Question about Sharp AR-5316 Advanced Digital Imager Copier
Developer light on
The developer light and serviceman are on the desplay.Replaced developer. How do i clear them.
    Habit-Forming:
  • Sharp Expert
  • 190 Answers
'Service man:press # interupt and C interupt
enter 24 and then 01 for drum and then 42 then 01 for developer.
Posted on Jun 27, 2014
The master please help, error C0F30 minolta cspro ep 4000, what needs to be repaired or replaced or serviced, please help, thank ...
When was the last time the developer was replaced in the developer unit? If has been replaced, then you might have a bad ATDC (Automatic Toner Density Control) sensor Located right below the developer unit. If the developer was replaced when it was done was a vacuum cleaner used? IF so the static electricity from the vacuum clear destroyed the sensor, NEVER USE a VACUUM cleaner to remove the developer. Also when the developer was replaced, was counter cleared to tell the copier developer was replaced, the copier uses the counters to determine certain voltages for certain assemblies, if not image problems and codes can appear. Finally, was the F8 run after the developer was installed before ant prints or copies made? If not buy new developer and start over, counter is to be cleared first, then developer replaced, then F8 run.
Apr 28, 2017 | Minolta Office Equipment & Supplies
Mesin foto copi minolta cs pro ep 4000, setelah saya ganti sponge rol busa, toner tidak mau keuar melalui sponge rol dan keluar kode eror C0f030. mohon solusinya, thank
Apr 02, 2017 | Minolta Office Equipment & Supplies
Sir.mam,
Como solucionar el c2557 de la konica minolta 282
When was the last time the the drum and developer was replaced in the developer unit? If has been replaced, then you might have a bad ATDC (Automatic Toner Density Control) sensor Located right below the developer unit. If the developer was replaced when it was done was a vacuum cleaner used? IF so the static electricity from the vacuum clear destroyed the sensor, NEVER USE a VACUUM cleaner to remove the developer. Also when the developer was replaced, was counter cleared to tell the copier developer was replaced, the copier uses the counters to determine certain voltages for certain assemblies, if not image problems and codes can appear. Finally, was the F8 run after the developer was installed before ant prints or copies made? If not buy new developer and start over, counter is to be cleared first, then developer replaced, then F8 run.
Mar 28, 2017 | Konica Minolta Office Equipment & Supplies
C0f30 error minolta photo copy
When was the last time the developer was replaced in the developer unit? If it has been replaced then you might have a bad ATDC (Automatic Toner Density Control) sensor Located right below the developer unit. If the developer was replaced when it was done was a vacuum cleaner used? IF so the static electricity from the vacuum clear destroyed the sensor, NEVER USE a VACUUM cleaner to remove the developer. Also when the developer was replaced, was counter cleared to tell the copier developer was replaced, the copier use the counters to determine certain voltages for certain assemblies, if not image problems and codes can appear. Finally was the F8 run after the developer was installed before any prints or copies made? If not buy new developer and start over, counter is to be cleared first, then developer replaced, then F8 run.
Sep 29, 2014 | Konica Minolta Minolta Ep4000/ep5000...
Error code C2801 for Bizhub 750
When was the last time the developer was replaced in the developer unit? If has been replaced then you might have a bad ATDC (Automatic Toner Density Control) sensor Located at the rear of the drum and below. (Remove drum to see, has a white cover on it attached to a control board, needs cleaning,2nd replace. If the developer was replaced when it was done was a vacuum cleaner used? IF so the static electricity from the vacuum clear destroyed the sensor, NEVER USE a VACUUM cleaner to remove the developer. Also when the developer was replaced, was counter cleared to tell the copier developer was replaced, the copier use the counters to determine certain voltages for certain assemblies, if not image problems and codes can appear. Finally was the F8 run after the developer was installed before any prints or copies made? If not buy new developer and start over, counter is to be cleared first, then developer replaced, then F8 run.
May 21, 2014 | Konica Minolta Office Equipment & Supplies
I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Apr 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp copier sf 2530
Reset the developer by pressing C-CA-0-C - 83-5
May 16, 2008 | Office Equipment & Supplies
Adding developer to sharp sf-2025
Hi, it means the developer requires changing. it has a life of 30k (i think). I would suggest that if your quality is not effected, then keep using the machine, or spend the money on an engineer to come out and replace it.
Andy
Feb 28, 2008 | Sharp SF 2020 Copier
Display problem Imate jasjam pocket PC
There are many possibilities.
This forum has got a lot of info on HTC phones and Jasjam is made by HTC.
http://forum.xda-developers.com/showthread.php?t=303872
Hope it helps and sorry I can not be more specific as the issue is hardware related but to pinpoint the fault I need to have the phone on my workbench .
Aug 17, 2007 | i-mate JAM Pocket PC
Sharp AR-5316 Advanced Digital Imager Copier Logo
98 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
