Question about Sharp AL-1641CS Laser Digital Copier
How to reset sharp al1217 drum - Sharp AL-1641CS Laser Digital Copier
4 Suggested Answers
  • 24 Answers
SOURCE: sharp al1217
I've never seen this model in Australia but could you confirm if its drum or toner either way its just the machine letting you know that it needs changing soon, however we have other models that do the same and run for quite a while before the quality drops off
Posted on Mar 19, 2008
  • 65 Answers
SOURCE: Sharp al1217 h4 blinking
H4 is a fuser heater code. This is most often a heat lamp.
Posted on Nov 24, 2008
hamzaskilltd
  • 316 Answers
SOURCE: H and 4 is blinking
H4 - Heat roller low temperature detection
Posted on Apr 13, 2011
H and 4 is blinking on my AL1217 sharp copier
Mar 04, 2011 | Sharp AL-1217 Copier
Tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Jan 04, 2010 | Office Equipment & Supplies
Office Equipment Copier Sharp AR-153E need to
Have you done simulation 24-7 to reset the drum? Do SIM 24-7 and the unit will start to copy
Mar 26, 2010 | Sharp Office Equipment & Supplies
Sharp AL-1217 Driver for Windows Vista
try the driver for AR123E at
http://www.sumthai.com/s0104/index.php?tpid=0086&pageno=1
it covers
Supported Models AR-123E, AL1045, AL1216, AL1225, AL1255, AL1530CS, AL1540CS, AL1456
Aug 21, 2009 | Sharp AL-1217 Copier
Reset drum
Hello sir; after you replaced drum there have 4 simulation you have to do;
1, simulation26-7 to match the first digit of the four digit printedon drum.
2, simulation 24-7 drum film wear correction counter reset.
3, simulation 44-6 patch forming voltage.
4, simulation 44-2 drum mark senser level standard value is 90.
To get in simulation the procedure as follow;
1, press "clear", 'pause", "0", "pause". then enter the simulation number one by one. GOOD LUCK !!!
Jun 02, 2009 | Sharp Office Equipment & Supplies
Nov 24, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp al1217
Mar 18, 2008 | Sharp AL-1217 Copier
1217 PRINTER PROBLEM
Try this link for printer drivers...
http://www.tradenet.sharp.co.uk/files/Personal_Products_%28Copier%2CPrinter%2CFax%29/AL_Product/AL1217/AL1217420.zip
Any problems please contact me again.
the above link is for the GDI windows XP driver
Thank You
Mar 10, 2008 | Sharp AL-1217 Copier
Drum cartridge - generic
Sharpe are correct there is no known button sequence I know about as the drum normally has a resistor that blows when installed resetting the drum count.
Thanks J
Dec 26, 2007 | Sharp AL-1661CS All-In-One Laser Printer
Sharp AL-1641CS Laser Digital Copier Logo
26 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
