Question about Makita BMR100 Radio
Can't adjust bass on my radio
I can't find a setting to adjust the bass is there an quilizer?
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
How do you take off the bass on a pioneer radio?
Go to your audio settings and you should see bass and treble adjustments or google your make and model of stereo and look at the manual online...
Mar 26, 2012 | Pioneer Car Audio & Video
Just brought the kenwood dpx u5120 car radio and the manual is not in English, just wondering if u can send me a English version or just steps to setting the clock?
To adjust the clock. All you do is hold down the bass boost button untill the clock flashes, then use the volume button to adjust the time and the forward and reverse buttons to switch between minutes and hours. When your finished setting the time just press the bass boost button again to finish.
Jun 19, 2011 | Car Audio & Video
I am trying to adjust the bass and treble in the bass focus and t-adjust but it keeps reseting.I don't have the manual and I would like to know how to lock the settings in so I don't have to keep on...
If they reset when you turn off the radio (or the car) it is possible that you have connected the power wiring wrong. There are two 12v (+) wires. One that connects all the time to the power block (fuse block) and that one supplies continuous power to the radio unit and another that connects to the ON-OFF (ussually controlled by the Start Up Key) power side of the fuse block. If these are not connected correctly the radio re-sets everytime the key is turned of. One way to verify this is to check if yo loose your selected raio stations too.
Hope it helps.
Nov 04, 2010 | Alpine CDA-9813 CD Player
this is kinda vague i hope this helps! first turn the equlizer to flat make sure eveything is equal. then turn he volume about 3/4 of the way up. this is around the point where th radiostartsto send distortion to the speakers (the easiest way to blow speakers) . thenstartwith the bass. eeryones ears are different i usually tue the bass to a notch or so below half ao if the radio ges to +12 i wouldput it on 4 or 5. next the mids are usully set at about +2 or 3. then thetrebbel is set a hairhigher than the bass. make this your maximum listenig volume so you dong damage the speakers. Hope this helped! let me know
Sep 15, 2010 | JVC Car Audio & Video
I have an amp powering two subs but only work with the radio and not when its in aux mode or cd mode. do i need some other conection
I am not familiar with your head unit but I know some radios can control audio options for each source. My unit has adjustments for bass treble fade sub out etc in each source like radio, dvd, cd usb etc. I would check this first. For example, my radio can have the bass set to zero while the dvd can have the bass set to 5. If this is the case for your stereo, the sub out for the different sources can still be set to off.
Feb 22, 2010 | Alpine CDA-9851 CD Player
Amp slow to kick bass in.
it sounds like you havnt got the memory live conected on your hea duit or it is conected to an ignition live this is no good it needs to be conected to a permenent live to ensure the memory has power at all ties of it coulb be that the amp needs adjusting for low volume use
to set up a sub you turn up the volume to the required level then adjust the amp acordingly hope this helps ben
Oct 11, 2009 | Alpine MRP-M650 Car Audio Amplifier
JL 13w7 & 1000/1 Settings
There is no "perfect" setting that can be placed in a manual. It's all done by ear. Your settings will vary depending on the vehicle you are in, the type of enclosure you have, the type of music you listen too, how much voltage your deck put's out. There are many variables, but I can try to give you a basic guide.
First of all you need to know your enclosure. If you have a ported enclosure tuned in the mid to low 30's you may want to set the low pass to around 70-80 hz with your sub sonic set at 30 hz. this will give you the higher bass frequency you need for the loud bass you want, and protect the sub from going too far below the tuned frequency of the enclosure, and losing it's composure.
As far as the gain, and bass boost are concerned, you just have to adjust them by ear. First adjust the radio volume to normal listening levels, by that I mean as loud as it can go without the speakers in the car sounding like ****. Now you adjust the gain first. slow turn the gain control, carefuly watching and listening to the sub.. Adjust the gain to the point of the woofer getting a lil sloppy then back it down a bit until the sound is clean again. Now do the same with the bass boost. if there is a bass boost frequency adjustment, set that as close to the tuned frequency of the box as you can.
If you are in a sealed box the adjustments are a bit easier, and are all about taste. Adjust the radio as described before, and put on your favorite song. Next start udjust thing lowpass frequency to taste, not too high tho, try not us higher than 100 hz in your sub's for better sound. Sub sonic is not quite as important in a sealed box, as there is much less danger of the sub losing control.
Well good luck, and hope this helps!
Jul 13, 2009 | Jl Audio 13W7 Car Subwoofer
How the heck do I adjust the radio sounds (Bass/Treble)??
in newer sound systems they usually have an button that says audio with push of the button it should give you options of adjusting balance fade bass treble etc.
Aug 27, 2008 | 1999 Porsche Boxster
Cannot Set the Treble & Bass
I have an Alpine 9887 you have a different eq than just trebel and bass the only way to get you bass an trebel setings are to install the imprint stoftware now if thats the route you go it tunes your radio to what it thinks it should sound like it's for sound quality not for alot of bass been there done that I have the software but you need to take it to a good alpine dealer to have it installed good luck
Jan 05, 2008 | Alpine CDA-9887 CD Player
Makita BMR100 Radio Logo
Top Makita Audio Players & Recorders Experts
Gil Shultz
Are you a Makita Audio Player and Recorder Expert? Answer questions, earn points and help others
