Question about Indesit Washing Machines
Washing machine burning smell
I have an Indesit WIXE 127 (uk) that has over the last couple of washes started to fill the room with a burning rubber type smell! Have taken the back off and the belt to me looks fine although im no expert, the machine is comming up 6 years old other than this it works however i feel something must be going wrong and would like to put it righr before it fails!!
  • Owen Giles
    Owen Giles Mar 23, 2014
    UPDATE Have used the machine again today and actualy the smell its not a burning rubber smell its more just a hot burning smell like maybe a hot motor!
  • 6 Answers
SOURCE: Burning smell at end of wash
could be the belts but it could also be the motor depending on the smell
Posted on Nov 27, 2009
GodBlessU
  • 3513 Answers
SOURCE: burning rubber
Hi
You have a broken motor coupling, while you are down to the pump check for something jamming the pump,..
Please follow the procedure...
First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft.
Thanks for contacting Fixya.com
Posted on Oct 01, 2009
SOURCE: I have a 2 year
Pull the back panel off and look at he drive belt. My pully nut loosened up and caused extreme vibration (more than usual). The pulley is aluminum and it rounded out the center hole of the pulley. The belt finally came off. I replaced the pulley and belt.
Posted on Sep 08, 2010
taran_2005
  • 10515 Answers
SOURCE: Indesit WIXE 127 The machine is
Demo Mode
If the machine is on Demo mode 'D on' will be displayed and the machine will NOT function.
To reset the machine for normal use:ยท
Turn the power off at the wall.
Push in and hold down the Start/Stop and the Start/Reset
buttons, while still holding down, turn the machine on at the
wall.
'D off' will be displayed and the machine will function
normally.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 20, 2010
  • 1751 Answers
SOURCE: Code F-05 showing on INDESIT
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Posted on Jan 03, 2011
My indesit WIXE 127 IS WORKING BUT MAKES ONE HELL OF A NOISE WHEN SPINNING
If it sounds like an aeroplane it's probably bearings u/s
Jun 19, 2013 | Washing Machines
Indesit wixe 127 door error
Most likely have to change the door lock and latch assembly.
Sep 04, 2012 | Washing Machines
Indestit wixe 127 is leaking water from under the machine and sound like an aeroplane when spinning ??
The only way you can find out where the leak is coming from is by removing the back and putting water in it. Using a torch try to see where it is leaking from. TBH its usually the door boot (the rubber seal around the inside of the door). As for the noise.... Open the door and take hold of the shiny part of the drum inside. (Just that bit). Try moving it up and down. If there is any play in it and it rocks a little that is your bearings going and can be an expensive repair. Hope that helps.
Oct 16, 2011 | Indesit W 123 Front Load Washer
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Jan 03, 2011 | Washing Machines
Model WIXE 127 instruction manual I have lost the one provided with new machine
Go to -
WWW.INDESIT.CO.UK
In the menu on the left, click on--- Indesit user manuals.
Then in the search box, enter your model number, and download the instructions.
Please rate my solution to your query.
Thankyou.
Jan 15, 2010 | Indesit Washing Machines
Wixe 127 how do you get max spin 1200 on spin cycle can only get 800 down to off?
It can actually depend on the programme you have selected.
You have to select a programme that will accept a 1200 spin, as not all programmes do.
Hope this helps.
Dec 16, 2009 | Indesit Washing Machines
Fabric conditioner not going
Check the solenoid belongs to that tray.It may struck.
Jul 05, 2009 | Indesit WA 125 Front Load Washer
Manual for Indesit WIXE 127
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Apr 07, 2009 | Washing Machines
How to remove filter on Indesit WIXE 127 front loading washing machine
You will find there are something like coins trapped in the filter, stopping it turning, get some pliers & try turning it backwards & forwards to dislodge the blockage. If this doesn't work you may have to force the filter & buy anew one
Nov 03, 2008 | Indesit W 123 Front Load Washer
My indesit wixe 127, wont drain and is stuck on error code f05. what doi do?
i think there is a problem with low water level sensor
My 127 fill up with water and i have f-08 error code which is a high level water sensor faulty
Aug 11, 2008 | Indesit Washing Machines
Washing Machines Logo
26 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
