Question about CTL 2go NL2 Net-tablet PC Intel Atom N450 Single-core 1.66 GHz - 512 KB - 10.1 Active Matrix TFT Col... (NBCNL2B) PC Notebook
Crack sreen my sreen is caack in mean several driffent place there are small one and big one i can use it but it is geting hard see thing because the crack seem to keep larger?do they cost alot in willl i need to take it to a shop i think if i take it to a shope it will be like bye a new one see i dont have alot of money so i try to just keep trying to use it but it has real hurt my eye i real hope u can tell me how to do it myself willl im praying thank u for time hope to here from u soon
White smoke gas smelljust changed plugs check engine light went off but the smoke is geting worse is this gasket hard to change
It sounds like a head gasket is blown or block is cracked, its a big job if you know cars, if you don't know a lot about your cars i say good luck.
Mar 12, 2015 | Cars & Trucks
What is causing my unintended acceleration in my 03 trailblazer
The brake booster can do this. It is the big black circular thing on the drivers side, at the fire wall. A small hole in the diaphragm. Hard to find and diagnose. These aren\'t cheap. Get one at a junk yard... New ones are $200 to $500. Small vacuum leaks will always cause an acceleration. big ones cause a misfire or really rough idle.
Sep 04, 2014 | 2003 Chevrolet TrailBlazer
How did my display get broken?
Typically this happens because the phone is dropped onto a hard surface on the edge or it falls display down not a surface that has a pebble or some other small surface that is sharp.
Other people place in a pocket causing stress to the screen. While damage may not be visible small invisible cracks can become big ones under repeated torsion.
Motorola Support
May 07, 2014 | Motorola Cell Phones
My 2002 chevy 6.6 duramax has white smoke coming out the tail pipe. What is possible problem?
Sounds like you have eather a small hole in head gasket. or a crack in head. White smoke mean's water in exauest.Try a bottle of liquid glass stop leak first if not to bad . this works good. if not to big of hole. good luck to you.If need any further help just let me know.
Mar 28, 2011 | Chevrolet 2500 Cars & Trucks
Sreen not broke but the picture inside is when
If you see rainbow colors on the screen, the screen is cracked, you will need the whole panel assembly replaced.
Nov 03, 2009 | Sharp LC46SB54U 46 in. LCD TV
Speaker is cracking whats wrong
This means your speaker is likely blown. In a big screen tv, this will be hard to fix. You have several options:
1 - Manually unplug speaker - meaning cut the wires, wrap 2 ends SEPARATELY in elect. tape
2 - In the Audio Options menu (or whatever its called on your particular set) set the Balance all the way to the other side.
3 - Replace speaker with a new one (on my set I can remove the front panel and see the 2 small speakers). This is not possible on all sets.
Oct 27, 2009 | RCA HD52W59 HDTV Projection Television
Cause of car RPM/speed rising up automatice?
usualy engine is geting too much of air check all the hoses including the one for the throttle body the big air duct may be cracked
Dec 31, 2008 | 2003 Kia Sedona
Operating system
If you have a laptop, it has a function called Hibernate. In this, the entire thing that is running, as it is in the RAM, is stored in a place on your hard disk and the PC is shut down. It resumes everything when it is switched on later.
The place reserved on the hard disk is a small thing called 'hibernation.sys' and it is as big as your RAM. If you don't need it, you can delete it through the command line or Disk Cleanup.
Now, the problem you are in is that the file has been deleted, mostly through cleanup and the system cannot hibernate anymore. I recommend that you use System Restore and roll back the computer to when there wasn't any problem. This won't harm your personal files. Now, remember to uncheck 'Hibernation Files' or similar in Disk Cleanup to avoid deleting it.
Or else, there is another way to restore the file without using the time consuming System Restore. See this.
Dec 13, 2008 | Computers & Internet
Cracked sreen by wii remote
Good Day, dabbpetty;
It sounds like you are confused, so order both screens. They both are probably damaged. Good Day, big IRISH.
May 31, 2008 | Mitsubishi WS-65315 65" Rear Projection...
CTL 2go NL2 Net-tablet PC Intel Atom N450 Single-core 1.66 GHz - 512 KB - 10.1 Active Matrix TFT Col... (NBCNL2B) PC Notebook Logo
15 people viewed this question
Top CTL Computers & Internet Experts
Joseph Hoffmann
Masood Rasool
Level 1 Expert
Are you a CTL Computer and Internet Expert? Answer questions, earn points and help others
