Question about Sharp AL-1217 Copier
How do I reset the Change Drum Soon on the display? al1217
Alarm says replace drum soon. Can the message be
The "replace drum soon" indicater is a warning for you to have a new replacement drum "on-hand". Soon the display will change to "REPLACE DRUM" AT WHICH TIME THE UNIT WILL STOP PRINTING.
When the new drum cartridge is then installed...the REPLACE DRUM indicator will be reset. DO NOT replace the drum before the machine says to.
Jun 04, 2010 | Muratec F320 Plain Paper LED Fax
Change drum soon
There is an easy reset procedure for this.
1) Open the front cover. 2) Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO". 3) Press 1 to reset the drum count. 4) Close the front cover. Good Luck and Thank You for using Fixya.
Jun 03, 2010 | Brother MFC-7820N Laser Printer
THE FAX MACHINE SAYS CHANGE DRUM SOON WE CHANGED THE DRUM AND NOW NEED TO RESET IT SO THAT IT NO LONGER SAYS CHANGE DRUM SOON
Open the door where the toner cartridge is, and push the clear key and look at the display where it will say reset no press 1 yes press 2. That should do it.
Feb 23, 2010 | Brother IntelliFAX 4100 Laser Fax
Brother 8360p says change drum soon
You have to open the front door and then press options, should see Replace Drum? just answer yes.
Sep 09, 2009 | Brother MFC-8440 All-In-One Laser Printer
Replaced Drum still says "Replace Drum Soon". How do I reset on a Brother 7420?
Reinstall the new drum unit, keeping the front cover open. Press OPTIONS. Press 1 when the display shows REPLACE DRUM? 1.YES 2.NO ACCEPTED. Close the front cover.
May 28, 2009 | Brother MFC 7420 All-In-One Laser Printer
"Change Drum Soon" Message; not change when we changed the drum.
Description:
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
Aug 07, 2008 | Brother MFC-7820N Laser Printer
Continous 'change drum soon' message after I change the drum.
5750e fax machine: To reset the drum counter follow the instructions listed below :
Get the message to appear in the LED
1. Open the front cover.
2. Remove and Re-insert Drum/Toner unit
3. Press the CLEAR key.
4. Press 1 to reset.
5. Close the front cover, pressing firmly on each side until they click
into place.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000007572&Sympt=Why+does+the+message+CHANGE+DRUM+SOON+continue+to+appear+on+the+LCD+display+after+I+replaced+the+drum%3f&Model=58&ProductGroup=2&Keyword=Change%20drum%20soon%20message&ProductID=PPF5750e
Jul 08, 2008 | Brother Office Equipment & Supplies
Change drum soon will not clear after new drum inserted
Reset of the drum counter
Hope this helps...
Jun 10, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother PPF-2800 Fax Drum "change drum soon"
this it brother web side go there and will tell you how to do http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000007573&Sympt=Why+does+the+display+still+show+CHANGE+DRUM+SOON+after+I+replaced++thedrum%3f&Model=61&ProductGroup=2&Keyword=change%20drum%20soon&ProductID=PPF2800
Apr 11, 2008 | Office Equipment & Supplies
Drum on Brother MFC-7420
Why does the message "CHANGE DRUM SOON" continue to appear on the LCD display of my Brother machine, after I replaced the drum? Description: This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below. Open the front cover. Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO". Press 1 to reset the drum count. Close the front cover.
Jul 27, 2007 | Brother MFC 7420 All-In-One Laser Printer
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
