Question about Casio Privia Px330 Px-330 88 Key Digital Piano New
How do i adjust the drum rhythm volume so it is louder than the tone settings
I need the drums to be louder than the piano, organ,etc.
    Champion:
  • Casio Expert
  • 411 Answers
You ay have to edit a rhythm and save it as a "user defined rhythm". During editing the volume of each part can be defined with vol. level ranging from 0-127.
Please read the manual.
Metronome volume can be easily changed by just holding the metronome button.
Posted on Aug 12, 2014
SOURCE:
Does an organ have to be tuned to a piano?
Electronic organs typically do not require tuning
A pipe organ produces sound via hundreds or thousands of organ pipes, each of which produces a single pitch and timbre. The goal of tuning a pipe organ is to adjust the pitch of each pipe so that they all sound in tune with each other.
Feb 17, 2018 | New Music
Lowery Promenade organ LX400.
Have you tried unplugging it for a couple of hours ?
Aug 29, 2016 | The Music
I believe organ hasn't been played or even turned on in over 10 years. The top keyboard plays if I turn on a setting such as piano or trumpet however I can't just get the organ keys to play.
Since the organ has not been used for a long time, I suspect that there can be degradation of the electronics, specially with electrolytic capacitors. hence I request you to switch on the Organ continuously and allow it to warm up, it there is improvement , then it will be worth to remove the bottom panel and clean up the boards,dry the PCB with a hair dryer and reconnect the boards.
Hope this will help.
Jan 23, 2016 | Music
QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Sep 01, 2015 | Alesis Music
Alesis QS8 keyboard. The volume of the organ is much louder than the keyboard when I switch between both modes without touching the volume slide. How can I fix this.
P95 making noise when pressing any key or any sound. (piano,organ,etc.)
thats a motherbord problem./ ic called tone generator which is usually faulty.
Sep 24, 2014 | Yamaha P95 Digital Piano
Volume keyboard
Go into function and look for the volume setting for your main voice - could be R1. This will give a numeric value of 127 or less. It sounds like you need to increase it, try 100 as that is usually sufficient.
Dec 27, 2013 | Yamaha DGX230 - Digital Piano
Alesis DM6 kick/bass has a really low volume-any way to make it louder?
MAKE SURE WHEN YOU ADJUST THE VOLUME YOU PRESS
SAVE , GO BACK IN A CHECK VOLUME LEVEL TO A MAX OF 16
Jan 09, 2013 | Alesis DM6 Electronic Drum Set
My son has started learning piano using the CTK 651. The music teacher needs a metronome function in this keyboard. Is there a option for this here? How do i get to that.
Most of these keyboards have such a function... the manual doesn't show any... however one could select drum set 5 and use the claves setting for a rhythm and control the rate with the tempo. This might be too complicated and it might be simpler to get a small metronome... some are very inexpensive.
Jul 19, 2011 | Casio Keyboard Ctk-481 Ctk-631 Ctk-651
Very littel sound in white and black keys. normal
We can only guess at what model/brand you have.
OFTEN such low volume things can be traced to a burned out light used in some expression pedals that use light dependent resistors to vary the volume.
Be aware that on some organs things like rhythm drums MAY go through a different set of speakers and amps than the other voices.
Apr 30, 2010 | Music
Casio Privia Px330 Px-330 88 Key Digital Piano New Logo
138 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
