Question about Pool & Spa
Waterco brightstream led pool light is not working
Not lighting, it was working up until last week now nothing. traced the voltage from the transformer to the light fitting and it was getting 12v AC correctly but no light
  • 1 more comment
  • dr_kilt Mar 27, 2014
    There is no bulb, it's multiple surface mount LEDs!
  • Scott Corey-reid Mar 27, 2014
    turn power off to light. disconect both wires to back of the light. use a multimimeter set on OHMS. cvheck across both terminals. if theres no resistance then replace the led light
    also, ensure no water or moisture has entered the light. remove the light from the wall, inspect the water tight backing, and gaskets under the faceplate
    Champion:
  • 305 Answers
Check continuity of the bulb
Posted on Mar 25, 2014
3 Suggested Answers
  • 990 Answers
SOURCE: Raypak els1102 pool heater problem
Hard to saw from here, but I assume you have a book on this, find your hi limit switch, it will have a reset button on it. It will be behind a rubber plug on the housing but is hard to reset sometimes. If you pull the cover it is easy to reset and once you see it you will be able to do this with the cover on.
If not this some damage may have been done to the coil in the contactor, you should be able to see it pull in or at least hear it klunk when the heater kicks on.You probally won't be able to feel heat when it runs as it is designed to protect you from scalding when it runs but you should feel a slight difference in the temp of the water coming from the returns in the spa. good luck and let me know how it works out.
Posted on Nov 07, 2009
  • 760 Answers
SOURCE: pool heater is not working properly
So I assume you have pressed the button by pool to select the pool thermostat? If this doesn't work sounds like another mother board problem, or try powering down the unit a few minutes then restart. IF you haven't pressed the pool button, the read this: The heater comes factory set at 78° F. for the pool mode and 100° F. for the spa mode. If it's in spa mode it's trying to get to 100F. Using the up and down arrows,you can set the thermostats to a minimum temperature of 65° F., or a maximum of 104° F. If you desire to heat only one
body of water, the thermostat is capable of an off mode. As an example, if you only wish to heat the pool and not the spa simply depress and hold the spa down arrow, and the thermostat will lower its setting to 65° F. then go to an off mode. Here is a link to your manual :http://www.pentairpool.com/pdfs/MasterTempOM.pdf
Posted on Jul 08, 2010
My waterco portapac was fitted 3 months ago. worked beautifully until 2 days ago. Now it is not heating. Any ideas? Thanks
it has a pressure switch that is a common failure pump waterco portapac Google Search the switch looks like this in most cases and is a gravy fix waterco portapac Google Search now you can bypass it FOR TESTING ONLY ! to see if it is indeed the culprit, it's around a $20 part and nice to have on hand Also check to see if the pump has a restriction, like a plugged impeller, debris might got into the pump and restricted flow, causing a low pressure situation ? Australian Spa Parts
Dec 30, 2014 | Waterco Pool & Spa
Pool light not working
see if voltage at switch then to relay if 12 volt light check transformer if ok check to see if to light fixture check bulb first
Jan 12, 2014 | Waterco Pool & Spa
Water pump isin't working
if voltage to pump bad motor if no voltage bad switch or relay
Dec 21, 2013 | Waterco Pool & Spa
Waterco Aqua Heat Titane 101, The Fan Come On But Compressor Does Not KickIn?
make sure your filter is clean, heat pumps are fussy about too much back pressure. you might try it with the filter cartdrige renoved
Sep 21, 2013 | Waterco Baker Hydro 80K Btu Titanium...
Fan Runs But Compressor Does Not kick In Waterco Aqua Heat Titane 101
I had the same problem last week. I called a technician who found out that the capacitor was defective. Cost 50$ + the service call.
If the capacitor is working, it might be the compressor...
No LED light?
check voltage from wall then transformer voltage
Apr 24, 2012 | Pentair Control Board - 42002-0007s
Colorlogic Pool Light flashes like strobe
These swimming pool lights have a power-cycled feature. THis means that you can power down the light and then power back up in 10 seconds and the light pattern will change. It sounds like your light is not cycling properly. Power it down for a full 60 seconds. This will reset the power cycle. Then try turning it on and off in 10 second intervals. If it doesn't reset, you bulb may only be partially functioning and it may need to be replaces.
Jul 06, 2009 | Hayward 12v LED Color Logic Pool Light...
Pool & Spa Logo
118 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
