Question about Acer America Acer Aspire AZ1620-UR10P PW.SGQP2.008 20"" All-in-One PC Windows 7 Home Premium 64-Bit"
Been in software installation point 13/30 for 2 hrs
Managed to get the computer to go to restore and recovery screen, chose restore to factory default, went through prompts, been stuck at software installation screen for 2 hrs that says it has completed 13/30 installing Office 2010. " Your software is being installed. Please connect to power cable and do not turn off your computer" Power cable is connected and one usb port is being used by wired keyboard. Do you have any suggestions.
  • 790 Answers
Sorry to hear about your computer problems.
If you are re-installing your software from a factory partition and you are hanging up in one of the processes, chances are good that you have Bad sectors and blocks on you hard drive.
This partition is a reserve and if damaged, will be useless.
If the system hangs, your information will still be on the drive.
Find a 64 bit version of win7 and try to repair.
If you have a USB external drive, you can transfer any needed data to it.
Also, if you have a emergency boot disk, you may be able to restart unit to retrieve data.
Hope this helps.
Posted on Mar 22, 2014
Acer travelmate 4222 i need to factory reset without cd
Try acer recovery management . should be installed on your pc. look for the restore button when the program opens.
Feb 14, 2014 | Acer TravelMate 3260-4874 Notebook
My computer is saying that the system is not fully installed and all I want to do is to resite it to its factory settings
Which operating system ?????.....
The HP Recovery Partition that comes pre-installed on most new HPs is like built-in insurance if your system becomes unstable or fails.
If the problem is severe enough, you may not be able to start the HP Desktop Recovery Manager from Windows but you can start it manually by following the steps below.
Disconnect all peripheral devices and power on the computer.
Press the F11 key after the computer first powers on to start the HP Recovery Manager.
Follow the on-screen instructions to back up recoverable files on the hard drive to an external drive or media.
Continue following the instructions to recover the hard drive to its original factory condition.
Click "Finish" when the recovery is complete.
Reconnect devices and reboot the computer.
Reinstall software and update Windows and HP to current settings.
Performing an HP System Recovery (Windows Vista)
HP Pavilion Recovery Partition
Accessing the recovery partition on your HP Pavilion laptop allows you to restore your computer to speed it up, eliminate a virus or repair your Windows operating system.
The Recovery Manager program makes it possible to restore your laptop to its settings as of a previous date or restore your computer to its original factory settings, which will erase all of your installed programs and personal data.
Using the recovery partition allows you to bypass the hassle of keeping track of recovery discs, which could be damaged in storage, rendering them useless when you need them.
Turn on or restart your HP Pavilion laptop.
Press "F11" when the "Press <F11> for recovery" message appears during the HP Pavilion boot process.
Select "Recovery Manager" from your list of recovery options and press "Enter."
The Recovery Manger program will open on your screen, and you can begin the recovery process.
Access Recovery Manager Within Windows
Click the "Start" icon or "Start" button in the lower left corner of your Windows home screen.
Click "All Programs" and then "Recovery Manager."
Click "Recovery Manager" again to open the Recovery Manager program on your HP Pavilion laptop.
using the hp recovery manager in windows 7
Oct 15, 2013 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
How to reset
Which operating system ??..
or
While restarting the computer keep tapping on the F10 key
on the next screen you will find start system recovery , and on the next screen you will find advanced options
in advanced option you will find an option for Destructive Recovery.. click that
If you are not able to run the recovery on the computer as above then you will need no use a set of recovery cds..... if you dont have them you can get it from HP..
or
HP Desktop factory settings
Gateway desktop critical error code
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
if this hails to fix the problem
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of your Windows 7 home screen.
Click "All Programs" in the Start menu, then click "Gateway".
Click "Gateway Recovery Management" to open the Gateway Recovery Management program.
Click the "Restore" header, then click "Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart.
When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
Jul 02, 2013 | Computers & Internet
How do you restore a emachines el1200 desk top to factory settings
[1]
reinstalling the operating system If you can run Windows...1 Click (Start), All Programs, eMachines, then click eMachines Recovery Management. eMachines Recovery Management opens. 2 Click the Restore tab, then click Restore system to factory default. The Confirm Restoration dialog box opens. 3 Follow the on-screen instructions to finish.
