Question about Raymond Weil Watches
9172 D 009370
We want to check is the clock original.
Need replacement clock hand
Your best bet is to see if the original manufacture of the clock is still in business. If so, they may still have the necessary information for one of their clock makers to make a new hand for you.
The only other solution is to locate a watch maker who specializes in restoration of old clocks and watches. There are many around who are very good. A new replacement hand can be made for you.
In any case, obtaining a hand will not be cheap. There will be a number of hours of work involved to make a new hand. The watch maker will most likely need the clock movement set to him so he can do the exact measurements required.
As for original parts off the shelf for old clocks, these are not easy to find. Many of these clocks were built on a one-by-one individual basis.
Jerry G.
Dec 04, 2011 | Watches
Manual for seiko QHL050S
Please log on click your region link and click for support from Seiko
http://www.seikowatches.com/
Nov 15, 2011 | Watches
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
The clock runs fast , 20 plus minutes a day... Is there an adjustment and or how do I deal with this problem? Mantel 8 day clock. Thanks Ron
mcdevito75 here, There should be a F/S on the back of the clock, if so place it in the middle, if not, check out a small watcg repair shop in your area.
Jun 26, 2010 | Bulova Hyannis Desk Clock With Engraving...
I need a replacement-part of a bezel insert-ring for a Rolex
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 22, 2010 | Rolex Yacht-Master 16628 Wristwatch
The analog clock is different than the digital. how do i only change one?
It can be quite messy, but the only way is to go through Tissot original site.
Here is the link:
www.tissot.ch
Rate me, please.
Aug 15, 2009 | Tissot T-Touch T33759851
Does anyone know where to get a replacement 'movement' for the Michael Graves's Alessi mantle clock.
Yep - I know a clock repairman in California who still has some of the original Hechinger Quartz Movements for the Alessi pendulum clock . Definately worth repairing .
Jul 13, 2009 | Watches
I need a user guide for a La Crosse WS-9211 Weather Station clock
Solved it! La Crosse let you download manuals from their website.
Nov 23, 2008 | La Crosse Technology E. Howard Ambassador...
Old Panasonic Clock RAdio
Assuming she can live without the alarm functions, have you considered the quick and dirty option of swapping the original clock for a quartz movement?
Mar 28, 2017 | Watches
Watches Logo
16 people viewed this question
Top Raymond Weil Watches Experts
Lyle Siemens
Lyle Siemens
Jimmy Accardi
Are you a Raymond Weil Watch Expert? Answer questions, earn points and help others
