Question about Samsung Ultra SlimFit 20" Digital TV
Standby faulty standby/no snow
Why no picture?
Probable power supply failure
Apr 14, 2016 | Insignia Televison & Video
Plow lights work OK, but why is there no power to joystick?
Bad connection in plug,bad wire, fuse or fusible link, faulty joystick.
press the helpful button and check link below
western plow problem Snow Plow Forum Let Talk Snow Discussion Forums
Jan 14, 2016 | 2002 Ford F-150
KLV-32EX330 LCD TV 3TIMES BOOTING ON SNOW SCREEN & GOES OFF.STDBY RED LED BLINKS 6 TIMES
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Aug 01, 2015 | Televison & Video
Sr my KLV 32ex330 standby press tuch release snow 3 times on of next red light 6 times blinking
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty
May 02, 2015 | Televison & Video
Got no channels lost all recordings have no signal, dish cleaned of all snow ect, no programmes for two days. Any advise please.
LNB has blown OR faulty cable. Snow could have got in and shorted cable. Try cutting off and replacing F connector. If cable ok then must be LNB - cheap part and often sky would replace free.
Dec 19, 2010 | Toys
RCA XL100 20" Snow on screen
you have lost one of 3 things,Antenna/Cable, Tuner or part of your tv's power supply
Sep 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
No Display
mainboard damaged and need to be replaced
Jul 09, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Nothing but snow
Your explanation about a different TV receiver working OK on the same aerial connections leads me to believe you have lost the tuning in the faulty receiver...
Just "snow" with no sound is a classic response for lost tuning....
It shouldnt have lost the tuning as there is a small battery(capacitor) that holds the previous receiver channel settings when you turn the TV off. But as you have had the Receiver in the back of a truck and disconnected from the power supply for some time then this is probably the culprit....
This battery (Capacitor) may be getting old and has lost its capability of sending a minute amount of current to the tuner IC (Chip) ...to hold your previous channel settings...So if you can retune the receiver to the output from the Dish Network Receiver you should be fine again, but if the battery is shot you need a new one....or just leave the Receiver in the standby mode for a couple of days to re-charge the battery (capacitor) up.
You will need a service technician to replace this small battery (capacitor) its a special type made just for your receiver....
Hope this helps
YUBEUT..
Oct 07, 2007 | Philips Magnavox TS3260C 32" TV
Samsung Ultra SlimFit 20" Digital TV Logo
52 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
