Question about Samsung Galaxy S 4G Cell Phone
Safe mode is on how do I turn it off
Don't know
    Producer:
    Uploaded 30 video answers.
  • Samsung Expert
  • 309 Answers
Let's start with the most common Hard Reset methods and go from there:
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap the Power button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Posted on Jul 04, 2014
Take computer out of safe mode
To get your PC out of the Safe-mode just simply Restart it :).
If that is not working, then restart, before the Windows logo apears keep pressing F8 and use the Normal boot.
Hope this has helped you :)!
If not please reply or send me an e-mail to tomas.and.jueros@outlook.com
Feb 27, 2013 | Microsoft Windows 7 Home Premium 64BIT...
My Toshiba Satellite L305 does not complete the boot process following the latest Windows updates. I get only to a black screen. Any suggestions?
I suggest that you do a system restore via safe mode.
If you don't how to go to safe mode, please follow the following steps:
1. Turn on your computer and tap F8. Keep tapping until you see the screen where you can find the option to go to safe mode.
2. Highlight safe mode and press enter.
3. when you are inside safe mode, do a system restore to the date when it was still working fine. It should work.
I hope this helps.
Carlo Adrian Canon
Nov 14, 2012 | Toshiba Satellite L305 (883974223084) PC...
Don't know HDD #1/SSD #1USER PASSWORD ON MY TOSHIBA
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Oct 03, 2012 | Toshiba Satellite L455S5980 Notebook
Mouse has gone crazy,you click on arrow and it will keep on clicking,it start draging while crossing web page,it highlite every thing blue
Try booting up in safe mode then Restore your system back to a date and time before you came across that web page and started having problems.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.Click Start/Programs/Accessories/System Tools/System Restore
Select a Restore Point (date and time) that is before you started having problems. You don't have to use the restore point that is shown just select option to see more restore points.When System Restore finishes, reboot your computer.Report back and let us know if it is solved or not.
May 03, 2012 | Dell Inspiron 1521 Laptop
Keyboard for lenovo R500 laptop not working
What do you mean not working? Is it that certain keys don't work, or the whole keyboard does not work?
Maybe your keyboard has been hijacked by a virus. Have you tried booting up in Safe Mode to see if it works?
Turn off the computer, then hit the power buttonto turn it back on and immediately start hitting the F8 key repeatedly untilyou see SAFE MODE. Take the Safe Mode option and let it boot up. SafeMode will look different to you, the screen will be darker and the iconsbigger, this is normal
Apr 03, 2012 | Computers & Internet
How do you get to safe mode for toshiba
Debra,
There are a couple of methods to get to Safe Mode on a PC.
The first and established method of getting Safe Mode to pull up is to turn the computer off all of the way. Then turn the computer back on and immediately start tapping the F8 key on the keyboard. (Don't hold the key down, but instead press it over and over.) This should bring you to a Safe Mode menu to choose which option to boot into.
If you have pressed the F8 key and the computer still attempts to boot to regular windows, you can press and hold in the power button to turn the computer off and retry the F8 option.
The other, less established method of forcing a computer into safe mode is to turn the computer on, wait until you see the Windows logo start to load, and then press and hold in the power button to force a shutdown. Doing this twice in a row should result in the safe mode prompt on the third boot up attempt.
Hope this info helps!
Nov 30, 2011 | Toshiba Computers & Internet
When I turn on my Dell Latitude D600 PC, the windows xp loading page appears. After it has loaded the screen turns black and does not make any further progress.
It appears that your display works fine until Windows XP loads. Try tapping the key when powering on the laptop. Select boot in safe mode and see if the laptop works.Here's a description of safe mode by Microsoft.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
If your display works in safe mode then you have a video driver issue or virus or software issue.
Jun 20, 2011 | Dell Latitude D600 Notebook
How do I turn off safe mode on Mozilla
Want to turn off Safe mode option on your Mozilla Firefox? Then follow this simple steps:
  1. Open Mozilla Firefox
  2. At the top of it (Firefox window), click on the Firefox button (in you have Windows Xp, click on File menu) and then click Exit.
  3. Start Firefox as you normally would.
  4. If Firefox keeps starting in Safe Mode see Firefox is stuck in Safe Mode.
If your Mozilla Browser is stuck on safe mode better to the steps here: Click here
May 16, 2011 | RCA VR702HF VCR
Clicking on any web site, I will be re-directed somewhere else and sometimes it will bring an error that I don't have an internet connection when I know I do. Could this a netgear wireless router issue or...
Hi, I can suggest you to try going online using your neighbour's wireless connection. So you can easily find out whether its the issue with the internet service provider or anything wrong with the browser.
However please try going online in safe mode with networking.
Turn on your computer and start tapping the key "F8". You will get screen that says safe mode, safe mode with networking. Use your down arrow key and highlight the "safe mode with networking" , then hit enter. It'll take you to the safe mode (where few features in the normal mode will be disabled). Here try going online, If you don face the issue here it could be a virus thats blocking.
Please vote this solution if you think this might help others:) Thank you
Please let me know if you need more help:)
Nov 04, 2010 | NetGear RangeMax WPN824 Router
Stuck in windows error recovery window
to get into safe mode, turn on your computer and press F8 immediately. Press the F8 constantly, till the safe mode booting option will come up.
Pressing F8, is the sure way of make your computer enter into safe mode.
Good luck.
Apr 16, 2010 | Dell Dimension 4600 PC Desktop
Samsung Galaxy S 4G Cell Phone Logo
117 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
