Question about Samsung NF210-A02 Netbook
Laptop have LED on but cannot be switch on the system
I cannot switch on my laptop even LED ligths were working
    Habit-Forming:
  • 192 Answers
That means its the time for you to giving the netbook for service at your near by service centre......or...........you can try downloading new linex or microsoft software.................the link i send you........from any other devices......and create a disc of it then try on your netbook....or.....you can buy a disc of softwares...........best of luck...........................all the best!!!!!!!.....did it have a fall?
Download Ubuntu Ubuntu
Posted on Mar 22, 2014
How do I fix the brake ligths?
Did you check to see if there is a fuse on the brake lights circuit?
If you changed the lamps and the brake switch it is obvious that they are not being energized.
Aug 31, 2015 | Cars & Trucks
I have a 40" Samsung LED model:UA40F5100 ang its not switching on, its having a red ligth not even working the remote or even if you press the manual button. what is the possible problem. Thanks..
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 19, 2015 | Samsung Televison & Video
No ligth on the radio of 2004 hona acord
manufactured led light system in radio may be out...unfortunateley the only way to fix is to send it back....radio will be coded from theft and will not work after taken out unless you have the code...aftermarket replacements are available!
Mar 17, 2014 | Honda Cars & Trucks
Hi i need help plz, i've my laptop do not power when i plug the ac adapter ther' is no ligth
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 23, 2011 | Dell Inspiron 2200 Notebook
Hi guys my Toshiba m35x s149 fell 2 feet to a wooden floor.The battery meter shows power of 63% but upon removing the power cord it switches it off.Tried another battery same response.when all is off( no...
I would think that the internal battery connections have been damaged from the fall. They may only need re-soldering. Any drop on to a hard surface from almost any height can damage your laptop.
Apr 18, 2011 | Toshiba Satellite M35X-S149 Notebook
On start up the lap top starts to come on and within 6 seconds it switches off and not even the screen comes on?
Do you have it plugged in? Also, do you know if the battery is charging? You may have a bad DC connection.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
The DC connector needs to be resoldered on the system board.
Dec 08, 2010 | HP Compaq nc6000 Notebook
I just bought two flood lamps to fit to the bumper of my 95 jeep wrangler, how would i wire them to a toggle switch?
  1. 2-wires on each fog ligth
  2. toggle switch 2-hook up
  3. okay run hot wire from battery to one side of toggle
  4. on fog ligths one wire migth be white or black
  5. take one of the wire on fog ligth (white)&other fog ligth (white)wire
  6. take a wire hook both white wire from both ligths an hook to this wire an run it to the other side of toggle
  7. black wire on ligths hook them to ground
  8. after you hook the ligths up an they work it best to put a fuse connector between one of the wires on toggle
Dec 06, 2010 | Jeep Wrangler Cars & Trucks
All lights work, except the brake /tail lights,the L.E.D. brake light on top works
The third break lights are LED and the circuit board may have gone bad or the solder may have gone bad. The circuit board is built in the third brake light and is a seal unit. You may have to replace the unit, there is a relay for the third brake light and that is located on the glove box behind the panel that say's relays. There are three relays in there, the center is for the fuel pump and the two out side are for the A/C and third brake light. Just swap them around and see if the brake lights come on. Good luck and keep me posted.
Jun 25, 2009 | 2001 Chevrolet Blazer
Cluster ligths not working
the switch has gone out and needs to be replaced.
Dec 24, 2008 | 1993 Nissan Pathfinder
Hp pavilion ze4900 charging but dead
Follow the below check list
Check1 : is power cable connected properly to computer
try checking all the cables are fixed properly
Check2 : Are you listining to Beep sound when your computer is poweron
IF yes then Ram is working properly
IF no then remove and fix your ram chipset again
Steps to do so..
switch of computer ..
open cabinet
You will find ram slot...press bars at both the ends ram will comeup directly..insert the chip again (donot press forcibly ) press gently untill you hear a click sound...
Switch on computer you should hear beep sound and computer will boot.
Thanks.....
Dec 16, 2007 | Computers & Internet
Samsung NF210-A02 Netbook Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
