Question about Health & Beauty
Invacare auriga 10 Hi from Australia.I have just been given a Invacare Auriga to try to fix for a lady. Horn stuck on so some time ago, somebody disconnected it.Dont know if that is an indication of
Has my questions shown above
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Disconnecting the horn, in most cases, should not affect anything else as long as it was done correctly. Beyond that, I have no idea what the question here is.
Posted on Jun 09, 2014
  • 32 Answers
SOURCE: batteries are charged disconnected and used seperate charger thet had 3/4 charge to start with push start button nothing wheels locked but when charger is plugged in controller lights light up showing
it sounds like dead cel in one of the batteries, try having batteries loaded tested.
Posted on Jul 13, 2009
gewiz
  • 1263 Answers
SOURCE: Blinking charge light on Invacare Zoom 300 scooter
Can you try another charger ?
Is it a onboard charger ? if so they do go wrong, Are they supply MK batteries ?
Check the leads from the charger connection socket to the motor controller board.
Regards
GeWiz.
Posted on Oct 06, 2009
dromtonpa
  • 40 Answers
SOURCE: oil / gel leak
If it is coming from your motors, it could be very bad. i.e. motor replacement. Sometimes on the side of those motors there is a black plastic cap about the size of a quarter or half dollar, those fall out sometimes and allow gearbox grease to come out. This should`nt be confused with your motor brush caps which are about the size of a pea and have a small **** in them for a screwdriver.DO NOT TAKE THESE OUT.  If the large cap has come out just stick it back in. If you can`t find it you`ll ned to call a dealer to get the part replaced.    If you can still find no prob,your probably going to have to go to a dealer.
Posted on Mar 26, 2009
  • 5 Answers
SOURCE: where is the reset button on a invacare m51
The controller puts out fault codes though the LEDs. Count them and then look in the operators manual for likely causes. In my experience it is the electronic brakes that fail on these units and they are costly.
Posted on Oct 16, 2009
  • 175 Answers
SOURCE: I have a invacare wheelchair pronto91 wont move 2
The three light flash indicates a short circuit between the left motor(as you are sitting in the chair)and the battery. Check all the wiring from the control box to the motor and make sure it is not damaged in any way. If it is okay, you have most likely fried the left side motor. A new motor-gearbox assembly for this chair runs in the neighborhood of $1,400.00, or you can take the motor off and take it in for a full rebuild for about $250 or so. Unplug the joystick and remove the seat and cowl. Jack up the left side with both motors in gear. Remove the center nut cover and take off the nut holding on the wheel taking care to retain the key that slides into the groove on the axle. Disconnect the wiring plug to the motor and remove the six bolts holding the motor to the frame. Separate the gearbox from the motor and take the motor to a rewind shop for repairs. Reinstall and it should be good to go.
Posted on Jan 08, 2010
Mobility scooter lights wont turn off
It really can only be one thing. Somewhere on your scooter is a switch for the lights. Try turning it off. If that doesn't work the switch is faulty
Nov 01, 2016 | Invacare Health & Beauty
Key flashing red on Invacare acs wheelchair controller
hi count the number of times it flashes and check youre owners manual for a fault code....try this site manual-Invacare www.invacare.com.au ...cheers
May 07, 2016 | Invacare Health & Beauty
My wife has an Invacare Auriga, it was not charged over winter, therefore batteries went flat. I bought 2 new batteries and fitted them, but when I switch the key on, the left hand light on the dash panel...
Check that you are not in freewheel. If you can push the scooter easily and the rear wheels roll then you are in freewheel. Move the lever to drive postion and turn the scooter on to see if that fixed the problem Hope this helps
May 05, 2011 | Health & Beauty
Where can i buy replacement carbon brushes for auriga 10 invacare scooter (6 mph model)
Since these are special made electric motors, you are going to have to go back to the dealer that sold you the machine and have them order the parts (brushes) for you. The PDF file for these scooters are found at:
http://www.invacare.co.nz/***/content/328/349/auriga-spare-parts-june2010.pdf
page 6 will give you the parts number.
If you are mechanically handy(I suppose so as you intend to replace brushes), then you may want to try a maintenance trick first of all. Generally these brushes are are not used up in a DC motor, but fail due to the carbon build up on the armanture of the motor shaft or the wear of the brushes have become so concave that they are making only slight contact on the armanture. If you can, pull the end off of the motor and lightly clean the armanture contact. Clean with some alcohol. Then examine the concave of the brushes, and using an emery board file the points of the arc in the brushes so that you change the deepness of the arc, bringing the center closer to the contact. re-assemble and test.
Jan 22, 2011 | Zoom 220 HMV 3-Wheel Travel Scooter
Have Invacare Auriga 4 scooter about 2yrs old Put into stores about 6 months ago was working fine battery's have always been on charge. Cannot get scooter to move. When I put de-clutching lever in to...
Hi. I have had a few scooters that have had this problem after sitting for a while. The brake lining is stuck to the body of the brake assembly. When the brake is energised by the controller, it can't release.
De-clutch the machine like you did, and try rocking the machine back and forth. If this doesn't work you might have to have a new brake assembly fitted.
The wheels turn in opposite directions, because the drive is through the differential unit in the rear axle. Even a car will do this if the driving axle is raised in the air.
I have also had a few cases of stuck motor brushes in these machines, but from your description, I would say it is the brake assembly.
Good luck. Neil.
Jun 13, 2010 | Health & Beauty
Invacare auriga looses power
Hi. Most probably its the throttle pot ( Wig Wag ) thats causing the problem. I am an Invacare service agent and I have changed these many times for this very reason.Also check motor brushes are not worn down or jaming. Good luck. Neil.
Mar 21, 2010 | Health & Beauty
My invacare auriga 3 wheel scooter will not work got 2 new batteries but will not power light flashing on charger as if charging but when put key in not even lights comne on
hi,
Can you clarifly what happens you plug in the charger in ?
Are you sure the fuses on the battery leads are okay ? the is one for each battery like a glass container ? check they have not blown, check the connections to the battery , are they tight ?
Regards
gewizrepairs.co.uk
Nov 14, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
