Question about Lexmark E Office Equipment & Supplies
Toner leak E260 - E Lexmark Office Equipment & Supplies
How to reset lexmark e260 chip
Go to any website that sells bulk ink and toner refills. They have chip resetters. You need to do this every time you refill . It cannot be bypassed.
Jan 24, 2014 | Lexmark E260 Laser Printer
When I print a page black lines appear on the page making. Its like the toner is leaking or something. I don't know how to fix this issue. I've cleaned the inside of the printer several times and...
The toner is leaking. The toner cartridge has two compartments, one for new toner & another for waste toner. When the waste toner compartment is becoming full to its capacity it starts throwing extra toner outside of it. That is what is called toner leaking. If you can empty the contents of the waste toner compartment, your problem will be solved. One more thing if wiping blade for waste toner is worn out, it also leads to toner leaking.
Aug 02, 2011 | Samsung ML 2151N Laser Printer
The toner light has been flashing. I have now put in a new toner cartridge and my amber light is still blinking
Please reset the pc count on your printer. Please click on the link below for the steps. http://bitly.com/r8ZhYJ
If you need further assistance, please contact Lexmark Technical Support Center.
Mar 30, 2011 | Lexmark E260 Laser Printer
Hi i wana ti refill toner powder but dont know how is.please help me. thanks. Ahmad
Please view the following video for Lexmark E260 Toner Refilling
Hope it helps! Good Luck!
CreativeTECH
Mar 10, 2011 | Lexmark E260 Laser Printer
E260 TONER RESET
When you say "toner reset", are you referring to removing and reinstalling the toner? Please provide us more information.
For further assistance, please contact Lexmark Technical Support.
Feb 03, 2011 | Lexmark E260dn Laser Printer
How to refill lexmark e260 cartridge
I would not recommending trying to refill a laser cartridge. This toner powder is very fine and you do not want to breath in this powder.
I suggest you purchase a re-manufactured toner cartridge for your model printer. These are cheaper than the new toner cartridges.
Oct 28, 2010 | Lexmark E260 Laser Printer
My T650n is leaking toner on pages I am printing. Using Lexmark branded recycled by Lexmark toer cartridges and about 2/3 are having this leaking problem. It is getting expensive. Is this a well know issue...
toner cartridges do leak but not all of them. are you getting toner build up inside the printer cavity? can you see where it is leaking visually looking at the toner? toners usually leak around the drive gears. if your fuser is not running hot enough the printer will get incomplete fusing and the toner will build up on the fuser rollers then make blotches on the print jobs. take a flashlight and check the rollers on the fuser to see if they have any build up on them. when toners start to leak they usually leave toner on every page.
Jul 03, 2010 | Lexmark T650n Laser Printer
Vertical lines
take out your toner , and shake it well then try it, if its ok, order new toner
Jun 17, 2010 | Lexmark E260 Laser Printer
Toner on the side of paper when copying
If you are using refilled toner cartridges then your toner cartridge may be leaking or the waste toner tank on the toner cartridge may be leaking. The other cause and more likely is the drum cartridge is leaking toner. I would recommend removing both cartridges. Then hold each 1 at a time over several sheets of clean white paper. Tap on the cartridges and see if any toner falls out of them. These cartridges are normally sealed and should not leak much if any toner. If toner falls out of either cartridge you will need to replace that cartridge.
Good Luck and Thank You for using Fixya.
Mar 27, 2010 | Sharp AL 1631 Copier
Toner Leaking
are the new ones original toners ? if not, then you have to buy a new original or working toners, because, its not recomended to refill toners, but if you want, then you can refill them only about 1-2 times.
Jan 31, 2008 | Konica Minolta magicolor 2400 Laser...
60 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
