My HP compaq nc 6400 stopped working. When I press the power on button the amber light flashes three times and then nothing. Works fine without the battery. My battery is only 4 months old. I left the...
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Oct 13, 2010 | Computers & Internet
My aser 7730 will not turn on? When the charger is plugged into the laptop the light on the charger flickers? Is this a mother board issue or power jack or what ? Help !
Oct 12, 2010 | Computers & Internet
Battery lasts only approx ten minutes. If the battery holds a lot more power than it supplies, it is certainly not supplying it. Without the net power supply this machine is less than useless.
Sep 23, 2010 | Acer Computers & Internet
My satellite l300 is not turn on. no lights for charging or power. power adepter is working. what can i do ? pls give me suggestion.
Try removing the battery from the laptop & see if it will power up. If not, then you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
Sep 07, 2010 | Toshiba Computers & Internet
Not charging
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
Aug 31, 2010 | Computers & Internet
Hi My laptop 4810T Can't use it's battery and it works only in plug in mode(when it is connected to power supply by adaptor ) The System shows no problem and can detect the battery and the precise amount...
Aug 30, 2010 | Acer Aspire 5520-5156 Laptop
HI I HAVE A PROBLEM WITH MY C500 FIRT OF ALL THE DC JACK ON THE CORD MUST HAVE WORN BECAUSE IT STOPPED WORKING I TESTED THE CABLE IT HAD A BREAK IN IT SO I BOUGHT ANOTHER ADAPTOR POWER SUPPLY AND I GOT...
Aug 25, 2010 | Computers & Internet
Altec Lansing MX6021 200 Watts RMS 2.1 Expressionist Ultra Speaker System Logo
383 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
