Question about Garden
The recoil starter assembly has shattered on my gardentec chainsaw. can I purchase a new assembly?
The Gardentec chainsaw has a 45cm chain bar and a 52cc motor
  • Merch
    Merch Mar 27, 2014
    The start pawls have also broken and how do I replace them?
    Problem Solver:
  • 16 Answers
I'm not familiar with the model 'Gardentec' is it a Ryobi product?
In many cases now and especially on cheaper hobby saws the starter pawls are not available as individual items. However I'll explain the process of replacement.
Firstly, remove the starter housing and the plastic shield fitted to most saws between the starter pulley and flywheel. You will now have to remove the flywheel. The centre nut is a normal R/H thread but you will have to lock the piston first.
Remove the sparkplug and if a piston lock tool is not available then a length of starter rope will suffice, Turn the engine over by hand until the piston is opposite top dead centre (furtherest from sight) then push as much of the starter rope into the hole as you can. This will stop the crankshaft from turning when you undo the flywheel nut. Once the nut is undone your next step will be to remove the flywheel and they seldom slip off easily. In many cases a puller will be required but use caution or the flywheel will shatter. Do not hit the flywheel with a hammer or damage will occur. Light pressure can be applied at opposite sides of the flywheel by inserting two screwdrivers and lightly levering. Do not use too great a force.
If these process fail to produce results then you should seek the help of a chainsaw service shop.
Now once the flywheel has been removed you can turn it over and insert a pin punch to drift out the pawl pivot pins.
Reassembly is a lot easier.
Posted on Apr 19, 2014
3 Suggested Answers
  • 8 Answers
SOURCE: i have a gardentec 38cc
What kind of saw. How old? New Spark Plug? How old is the gas inside it? Is the air filter dirty? When you try to start it does it turn easy or is it a little stubborn or won't turn at all?
Posted on Mar 29, 2011
j_penny
SOURCE: I have a Gardentec 38
either chain has come off drive sprocket or clutch is knacked, --adjust chain to reset it on sprocket by loosening the two flange nuts on the blade bar side, or check clutc and or brake band is not stuck on
Posted on Nov 08, 2012
How do I change the spool on my gardentec strimmer
www.gardentec.cn/products.asp
Get a operating manual to find out how.
May 24, 2014 | Garden
Gardentec
http://www.gardentec.cn/upload/170-1.jpg
info@winplus-intl.com
I suggest you contact the above and ask where you can purchase the part,
May 14, 2014 | Garden
Where can i get gardentec chainsaw parts
GHS Limited have spares for all chinese chainsaws!
Nov 08, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Gardentec fly wheel pully springs
They can be found on Ebay. I have bought many parts for Huskys and other brands there. If not, try Amazon.
Mar 17, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I have a gardentec 38cc petrol chainsaw which wont start
Mar 29, 2011 | Garden
WeedEater Edger PE550 Starter Rope will not recoil
Order a new recoil spring from your suppier. It comes wound up. Remove the old part first usually four screws on the outside. Make sure the rope is fully wound then insert the new spring and reassamble. If it becomes unwound by mistake its a labourious job to rewind but can be done.
Aug 29, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How do you remove the recoil starter cover. I
which kind of chainsaw, make, model, how old?
Jul 09, 2009 | Garden
Chainsaw won't start
Time to get out your trusty tool kit. Remove the side cover assembly and look at the recoil assembly. You should see a pair of fingers that when you pull the cord move toward the center. If the fingers are there and not broken, make sure they move when you pull the cord. clean them if dirty or have foreign objects (like sawdust) around them. If the fingers are broken, replace them. You should be able to purchase them from your local saw shop.
Apr 18, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
121 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
