Question about Sony VPL-HS20 Multimedia Projector
Hi i turned off my sony vpl-hs20 projector and accidently pulled out the power plug while it was cooling down, now i get no power not even a standby light, please help.
Not sure how to fix.
Marrie
  • 563 Answers
SOURCE: SOny VPL-EX1 turns on for a few minutes and then the Lamp /Cover LED and Power ON/Standby LED flashes.
Hi David
I think you should replace the lamp.
Posted on Mar 26, 2008
  • 4234 Answers
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Posted on Apr 09, 2009
SOURCE: Sony VPL-DS100 will not turn on
I had same problem. The cause was a blown fuse (T5.0 Amp 250V). You have to open the case and then get below the print that is under the alloy cover. it is quite simple to fix. A fuse costs 60 cents.
Posted on Jun 15, 2009
BlackOnyx
  • 102 Answers
SOURCE: sony vpl-hs20 cineza projector- reset lamp counter
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Posted on Feb 06, 2010
  • 89 Answers
SOURCE: i purchased a new lamp
See http://www.avlamps.eu/projector-lamp-sony-vpl-cs6-_d9953.html for instruction how to reset the timer
Posted on Aug 10, 2010
Powering up
the projector is quite good and may not have any internal defect
may the bulb has really burnrd out......
try a new bulb if it works or not
Oct 15, 2008 | Sony VPL-HS20 Multimedia Projector
HOW DO YOU PUT THE SYSTEM IN STAND BY
Turn Power Off by pressing power button on projector, it is now in standby.
If projector is plugged in but not in power On mode or not showing picture, it calls standby.
Aug 27, 2010 | Sony VPL PX40 Multimedia Projector
Sony vpl-hs20 cineza projector- reset lamp counter
Jul 19, 2009 | Sony VPL-HS20 Multimedia Projector
How to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Jun 01, 2009 | Sony Office Equipment & Supplies
VPL-HS20 shuts down in the middle of a movie
There is a heat sensor cutting down the power. The sensor is located on the upper side between lamp and fan and is monitoring the air temperatur. I don't know what is causing the sensor to switch - excessive heat or simply age or ... . Anyway un screwed this sensor and my problem disappeared.
Possibly a stronger fan would solve the problem too.
Jun 26, 2008 | Sony VPL-HS20 Multimedia Projector
VPL-HS20 issues...who's got the right answers!
I know this post is 3yrs old, but wanted to add a couple things. I have the VPL-HS20, you can take the filter out and blow it out with air can duster every so often. I bought a new one and they are over $30.00.. Also buy the correct bulb LMP-H180 3000hrs if you replace it. You can clean the front lens protector, Remove slide tab, hold top and bottom of lens cover assembly and give a firm 1/4 twist clockwise, then pull out. You can clean it with glass cleaner cloth.
May 04, 2008 | Sony VPL-HS20 Multimedia Projector
Sony VPL-HS20 Multimedia Projector Logo
159 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
