Question about Whirlpool GU2400XTPS Built-in Dishwasher
Water will not/would not reach the top
1. Water would not spray out of the upper arms. Soap residue would remain in the cup after the cycle was completed.
I found the chopper assembly to be "clogged" and I would clear it. Pressure would be great again but in time I would need to repeat the process. How can I tell if the chopper is broken? Should the metal blades spin separately from the metal cap?
  • Whirlpool Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
g
Posted on Sep 30, 2010
Pld4555rfc3
Hello ddux97 - Here are a few simple troubleshooting tips that may help you resolve this issue:
· Do you have hard water? Hard water is the primary reason to cause soap residue. Water hardness can be determined by the local water supply company, water treatment company or via a water hardness test kit, which can be found at local part distributors or hardware stores. Some kind of water softening is recommended, in areas where the water hardness is 12 grains or higher. For very hard water a home water softening system would be recommended.
· Will the upper spray arm rotate freely? If it does not, then there isn't enough water being pumped to the spray arm or the full flow of water is not making it to the upper spray arm. Remove or replace the spray arm assemblies since it is possibly damaged.
· Confirm that the drain hose is strapped up properly under the sink to prevent the water from siphoning out during the cycle.
· Dishwashers require the water inside the unit tank to be 120F to perform properly. Best way to ensure this happens is to run the sink faucet until the water comes out hot before the dishwasher is turned on. This will ensure that hot, 120F water goes directly into the dishwasher when it starts to fill. When checking dishwashing detergent boxes and with detergent manufacturers, the compounds in the detergent need water temperatures to be between 125F - 140F to dissolve in the dishwasher. The water pressure should be 20-120 psi (pounds per square inch). If it is too low, I recommend reaching out to a plumber to further assist you.
· Rinse aid dispenser should be checked and filled about once a month depending on the number of washes you do in a month since this will cause cloudy dishes and soap residue.
If these basic troubleshooting tips prove ineffective, then at this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Jun 19, 2013 | Frigidaire PLD4555RFC Dishwasher
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
My LG dishwasher soap dispenser does not empty entirely and leaves a residue on the door. It also doesn't seem to be cleaning as well as when it was new. It's about 2 years old. I was using a gel...
Make sure you're not loading the dishwasher with large items close to the soap dispenser. These can block the action of the dispenser door. Also, be sure the water temperature is 140 degrees for the best cleaning efficiency.
Another thing may be that your spray arm jets are clogged.
Depending on the model, the lower spray arm generally has a nut or thumb/butterfly screw (plastic) that you remove and then lift the spray arm off. I always soak mine in hot soapy water and then flush with hot water. If debris such as pieces of paper, bone, peelings are in there, you'll need to take a tweezer or toothpick to remove them from the jets. The upper spray arm usually has the same apparatus and you can follow the same procedure.
The upper spray arm receives water pressure from a tube that runs up the back of the machine on the inside. If the connection has been knocked out of line, the water can't flow through the tube to the spray arm. My kids used to knock ours loose when they loaded the lower shelf. Pull out the top shelf and see if the plastic connectors are in place. If not, snap them back on the shelf supports and this should align the tubes.
One more thing: the bottom of the door..on the INSIDE of the machine.It's amazing how much "gunk" settles and accumulates under there. I use an old toothbrush, moistened in soapy water to scrub the underside of the door. Then pour hot water on the area. Next run a regular cycle with NO items in washer and use 1/2 cup white vinegar...no detergent.
I hope these suggestions help your problem. If so please come back to Fixya and rate my advice!
Jul 21, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
Maytag Quiet Series 300 - it seems like the soap door is not opening and when it does the soap packets are not dissolving. I cleaned out all of the spray arms. That did not help. What else can I do??
  1. Be sure that you don't have something large blocking the dispenser door like a cutting board.
  2. Make sure the water temp is 125 degrees going into the dishwasher. Cold water won't break down detergent correctly.
  3. Make sure your getting water pressure: Run your dishwasher on normal. Wait until the cycle starts and the spray arms are spraying. Turn a cup right side up to catch water on the top rack if you run the dishwasher and wait 20 sec that cup should be half or full. If you don't have water in the cup you could have poor water pressure from your pump. This could indicate 1. Worn motor 2. Clogged pump
Have a great day!
Dec 07, 2010 | Maytag MDB7100AWB Dishwasher
My dishwasher is not cleaning dishes - it is running through its cycles, but when it is done, there is a heavy residue of soap and hard water and the dishes looks worse than when i put them in.I've changed...
Hello there:
There are 6 areas that could cause this to happen Please follow these simple steps ok
Investigate each of these six areas if your dishwasher is not completely cleaning your dishes:
Water Inlet Valve
Heating Element
Filter/Drain Grate
Cycle Selector Switch
Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
Dec 30, 2009 | Kenmore 15899 Built-in Dishwasher
Dishes not getting clean
Check the following to address this issue.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jun 19, 2009 | GE GLD4600NCS Built-in Dishwasher
GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dishwasher - Soap Stuck in Cup If you have dishwasher detergent stuck in the soap cup after a full cycle, please check for the following conditions:
  • The water temperature should be at 120 degrees (140 degrees if your dishwasher has water heating capability). Check your water temperature Check your water temperature.
  • Make sure the soap cup is not blocked by anything.
  • Allow the dishwasher to fill and make sure it is getting a proper amount of water. The dishwasher should fill for about 90 seconds. On permatuf models, the water should measure 3/8" above the island near the center of the tub. On all other models, the water should measure about 1/2" below the heating element.
  • Check the lower spray arm for any blockage in spray holes or items that would restrict its turning.
  • Make sure the soap cup has opened at the end of the cycle.
  • Check the sump area inside the dishwasher for any restrictions.
Apr 09, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
Heating Element
Filter/Drain Grate
  • filter
  • . Detergent or Detergent Cup
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Mar 29, 2009 | Dishwashers
    Top arm is not moving
    Filter and rotor jets prob clogged.
    In wash, the water is heated, supposed to dissolve the soap and then sucked thru a filter and pumped up the back and out the top to spray water everywhere.
    Soap doesn't always fully dissolve and clogs the filter and some slimy gets thru and clogs the rotor jets.
    To fix:
    1. Remove Upper and lower dish drawers
    2. Take off the Upper. Middle and lotwe rotors and clean their jets out with toothpick and frequent flushing (Plug a clean hole with toothpick to make water come out elsewhere) Use the sink on full blast to see if water comes out all holes.
    3. Reassemble rotors.
    4. Remove and clean filter. The filter is in the bottom above the Motor/pump and held in with 8 shiny hex-head or Torx screws. Take out all screws, lift out filter and clean in sink with warm or hot water from backside. Use garden hose for hard to reach areas.
    5. Reinstall filter. Don't overtighten or you will crack it
    6. Replace drawers
    Done!
    Mar 26, 2009 | Dishwashers
    Maytag MDB3100 Soap Dispenser Problem?
    Remove each arm and inspect the small spray holes for plugging. Use a vacuum in the center hole and poke out each plugged hole. Unless your vacuum allows wet pick-up, make sure the arm is dry first. Try using a capsule type of detergent instead of liquid. You might have to tear down the lower spray arm assembly to the deck to clean the large screen which may be plugged with water/food deposits. Use hot water, detergent and white vinegar to clean the screen. Hope this helps!
    Jun 12, 2008 | Maytag MDB3100 Dishwasher
    Open Questions:
    See all Whirlpool GU2400XTPS Built-in Dishwasher Questions
    Whirlpool GU2400XTPS Built-in Dishwasher Logo
    103 people viewed this question
    Top Whirlpool Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