[2]
If you cannot run Windows...1 Restart your computer, then press the ALT+F10 keys during startup. 2 Follow the on-screen instructions to finish. IMPORTANT • • If your hard drive has failed and you can't restore the software from the hard drive or recovery discs, contact eMachines Customer Care for help. After you restore your computer, it will appear with the same files and programs it had when it shipped from the factory. You still need to download Windows updates and antivirus updates to bring your computer's software up to date.
Aug 27, 2011 | E-Machines eMachines Desktop PC
Factory reset
I think with acer u can use their erecovery management within windows /start/programs/Acer Recovery management/
or you can use the Alt+F10 or F11 at the start up some models vary and that hopefully should prompt u to reset the pc to factory settings, remember to back up you data, you might struggle with some drivers, and make sure you reinstall the security software that you prefer as soon as you are able to connect online. good luck hope this helps
May 04, 2011 | Acer TravelMate 240 Notebook
Is there a restore partition on a hp mini 110 laptop. If yes, how to access it ?
Using the Recovery Manager
The recovery manager helps you recover your factory shipped computer programs and drivers should you experience a computer failure or instability. The recovery manager can be accessed by either of the following:
Click Start and start typing recovery in the search field. Select Recovery Manager from the list provided.
Recovery Manager is also accessible by pressing F11 during boot and allows users to recover the factory preinstalled image.
The recover manager allows you to perform the following by selecting the Yes button and then the Next button on the appropriate screen:
Software program re-installation:
o
If you select Yes and Next , you will see a software re-installation screen that helps you reinstall software that was included with your computer. Select Next and you will be provided a list of programs and be asked to choose which program you wish to reinstall. Follow the onscreen instructions.
o
If you select No and Next , you will be asked if you want the following:
Hardware driver re-installation:
o
If you select Yes and Next , you will see a hardware driver re-installer screen that helps you reinstall hardware drivers that were shipped with your computer. Select Next and you will be provided a list of drivers and be asked to choose which driver you wish to reinstall. Follow the onscreen instructions.
o
Microsoft system restore:
o
If you select Yes and Next , the Microsoft System Restore requires you to leave the Recovery Manager and by selecting Next , you will be forwarded to the Windows System Restore program. Follow the onscreen instructions.
o
Recover your computer to its original factory condition:
o
If you select Yes and Next , your computer will automatically start the shutdown procedure and reopen in the System Restore program. Be sure you want to completely restore your computer to its initial factory settings before proceeding. Otherwise select cancel.
o
If you select No and Next , you will be provided information for contacting HP Support. Clicking Finish will close the program.
Mar 16, 2011 | Computers & Internet
Packard bell easy note lm85 recovery management & updator software download link please
Hi
When you hit the power key also hit the F11 key keep pressing it until you get into the
recovery box
then follow on screen instructions
please back up all you files or pictures ist onto a disc or pendrive
because if you take it back to factory settings you will loose everything that you have put onto the
laptop but the bonus is that you will have a nice clean hoopefully sweet running laptop
good luck
Feb 24, 2011 | Acer Aspire 5610-4648 Notebook
How to factory restore my compaq presario f700 with no CD-ROM
It depends on which OS and software came with the computer and the state of the computer. (In all cases do not use the Microsoft System Restore. This will return a computer to the last known good state (revert to a prior version of the registry) but not to the factory installed state.)
To do a recovery without starting Windows:
Some Vista and Win7 machines came with HP Recovery Manager. Press F11 during bootup (BIOS prompt) then if the hard drive is accessible, the Recovery Manager will start. Follow the on-screen directions. (If you changed the OS from originally installed version or repartitioned the drive, this is not available.)
For all other OS and recovery software options, you will need an external (USB) optical drive. The preferred option is a R/W DVD drive to create the recovery media yourself. (HP will send you recovery discs for a fee if the machine is under warranty.)
If you can enter Windows, click Start
Sep 25, 2010 | HP Compaq Presario F500 F700 and G6000...
Restoring to factory settings
Did the laptop come with a Restore CD if so insert that and restart the computer and follow the instructions.
Jan 14, 2008 | HP Pavilion dv9000z Notebook
Acer America Acer Aspire AZ1620-UR10P PW.SGQP2.008 20"" All-in-One PC Windows 7 Home Premium 64-Bit" Logo
29 people viewed this question
Top Acer America Computers & Internet Experts
JonSnell Electronic
JonSnell Electronic
Jovan Sakovic
Jovan Sakovic
L Pfaff
L Pfaff
Are you an Acer America Computer and Internet Expert? Answer questions, earn points and help others
