Question about Ice Cream Makers
Philips hr 2298
Zijn daar nog losse onderdelen van te bestellen?
Brush Cleaning did not clear the (L / R) HPR> 45F (7C) AFTER 1 HR fault on my Taylor Model C723 soft serve ice cream freezer.
Certain conditions must be met. The machine needs to be empty. The freezer door must be off the machine. The power switch must be off. Once the machine is off, a 5 minute countdown will show. It will also show 4 temperature readings. All 4 of them must be above 60 degrees F. before the countdown will start. Once the counter reaches zero, the Brush Clean Cycle will be reset along with any temperature vs. time error codes. If at any time, one of the temp readings drop below 60 degrees F. before the end of the 5 minute countdown, the countdown will reset to 5 minutes and the machine will not reset. Generally, the freezing cylinders take longer to come to temperature. Even when you run warm water through it first, there is sometimes enough residual cold to bring the temperature back below 60. A successful Brush clean Cycle will display "Power Switch Off---Unit Cleaned" and the 2 digit green display under the main display will reset to 00. if this happens and you turn the machine back on and you are hit with the same message then you may have an issue with one of your boards.
Aug 02, 2017 | Taylor Ice Cream Makers
Replacement parts for philips ice cream maker 2302
The only ice-cream maker on Philips website is the HR 2304 - the replacement cooling block for this is HR3936/01.
See on this webpage:
http://www.philips-shop.co.uk/store/catalog/household-accessories/ice-cream-maker-accessories/-/productdetail/HR3936_01_GB_SHOPPUB/GB/en?active_tab=overview#productDetailtabs
Not sure if this will fit yours?
Otherwise explore the Philips website for contact/support.
Feb 21, 2013 | Ice Cream Makers
Het koelelement van onze Girmi type GL14 is kapot. kunnen we dit apart verkrijgen?
Ik heb hier nog een volledig nieuw toestel staan, dat ik evt. wens te verkopen. Indien interesse, tel. GSM 0499/713896.
Apr 13, 2011 | Girmi GL14 Gran Gelato 1 Quart Ice Cream...
Instructions for coffeemaker cuisinart DC1200 need to know how to set the automatic time for cooffemaker
Turn dial to PROG
Press and release HR button a few times - it will have a "PM" on the display if it is set for PM
Press and release MIN button until minutes are set
Once the time you want it to go off is selected, turn the function knob to AUTO-ON - flick the switch to ON - a green light will now illuminate and you are ready to go (don't forget to put water in the reservoir and coffee in the filter basket)
Sep 24, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Please find me the manual for philips ice cream maker 2303/1and not pdf please microsoft word thanks
Go to www.filehippo.com download Adobe Reader
Then you can read any .pdf files that are posted for you
None of the makers use Word
Jun 24, 2009 | Deni / 5201 / 5202 / 5203 / 5205 Ice Cream...
Euro cuisine yogurt maker- no instruction booklet
1. Pour 7 glass jars (42 oz total) of fresh pasteurized milk (whole or skimmed) into a high-sided saucepan.
2. Heat the milk until it boils (203F) and starts to climb to the side of the saucepan. Boiling will make the yogurt firmer,
3. Remove the pan from heat and allow the milk to cool to room temperature (95F)
4. Strain the milk into a pitcher
5. Stir in 1 glass (6oz) of natural yogurt with some of the strained milk in a separate bowl until the yogurt is dissolved and you have a smooth mixture (Freeze-dried Yogurt Starter can be used here as well).
6. Mix the room temperature milk very well with the smooth mixture as prepared above
7. Pour the mixture into the seven jars, and place the jars - without the lids - in the yogurt maker
8. Cover the yogurt maker with the clear cover.
9. Plug into the power outlet and let it sit still for 6 hr (whole milk) or 8 hr (skimmed milk)
10. Unplug when the time is up. Remove the jars, put the lids on, and refrigerate at least 3 hrs
Apr 22, 2008 | Ice Cream Makers
Help me find the english user manual
http://www.p4c.philips.com/files/h/hr2303_10/hr2303_10_dfu_eng.pdf
This is the manual for the 2303, which is the same thing as the 2302.
Dec 04, 2007 | Ice Cream Makers
Ice Cream Makers Logo
49 people viewed this question
Top Ice Cream Makers Experts
ray gallant
Ruth summersides
Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
