Question about TP-LINK Computers & Internet
Admin password not working
I want to change my password but there is no details
2 Suggested Answers
  • 1543 Answers
SOURCE: How to rightfully, reset an admin's password at start up log in.
If you know the current administrator password, you can change it by going to System Preferences: Accounts.
If you've lost the password, you need Disk 1 of the OS install disk set. Start up the computer and put the disk in the optical drive. Restart the computer and hold down the option key immediately after the chime until a disk icon appears on the display. Wait a few seconds more until the optical disk icon appears. Click on this, then on the arrow to boot up from the install disk.
When the OS installer appears, go to the Reset Password... item in the Apple menu and follow the directions there. (Select the administrator account from the pull-down menu.) If your install disk is not specifically for an eMac, or is made for an eMac with a different graphics chip, the display quality may be poor, but you should still be able to pick out what you need to see from the Password applet.
Posted on Jun 27, 2013
Cannot remember router password to connect iphone Can you help?
Access your wireless configuration by going to your browser and typing in the address bar
192.168.1.1 (unless you have changed your LAN IP then use that)
on the login screen put in the admin details(if you don't know look at the bottom of your router it has the info, it is usually admin:admin)
Go to Wireless settings and change the WPA2 or WEP Key to whatever you want.
Access iPhone with newly changed password.
Have fun :)
Aug 14, 2011 | NetGear DGN2000 Wireless Router
How to change the password of our router?
login it's web-based configuration utility (192.168.0.1)
the default username and password are admin and admin
you can change whatever you want from there.
This is your user manual for further details:
good luck
Jul 27, 2011 | Encore ENHWIN3 Wireless Router
Can't find my wep key or admin password
If you have forgotten both you will need to restore your router to factory settings and re-add your internet details ***NOTE*** you will most likely have to contact your ISP for your account details so you can add your net details.
To restore there is a small pin hole on the back of the router with reset below it push and hold for 30secs this will revert your router back to original settings and change your login details to username: admin & password: admin. You will now need to run the setup wizard to setup your router and internet details which will allow you to input a new wep key.
Once done you will need to re-connect each device on your network with new details.
Hope it helps.
Thanks.
Nov 27, 2010 | SMC Barricade g SMC2804WBR Wireless Router
How do i find my ssid?
You need to log in to the router. You can do this by opening up your web browser and in the address bar type:
http://192.168.0.1
You will then be prompted for your username and password. If you have not previously changed this password then the login details should be as follows:
username:
password: admin
If this doesn't work try:
username: admin
password: admin
If this still fails you can reset the router back to the factory settings by taking a paper clip, and pushing it in the reset button for 10-15 seconds. Then restart the computer and configure your new password settings in the router.
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
Oct 20, 2010 | Linksys Wireless-G WRT54G Router
Hello I have a Fujitsu N Series Lifebook, my brother changed my password and forgot it now I am not able to log on. Is there any way that I am able to restore to factory settings?
First, try logging into the admin account. I'm not positive about your particular computer, but for the most part this consists of using Admin as the username, then either admin as the password or something else similiar. Look up your computer to find it. Once in, you can go to user settings and remove the password.
If this doesn't work, you will have to use a boot program to hack the password, but I'll wait until after you try the first part to go into detail about that.
Oct 07, 2010 | Computers & Internet
How can i made admin password in WBR 2310?
in your explorer bar
type 10.0.0.1
log on as ADMIN
Password Admin or 1234
add new user when logged on
create your password here
make new user the default user
'write down log on details and password too
open a second explorer bar and log in as new user for testing
if working save your settings and close explorer
open in admin mode then try new user mode
admin probably wont work now new user is the default user so everything should be working now
cheers Misterdj
Apr 18, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How is login and password in router wg 414b-i
The by default Login ID and Password is (admin , admin).
If it does not work please check on user manual given by the manufactures. Or could be the case the some budy manually changed the router details.
Regards,
Raman
Sep 07, 2009 | LanReady (WG414B-I) Wireless Router
How to enter authentication details for the Document Server ?
Hi there if you type in the internet explorer the ip address there you will have the machine information. Then login usually the login is
User name = Admin
Password = password or just enter leave blank
Once you are in there you will be able to change the details you need.
Cheers J
Dec 26, 2007 | Ricoh Aficio 3025 All-In-One Laser Printer
Computers & Internet Logo
15 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
alex metro
alex metro
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
