Question about Konica Minolta Copier Toner 7155 7165 950-564
Printer timed out - Konica Minolta Copier Toner 7155 7165 950-564
  • Konica Minolta Master
  • 6,161 Answers
Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN Developer procedures. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Posted on Jan 14, 2016
Reset canon printer MP500
The reset method for Canon Pixma MP500 All-In-One Photo Printer
1. Entering into Service Mode
  1. Start with printer connected to power cord (electric source)
  2. Press and hold STOP/RESET button.
  3. Press and hold POWER button.
  4. Release STOP/RESET button without releasing power button.
  5. Click STOP/RESET two times and then release power button.
2. Reset the Canon Pixma MP500 All-In-One Photo Printer
  • After the printer entering into service mode, prepare paper on the printer paper tray
  • Press Stop/reset button for 1 times and then press power button, await till printer finished print.
  • Press Stop/reset button for 2 times and then press power button, The printer will print again. Await till printer finished print again.
  • Press Stop/reset button for 3 times then press power button to reset EEPROM.
  • Press Stop/reset button for 4 times then press power button to reset Waste Ink Counter.
  • Switch off the printer. if printer doesn't turn off, press button power until printer off
Jul 26, 2014 | Canon Pixma MP500 All-In-One InkJet...
I have a conon pixma mp198 error 27
ink absorber is full is canon error code E27. Try doing this steps to help you fix this problem.
Unplug the power cord then Press and hold down the Stop / Reset. After that Insert the power cable
and Press and hold down the power button (the button Stop / Reset fixed in press), When pressing the Power button, then release the button Stop / Reset. Press the Stop / Reset 2 times then release the Power button."Wait until the digit 0 appears in the display"
> Push down the Stop / Reset 1 time.
> Push down the Power button 1 time, the printer will print a sheet of paper.
> Press the Stop / Reset 2 times.
> Press the Power button 1 time, the printer will mecetak a sheet of paper
> Press the Stop / Reset 3 times.
> Press the Power button 1 time. (No printing)
> Press the Stop / Reset 4 times
> Press the Power button 1 time rather long and loose (to turn off the printers).
"If the printer still can not get turned off, unplug the printer power."
> Turn on the printer.
> E27 error message is gone & the printer is running normally.
Nov 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Error code E27, ink absorber is full. Call service.
Follow these steps :
1. Unplug the power cord
2. Press and hold down the Stop / Reset.
3. Insert the power cable
4. Press and hold down the power button (the button Stop / Reset fixed in press)
5. When pressing the Power button, then release the button Stop / Reset.
6. Press the Stop / Reset 2 times then release the Power button.
7. Press the Stop / Reset 1 time.
8. Press the Power button 1 time, the printer will print a sheet of paper.
9. Press the Stop / Reset 2 times.
10. Press the Power button 1 time, the printer will mecetak a sheet of paper
11. Press the Stop / Reset 3 times.
12. Press the Power button 1 time. (No printing)
13. Press the Stop / Reset 4 times
14. Press the Power button 1 time rather long and loose (to turn off the printers).
15. Turn on the printer.
16. E27 error message is gone & the printer is running normally.
Oct 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Changed ink, cleaned cartridge area, turned printer on and off, still have an error code 1203. what is my next step?
Hi there can only try and I hope it will do the job for you.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
Reset Factory Defaults on the Dell™ 962 Printer
To reset factory defaults on the printer, perform the following steps:
  1. Press the Mode button several times until the Copy LED is lit.
  2. Press the Menu button until Set Defaults is displayed, then press the Select button.
  3. Press the right arrow button until Restore Factory Defaults is displayed, then press the Select button. The printer will ask for the date, time and language.
  4. Enter the time, date and language, the press the Select button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 15, 2010 | Dell 962 Photo All-In-One InkJet Printer
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
Will the printer become damaged because repeated error message?
Do a EEPROM initialization:
Service Mode
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 26, 2009 | Canon PIXMA iP1600 Printer
Installation of printer
is ok, i don need to install this printer again... give to my friend already .. thank you
Dec 27, 2008 | Lexmark JetPrinter Z25 InkJet Color...
Setting the time
On my 6310 all in one printer ------> Hit "Setup" key (with the question mark next to it >> Select Tools (menu item 6) with OK button >> Date and Time (menu item 3) with OK button.
Then set the date and time using the keypad on the printer and the ok button. Either the arrow keys or the setup button move through the various menu options.
Nov 05, 2008 | HP Officejet 6310 All-In-One InkJet...
Canon BJC 85 printer
PRINTER BEEPS (5) TIMES, ERRORS
Nov 29, 2007 | Canon BJC-85 InkJet Printer
Error e5
Isnt e5 error meaning the cartridge has been previously used before?? Best bet is to hold in both the colour and black copy buttons for about 5 - 10 seconds and this should allow you to print again. If you do not have a copier/scanner, hold in the resume button. (triangle within a circle).
Sep 11, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Konica Minolta Copier Toner 7155 7165 950-564 Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
