Question about Whirlpool Dryers
Is there a way to reset the dryer?
The display shows a message: F04 Is there a way to push the start button a few times or something that will possibly RESET the dryer again?
    Scholar:
    New Friend:
  • 111 Answers
Need exact model number will let you know what code means
Posted on Mar 23, 2014
  • 76 Answers
SOURCE: Dryer won't start when pushing the start button
bjsouth Most likely the problem with your dryer is bad motor. It is not repairable and has to be replaced. If you feel you can do it yourself, let me know and I'll help to buy new motor and provide you with instructions how to replace it. Gendos...post back
Posted on Mar 04, 2007
agitateme
  • 88 Answers
SOURCE: kenmore electric dryer model # 87670100
The motor is weak and needs replaced, don't hold the start button too long or you may smoke the motor's thermal protection and it could get smokey and stinky. Make sure you can get the blower wheel off before you make a run for parts, sometimes you have to break them off the shaft. : (
Posted on Sep 17, 2008
  • 1462 Answers
SOURCE: The tumble dryer appears to
check the lint filter and check venting clear
Posted on Nov 04, 2008
SOURCE: Asko T701 Dryer - Dryer Start Button
There is a reset (overheat) button in the back of the dryer. My manual states that this switches off the tumbler if the temperature is too high... need to clean the filter and reset the switch by pressing the rubber disc on the back of the machine.
However, this issue was just the beginning of my problems with the T7005... have had the switch replaced, rollers replaced and now being advised that the motor needs replaced too. Although the Asko marketing quotes a "20 year" lifespan, mine is at 10 years now. Probably will choose another Asko as my cabinetry is built around these machines. Good luck!
Posted on Jan 09, 2009
canbruce75
  • 1776 Answers
SOURCE: First the dryer stopped heating, then when the
This is a situation that you need to be very careful with. It sounds like you have a grounded heating element. If this is the case, then the current can be running through the dryer's frame and can cause electrical shock. Keep the dryer unplugged and check the heating element for continuity. If it has none, replace the heating element. BE CAREFUL. Hope this helped and best wishes.
Posted on Aug 03, 2009
My brother NX-600 keeps displaying the code F04, if I switch machine off then on again it will allow me to sew, but then stops showing the F04 message agai.
You need to find out what that particular error code means and address that particular issue. It could be something very simple but frustrating, just the same..
Search for:
Make Model error code F04
Oct 19, 2017 | Brother Sewing Machines
What do Error codes F04 and E03 mean?
The dryer is in need of service if a code beginning with an "F" appears in the display.
Alternating between F# and E#, the dryer control has detected a problem that requires service.
Call for service.
May 04, 2014 | Maytag Maxima EcoConserve Series MED6000XW
Bad relay message and circuit breaker is pushed in and stuck
reset the machine and follow the step and fix it.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 21, 2013 | PaceMaster Exercise & Fitness
PLO5 error message on Quinton Clubtrack treadmill
Try to clear the error message. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 2
  • 3
Jan 25, 2013 | Quinton Stairmaster Clubtrack 3.0 GymTough...
What is f04 Whirlpool 6th sense?
F04 indicates a fault in the heating circuit.
It can be a main board, wiring, thermostat or heater fault.
You would need to check the heater and thermostats with a multimeter to ensure they are not open circuit.
However, the first thing to try is a reset of the control board.
Turn the dial to off.
Turn the dial clockwise to the 6 o'clock position.
Press the start button 3 times
Turn the dial 1 position clockwise.
Press the start button 3 times.
This should erase the code.
Try the machine again.
If the code comes back, you need to check out the heating circuit.
If you change or repair any part, reset the board, then try again.
Jul 09, 2012 | Whirlpool Dryers
Gas dryer will not start. Model MGDB850WR0 maytag bravo gas dryer serial MY3101043 purchased 2009. lights and display come on, push buttons give tones, but nothing happens when you push start. Display...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2011 | Maytag Dryers
The words tire reset keep on popping up on my dashboard. What does that mean, and how do I get rid of it? 2004 Ford Freestar.
With and without "Mesage Center" respectively (pretty sure)
With the engine on...
Push "Setup" button, until your driver display says something like "Press Reset for system check".
Then push Reset. The system check will start, rotating through a series of checks.
About the fifth or sixth check will be the tire pressure. The system will sound the tone (same one that starts w/the light) and It'll say something like "Check Tires Pressure" on that moment press and hold for 3 or 4 seconds Reset. When you release the Reset button It'll show "Hold Reset if tires are OK". While that's up, hold the Reset button. After 3 or 4 seconds, the tire warning light will blink 2 or 3 times and then will stop .You need to be ready for it, because you don't get very long to release.
How to reset the low tire pressure warning if the vehicle does not have the "Message Center"
Turn the ignition to the ON position,
depress and Trip/odometer button (located in the instrument cluster) until "TIRE RESET" or "CHECK TIRE AND RESET" is displayed in the odometer display window.
Once "TIRE RESET" or "CHECK TIRE AND RESET" is displayed, press and hold the button for three seconds.
The low tire warning indicator light will flash three times as the low tire warning system begins to initialize.
This information is in the Owners Manual
Hope it helps
Nov 04, 2010 | 2004 Ford Freestar
My Video casset palyer is Panasonic NV-MV20 VHS VCR
Looks like the Loading cage gears Timing has got messed up. If you are worried about taking it to a Repair Shop, take it to the company service centre.
Mar 16, 2007 | Panasonic NV-MV20 VHS VCR
Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Nov 22, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Dryers Logo
233 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
