Question about AOC 19" LED Monitor e950Swn Black
BOUNCING CHARACTERS/DISPLAY My e950Swn monitor display are bouncing it happened when I use Windows Media Center to Play a Video and a warning message appeared but I cannot read it. Is there a way to fix it?
  • AOC Master
  • 2,013 Answers
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Posted on May 28, 2014
Brother fax 236s My fax machine display cannot be seen when i look it directly. Characters can be seen lower and high positions. How do i adjust display contrast?
That's quite unusual. It should really be in reverse and it should be dark when looking directly and feint when at angles. I suspect you have a light in the room that is bouncing off the display. Try it in another room and I bet it will be ok. By the way there is no adjustment as its a low end unit.
Feb 08, 2015 | Brother Office Equipment & Supplies
I connected an external monitor to a lap top. The screen on the monitor is bouncing making all the print fuzzy and difficult to read.
Have you tried the same connection with another monitor? That will tell you if the cable or monitor is the problem. If the same thing happens with another monitor then its the computer input or system drivers.
Dec 31, 2013 | Computers & Internet
Cannot fit to screen size
You probably need to install a display driver for this monitor on your netbook. http://us.aoc.com/monitor_displays/e950swn
Dec 05, 2012 | AOC 19" LED Monitor e950Swn Black
Frequency out of range 11khz/ 119khz message
The PC is sending out the resolution that is too high for the monitor to handle, you need to set the resolution of the PC to be the native resolution of the monitor and set the refesh rate to be at 60Hz.
Jan 12, 2010 | Envision H191W Monitor
How do I rotate the screen when I rotate the Acer B203w
For Windows XP -- within the control panel, click on Display Icon and the following screen will appear. I have 2 monitors (Laptop and HP L1925 monitor). On the display properties screen, near the top of the screen, click on the “Settings” tab. When the “Settings” screen displays, select the “Advanced” button near the bottom of the screen.
The “Plug and Play Monitor …” screen will appear as shown below. From this screen, click on the “INTEL(R) Graphics Media Accelerator Driver for Mobile” tab near the top of the screen. Note: Tab stretches the full width of the screen.
The "Plug and Play Monitor ..." screen will change to show Intel Graphis Media Screen. From this screen click on the “Graphics Properties” button near the center of the screen.
The screen will change to show the graphics properties. Note, the screen actually comes up with “DISPLAY SETTING” selection (in dark Blue on the Left hand side of screen). To change Display settings click on the words “DISPLAY SETTINGS” (left side of screen) and the screen will switch to show Rotation options. On the top of the screen, select the “Monitor” you wish to change by clicking on “Monitor” button. Next make sure the “Enable Rotation” box is check on the right side of screen and then click on “90”. Your monitor should rotate at this point to portrait. A message will appear letting you confirm if you wish to keep this new setting. Specify yes to keep the new setting.
This should do the trick.
Joe Buus
Jan 29, 2009 | Computers & Internet
Using windows media XP warning comes up on screen-NO INPUT. Why?
update your video card driver or adjust your screen resolution and color bit
Dec 05, 2008 | Computers & Internet
Weird characters on monitor, cannot log-in
Well, either the monitor is messed up and trying to display a message like "No Signal" or the monitor is set for a different language.
What happens when you press the menu button on the monitor? Change you make changes?
Nov 18, 2008 | Computers & Internet
AOC 19" LED Monitor e950Swn Black Logo
61 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
