Question about Electric Measuring Tools & Sensors
I'm looking for a wiring diagram of an multimeter dt 3800
There is a standard resistor burned through, which I have to replace, but I don't know the value of it
  • 76 Answers
SOURCE: Need value for part R14109
R14109=750ohms 5% 1/4w (Resistor(750r5%.25W/R14109/179317) There is much more likely wrong with the TV. Resistor don't normally burn out with help, say, without a failing flyback transformer and possibly taking a transistor or two with it. If you need the manual, go to http://www.samswebsite.com/photofact/pf_search.asp and type in "F31317" into the search field, you will several listings. If you decide to replace it yourself, here's some more part numbers in case you need them. Model: RCA\F25422TX41 Symptom: Dead Necessary parts: Transistor(Q14401) Main Voltage regulator Q14101 Resistor R14109 open. Research indicated the flyback transformer most probably bad \\CTC203AC4\HOT/D2578(Q14101/242224)* Flyback(14536119A/T14401/244229)* Main reg(P9NBSO/Q14101/244223) \Reg(MPS8599/Q14102/147665) Resistor(750r5%.25W/R14109/179317) Reg(MPSA06/Q14103/232218) Hope this helps you. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
SOURCE: samsung projection tv convergence problem
I was just working on replacing my stk's and was wondering if you could tell me what value the resistors are? Here is my previous post if you would like to see it. http://www.fixya.com/support/t191186-blue_out
Posted on Sep 25, 2007
SOURCE: HP Scanjet 5370C circuit board resistor 105 burned..what is size?
http://en.wikipedia.org/wiki/Resistor
Posted on May 13, 2009
SOURCE: NEED TO KNOW THE OHMS VALUE FOR RESISTOR ON PEANUT 8685
I have the same problem, but it is open.  The color code Brown - Green - Brown - Gold.  If it is a resistor, the value must be 150 ohms +/- 5%.  To confirm the value, I open the working trimmer and remove one leg from the circuit and measure resistance.  The meter reads only 4 ohms.  Therefore, I think it is an inductor (150uH +/-5%), not resistor.
Posted on May 14, 2009
SOURCE: burnt out resistor
I'm in the same fix. I learnt that a new pcb is £68 so had the pcb repaired but after the machine has warmed up it now cuts in and out. Like you, I haven't been able to locate a wiring diagram so am trying a last minute lash-up before binning the machine:
A friend suggested that since we all seem to only operate the cleaner on full power I should connect the on/off switch direct to the motor bypassing the rheostat and the pcb as in old fashioned machines.
Posted on Jul 07, 2009
My indesit cooker keeps blowing the fuse
Could be a shorted part. Thermostat, resistor, etc, without looking at it, very hard to tell what is wrong. Some part is shorted you will need a multimeter or look for burned part.
Mar 11, 2014 | Computers & Internet
My fan wont turn on
I don't know which fuse it would be, but you can easily check them all one by one. Either check them visually, or you can test them for continuity with a multimeter.
When my fan died, none of the fuses were blown. The resistor the controls the different fan speeds had burned out. This was far more difficult to check and replace than a simple fuse, however.
Oct 22, 2012 | Suzuki Aerio SX Cars & Trucks
Resistor going to my pto clutch burnt out
Your going to have to call the factory/customer service and find out what the resistor size is.Got Radio Shack and get a couple of them and solder one in.You don't want to run it strait without the resistor,could burn up something MORE important.Like the clutch.You can get Husqvarna online help too.Try Husqvarna.com.This new stuff can be a pain at times,but gotta havit.Rigger
Aug 28, 2012 | Cars & Trucks
WIRING DIAGRAMS
You'll probably need a shop manual for that.
Most DIY books don't provide diagnostic info for sensors.
Jul 13, 2012 | Cars & Trucks
Hello I have a 2005 gmc Yukon Denali. The other day it rained heavily. The next morning I went to work and noticed my ac blower wasnt working. So I tested it and the motor ran but I did find that my...
check the wires with a multimeter to see if there might be a short. put the multimeter where the fuse is at to see why the fuse is being dead. but make sure you know what you are doing first with multimeter or have someone else that knows how to use the multimeter.
May 24, 2011 | 2005 GMC Sierra Denali
Yamaha DT 250 Enduro wiring diagram
Hi, Keith1171 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha DT 250 Enduro wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
Yamaha DT250D Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-dt
Jan 26, 2011 | 1972 Yamaha DT 360
The air conditioning works, but only when the switch is turned to high. We tried replacing the switch, which did not work.
Good that you replaced the switch, but usually the resistor is also bad when this happens. The resistor is usually somewhere under the dash screwed into the duct with 2 screws and has a connector coming out of it with several wires. Remove the connector and unscrew the resistor. It will probably look burned up. If so, replace it.
If not, the wires have probably burned up somewhere along the way. If you have trouble finding the resistor, please let me know and i will try to locate it for you. It looks like this:3067b47.jpg
Sep 26, 2010 | 1995 Nissan Altima
Need Circuit Diagram, or convergence resistor list for PT51D31CE
they are 2.2 ohm , i have replece many of this before
Apr 19, 2010 | Panasonic PT-51D31 TV
Panasonic TV projector PT 4743G
yes the convergence ics will blow that resistor
Jan 21, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Measuring Tools & Sensors Logo
42 people viewed this question
Top Electric Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Electric Measuring Tool and Sensor Expert? Answer questions, earn points and help others
