Question about Sharp AL-1217 Copier
Drum error how to Sharp AL-1217 drum reset
ginko
  • 19396 Answers
SOURCE: I WANT SHARP AL-1217 COPIER DRIVER
Click here to open the download page, enter "AL-1217" in Product Code box.
Note AL-1217 does not have Vista drivers.
Posted on Feb 09, 2009
SOURCE: My Sharp AL-1217 keeps flashing H4 and does not respond
This is a typical fuser lamp issue. This is usually caused by a fluctuation in current supplied to the fuser assembly when the copier is warming up.
This cannot be solved by powering off the unit nor by unplugging it!
Follow the simple steps below to correct the issue:
  1. Power on the unit.
  2. When the LED display starts flashing "H" and "4", Press C and Auto button(this is the leftmost button with the copier console facing you)
  3. Repress the C and Auto Buttons again
  4. Press the copies button until 14 appears on the LED.
  5. Then Press the BIG Blue COPY button(the rightmost button with the copier console facing you)
Hurray, that's all folks
Posted on Mar 27, 2009
Sharp Tech
  • 63 Answers
SOURCE: how can i reset the drum on al 800 sharpgrayscale
You should have on the right side of the display panel a "C" key and on the far left side your "light" exposure key.
Press c-exposure-c-exposure the scree should go blank. using your key pad make the display show 24 then press your copy key. then make it show 7 the press your copy key. Press the C or CA key until the copier resets. The light should have gone off.
Posted on Oct 15, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Reset drum counter on Sharp AL-1644
This works on MOST sharp AL series copiers.
Press these keys in sequence:
Clear → Density select → Clear→ Density select
display should go blank. Then enter:
24 as if you were making 24 copies then press print
then enter 7 as if you were making 7 copies then press print
if successful you should see flashing 000
turn machine off then on again and the drum light should be gone.
Good Luck
Posted on Nov 03, 2009
Testimonial: "Fantastic! The code for the Sharp AL-1644 drum reset worked like a dream! Thank you."
wheatlandsvc
  • 1110 Answers
SOURCE: sharp al-1631 copier. drum error code
You can reset this indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
Posted on Nov 16, 2009
Testimonial: "Ok sorry thank u. I am new sorry i will be better in the future."
How to reset sharp al 1217 h4
it is probly the thermistors in the fuser unit. in most cases you just replace the whole fuser unit.
Dec 20, 2014 | Sharp AL-1217 Copier
Old model AL-1217 photocopier giving error reading of L? Any thoughts, tried everything! Thanks
L1 mean scanner is not goes home position,
Solve: Clean all surface then solve your problem
Feb 06, 2010 | Sharp AL-1217 Copier
Sharp AL-1217 Driver for Windows Vista
try the driver for AR123E at
http://www.sumthai.com/s0104/index.php?tpid=0086&pageno=1
it covers
Supported Models AR-123E, AL1045, AL1216, AL1225, AL1255, AL1530CS, AL1540CS, AL1456
Aug 21, 2009 | Sharp AL-1217 Copier
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
My sharp AL-1217 greets me with a flashing "L1" error
try to clean the scanner glass, it has a white stripe at the home position of the scanner optics, clean it well.
Jul 28, 2008 | Sharp AL-1217 Copier
AL 1217 noise when started
hi first u check with out drum and toner unit. that time also u getting noise u check main drive assembly and fuser assembly.
Jun 24, 2008 | Sharp AL-1217 Copier
Sharp al1217
I've never seen this model in Australia but could you confirm if its drum or toner either way its just the machine letting you know that it needs changing soon, however we have other models that do the same and run for quite a while before the quality drops off
Mar 18, 2008 | Sharp AL-1217 Copier
Sharp AL-1217
It sounds like its either the wrong cartridge or the actual crum chip on the cartridge is faulty
Mar 14, 2008 | Sharp AL-1217 Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
