Question about BATTENFELD Sport & Outdoor - Others
Moog adjustment Servo calve behaivor
My side view mirror on pt cruiser won't adjust down. I have to do it manually. All other directions work. What's wrong?
Dead short in the servo in the up/down servo, in/out servo still working. Same on my Lexus!
Nov 16, 2016 | Cars & Trucks
Calve gap on a Honda GX390 engine? Hi, I have a gas power washer with a Honda GX390 engine in it. I need to adjust the valves. Any idea what the gaps are supposed to be? Also do I adjust on a cold engine...
Hi intake is 0.15+ or - 0.02mm and exhaust is 0.20 + or- 0.02mm cold engine..I always double check after running the engine again...you can check out the owners and service manual and all specs here http://cdn.powerequipment.honda.com/engines/pdf/manuals/37Z5F602.pdf
Feb 23, 2015 | Honda Garden
How to build body building?
http://www.shopyourshape.com/calculate-your-body-shape/
Feb 05, 2015 | bodybuilding.com Android Apps
I keep seeing movies where the boxers all train by jumping rope. Why do they do this?
They jump rope to develop cardio endurance as jumping rope definitely keeps your heart rate up. Boxers need strong forearms and this activity targets them. Boxers need strong calves for their quick footwork and jumping rope targets the calves. Boxers also need good rhythm and timing, a skill that is developed in jumping rope.
Jan 03, 2013 | Exercise & Fitness
I want a good workout that will target my thighs and heard jump roping can help. What type of jumping will target my thigh?
Jumping from side to side with your feet together targets the inner as well as outer thighs. It also works out your calves and glutes. Jumping on one leg will target the glutes, calves, and hamstrings as well as the core. Front to back jumping targets all of the lower body muscles.
Do elliptical trainers have adjustment qualities?
Yes. Most trainers have adjustments for elevation. The elevation feature on an elliptical doesn't make the workout harder; instead it changes the emphasis so that the higher the slant, the more your glutes and hamstrings will be worked out; whereas the lower positions emphasize more on your quads and calves.
Aug 02, 2012 | Exercise & Fitness
Transformer broken 3 times!!! nothing strange, do not move or fell or connect to other things, use it only one time and burned !!!??
I assume you are using OFFICIAL Moog transformer. This takes a 12 VAC 500ma trnasformer which is VERY uncommon for pedals. DO NOT use the common transformers for most pedals which are around 9VDC as they MAY appear to work briefly but will not operate this unit. Let me know what Moog model power transformer you are using.
Jul 26, 2011 | Moog MP 201 CV/MIDI Control Multi Pedal
LOUD SCREECHING SOUND UPON START UP. I WAS USING BELT CONDITIONER AND IT STOPPED; HOWEVER, IT DOESN'T STOP NOW, WHILST USING THE DRESSING. PLEASE HELP!
tighten/adjust the belts and if overly worn CHANGE THEM. Only other problem I could suggest is a bearing in alternator or water pump is getting ready to calve.
May 05, 2011 | Jaguar XJ6 Cars & Trucks
How to adjust camber on 2001 monte carlo
There is no camber adjustment from the factory,however moog sells a camber bolt kit that will allow for adjustment. About 20 bucks . If you are talking about the rear of the car,ride height makes a drastic change in camber. If the springs start to get weak the camber will go negative,spring spacers will correct this.
Jan 07, 2011 | Chevrolet Monte Carlo Cars & Trucks
AC temperature
Servo motor? I disagree. Actually, there are 3 servo motors in the vehicle; an air inlet servo, an air mix servo, and an air outlet servo. None of which control the temperature.
The AC temp is controlled by a thermister in the cooler box/eveporator unit under the dash.
Jul 10, 2008 | 2001 Toyota Tacoma
Sport & Outdoor - Others Logo
354 people viewed this question
Top BATTENFELD Sport & Outdoor - Others Experts
Are you a BATTENFELD Sport and Outdoor - Other Expert? Answer questions, earn points and help others
