Question about Nikon CoolScan V ED Film Scanner
Scanner doesn't recognise their is a slide loaded in the slide holder
I have loaded the slide into the slide holder in the scanner. When I click on scan in Vuescan, the software tells me there is no film loaded and to insert some into the scanner. Pleas help!
    Problem Solver:
  • 13 Answers
The first thing I'd try is to run the scanner with the Nikon software. When you power on the scanner it goes through a variety of checks, and finally you should have a silent scanner with a solid green light at the front. Start the Nikon software and wait until it finds the scanner, if it doesn't you have a hardware problem with the scanner.
If it goes well to this point insert a card or plastic mounted slide and hit Preview. The scanner should then create and image you see on screen. Next step would be to make a scan. If the slide you're trying to scan isn't card or plastic mounted you'll need the Nikon made carrier.
Hope this helps.
Posted on Mar 23, 2014
2 Suggested Answers
SOURCE: nikon 8000 film scanner problem
I If you use nikon scan you get a different error warning Update nikon scan and also gdiplus.ddll update from thre nikon web site. It worked for me.
Posted on Jul 27, 2008
I am trying to scan slides with Epson Perfection V500 Photo...I placed the slides in properly and press the scan button on the scanner. It scans the row of slides as they appear on the scanner bed. But...
You have to have the plastic slide holder (positioner) placed perfectly. Look at the "A" and "C" tabs on the plastic holder. If they don't position your slides over the center of the glass, you are using the wrong tab! Slides have to be back-lit, which is what the top cover does. It doesn't light up the sides of the scanner glass, only the middle.
Feb 04, 2011 | Epson Perfection™ V500 Flatbed Scanner
The slide holder will not return after scanning. The little wheel that is supposed to move the slide holder just clicks but doesn't move the slide holder. I have to remove it by hand. By the way, this...
I have the 5400 II and have had similar problem. I found out, that it is essential, that the film/slide holder is clean and have a smooth surface. Specially on the edge where it touches the plain bearings. I have lubricated the whole holder with acid-free silicone, wich over time made the scanner work perfectly.
Brgds Per
Jan 01, 2011 | Konica Minolta Dimage Scan Elite 5400 II...
I have recently purchased the SVP Digital Film/Slide Scanner for the purpose of scanning slides and my initial response to the product is very favorable. I have however found that loading the slides into...
FixYa provides help and advice to people's problems and we are not affiliated with any companies.
You are best solution in this case is to contact the supplier of the fiim scanner or the SVP company.
Oct 02, 2010 | SVP PS9700 Film Scanner
My scanner sometimes crops a particular slide but not others. Some scan ok. What is going on?
Be sure to put the slide in the holder in the proper direction. The opening in the slide holder is rectangular, not square like the slide. If you place the slide in the holder horizontally and the holder window is vertical, it will crop off the sides of your picture.
Jul 20, 2010 | Plustek OpticFilm 7200 Film Scanner
First time i have scanned slides. not sure how to load them. do you slip them in from top, then cover with the vertical slide? i have put in a slide but can't read it--it comes out black when i try to scan...
double click the HP solution center open the scanner lid remove the TMA cover (transparent material adapter) by pulling the cover up place the slides onto the slide holder insert the slides w the top of the slides pointing up and the front of the slide facing you close the lid press the scan film in the HP dialog box select picture select scan positive, and select TMA click scan
goodluck
cheers
Dec 22, 2008 | HP Scanjet 4850
The slide transport goes in about 1 inch and then ejects itself.
Not sure if this will fix it, but there are a bunch of metal tabs on each rail (that the holder goes into) that (I believe) are contacts that help the scanner to determine where the holder is. They get bent very easily. If they are, bend them back carefully.
You sort of have to look "up" into the scanner with a flashlight to see them on each side.
Dec 14, 2007 | Minolta Dimage Scan Dual II Film Scanner
KM DiMage Scan Elite 5400 II
I have same problem..Are you find answer!? Thanx!
Graksi
Dec 03, 2007 | Konica Minolta Dimage Scan Elite 5400 II...
Nikon CoolScan V ED Film Scanner Logo
131 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
