Question about Mustek Televison & Video
Won't turn on
My mp76b won't turn on without electric power eventhough the battery is fully charged
SOURCE: it won't turn on, bt the battery still charging
Another way I've found to do this is to press the power button and reset button at the same time. Then when you get the message to clear all data press cancel. I get this every time I re-charge my axim in the cradle. Doesn't anyone have a better solution? When it happens I have to reset my time. It's usually a day behind.
Posted on Jan 18, 2008
  • 13 Answers
SOURCE: battery is fully charged checked with meter. once
Sorry to say, yes, anything with a kid trax or safety 1st battery has a problem. Go to www.cammhsm.com and you can find some help. I know, I have one.
Posted on Jun 30, 2010
HansPP
  • 2510 Answers
SOURCE: Have a Dyson DC16 -
After two years the batteries are probably no longer holding a charge and need to be replaced.
Posted on Feb 14, 2011
allsmalleng
  • 15 Answers
SOURCE: Even with a fully charged
Here is a test you can do.. Follow the thick red cable from the battery to what is call a solenoid you will see two rods with the red wire from the batter going to it and a red wire going to the starter leaving it.. Take a screw driver and connect the metal rod to each other make sure you are touching the rubber handle of the screw driver you will see sparks because you are connecting the batter power to the starter.. if the engine turns over then you need to replace the solendoid that is your problem.. you pick them up at any auto store. If that doesnt work please let me know thanks..
Posted on Jul 16, 2011
t00nz
  • 4738 Answers
SOURCE: Canon powershot SD1300 IS won't turn on, even
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Posted on Oct 11, 2011
MY QUESTION IS ABOUT BATTERY POWERED ELECTRIC SCOOTERS. WHY IS IT THAT i AM NOT GETTING NOWHERE NEAR THE RANGE that I am getting from a fully charge scooter.
Sounds like either the battery or charger is not working properly. If the machine has been sitting around for a long time without charging the battery then the battery may not hold a full charge, I would pull the batteries and have them checked out and see if they are charging up to snuff. Fully charge them before you get them tested. There should be no charge to check them.
Oct 03, 2017 | Electric Health & Beauty
Power light flashing amber
Follow the steps given below. (Please be careful when handling computer electrical components like batteries and AC Adapters)
  • Remove the battery and hold down the power button for few seconds (to drain all remaining power)
  • Power up the computer without the battery with the A/C adapter plugged in.
  • Wait for few seconds and plug the battery back in
After a few tries the computer should start charging normally. The amber battery stops blinking and turn green when fully charged.
Feb 13, 2015 | Acer Aspire One Kav10 Netbook
Have the STX Vipor electric car. Fully charged but won't go, just hear clicking noise.
If this was a real car this could be anything from anti-theft to a blown battery. Being as its a power wheels it would probably be the battery is ruined because it was charged sitting on concrete bare. Which will quickly destroy a battery. You may have to buy a new battery. The only other thing I can think of to check is if the motor is ruined powering the wheels. Which will be a much more expensive fix. Hope this helps:)
Sep 20, 2012 | Fisher Price Power Wheels Rechargeable...
Have a Toro Personal Pace 190 cc electric start mower. About 18 months old. Battery can be fully charged but it only seems to start it about every third or fourth time. Pulling the cord starts it every...
battery or cable problems
When using the battery , there is insufficient power left to run the ignition system
when pull starting what is in the battery is sufficient to start the engine
Feb 20, 2018 | Toro Lawn Mower With Toro Power Tools
The window is suddenly shutting down everytime i open it, eventhough it is fully charged?
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Aug 25, 2011 | HP Pavilion dv6000z Notebook
I had not used the chair in 2 months, when i charged the battery in my electric wheelchair, the lights near the top of the joy stick shows its fully charge, but when i unplug the cord, it go's...
Yep It sure does Why didn't you charge the chair for 2 months? Charge at least once a week if you don't use it daily. Always break in the new batteries by using the chair daily for 10-15 days charging everynite then charge once a week if it sits for that long without use. Always put up fully charged. Do this and your batteries should last 3 -4 years Charge overnite if you use daily and never charge more than 24 hours Good Luck
Nov 15, 2010 | Electric Jazzy 1115 Power Wheelchair
IBM Thinkpad T22 Battery
pls first check your adapter may be problem with your adapter.
thank you
Sep 28, 2008 | IBM ThinkPad T22 2647 Notebook
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Televison & Video Logo
Top Mustek Televison & Video Experts
Tom Chichester
richie46
Are you a Mustek Televison and Video Expert? Answer questions, earn points and help others
