How to take samsung tv off mute
I don't know if i pressed mute,but its not working.i have tried pressing mute button again and again.still doesn't work.
    Scholar:
  • 195 Answers
Make sure the speakers are not turned off in the menu.
Posted on May 08, 2014
CrazyLarry
  • 173 Answers
SOURCE: Zenith 50" R56W36
maybe on your remote press menu and find converence and use the keys to move the red first over the green then move the blue over the yellow ..by standing back and just using the remote....should end up with white lines. and dont hit that button again once set. a tech should do this quickly and charge you minium.
Posted on Aug 17, 2007
  • 192 Answers
SOURCE: blue screen and shut off by self
You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
Posted on Sep 23, 2007
SOURCE: Samsung LCD TV not receiving PC signal
Check your vga cable. Some cables have only 14 pins, some have all 15. The missing pin is pin 9, in the 15 pin cable it carries 5v from the graphics card to the screen. Without that 5v signal most LCD and Plasma television screens won't recognise a PC input. I had the same problem and only managed to fix it when my girlfriend swapped a cable over for me and as she did so glanced inside and said "it's got a bit missing" The cable that came with your PC most likely only has 14 ins as that is all a monitor screen needs.
You can buy a 15 pin cable at most PC or electronic shops, just check that isdoes have all 15 pins befiore you buy it. The cheap ones are just as good as the expensive ones unless you are buying 20 foot cable. For 6 foot cable the cheap ones are just as good as the expensive ones.
Posted on Sep 20, 2008
  • 346 Answers
SOURCE: Toshiba Regza 32C3000A tv sound
if you press the volume + on the tv and the volume- on the tv and the volume increase and decreases respectively then the remote control mute button is the problem
Posted on Nov 14, 2008
Ajkill
  • 2035 Answers
SOURCE: Need to reset Mistubishi 48 rear projection tv.
Follow the steps below for the initial set-up:
1. Select the "MENU" display by pressing the "MENU" button once.
2. Press the number buttons "2", "2", "7", "0" in sequence to select the "OPTION MENU" display.
3. Press the "ADJUST" button to select "INITIAL."
4. Press "ENTER."
NOTE: At this time channel 3 is automatically selected.
This will reset the the tv ....
Posted on Feb 18, 2009
How can I open the service menu?
Press the helpful button and check link below for various models
First power off your TV using the remote, then press following buttons quickly on your TV remote:
Display (or i+) + 5 + Volume Up + Power
It'll show the hidden service menu on your TV screen.
Once you enter into service menu, you can press Menu (or Options) button again on your remote to switch between various service modes such as Digital, Chassis and VPC.
To navigate between available options press 1 or 4 buttons. To change or modify their values press 3 or 6 buttons.
To save your changes, just press Mute + 0 (or Enter) buttons on the remote.
To restore settings to factory defaults, press 8 + 0 (or Enter) buttons.
PS: For some new models the above mentioned method might not work. You can try following key sequence to access service menu in those new models:
While TV is on, press Left + Right + Mute + Center button + Mute + Menu buttons.
Hidden Secret Service Menu Codes for Sony Samsung LG and Philips TV
TV Service Menus Hidden features you didn know about
Jan 31, 2016 | Televison & Video
I have a samsung dvd player that connects to my samsung flat screen tv. Every now and then someone uses the tv and i don't know how they work it but the info button then doesn't work. if i disconnect
Contact the Samsung service centre. It sounds to be a strange fault with Samsung brand TVs. http://electronicshelponline.blogspot.com/
Inform them the problem you faces with the TV. They will surely provide a solution.
Nov 25, 2014 | Samsung Televison & Video
Volume buttons not working
Either the mute button was pressed. Press the mute button once. If audio does not return, press mute again to return it to its original status. There could had also been a loose audio cables. Make sure loose audio cables are plugged in. Either the speakers are damaged. If so they need to be replaced right away. There could be distorted audios which means the audio cables or damaged and can easily be replaced. Buzzing audio wrong button on the remote was pressed. Press only one of the buttons on the remote one start with CBL,TV,VCR,DVD,and the AUX.
Mar 10, 2014 | Samsung Televison & Video
We have a DVR hooked up to our 1989-99 Mitsubishi TV (floor model) still in amazing working condition. The remote control for that TV never allowed us to put the TV on mute. If the mute botton was...
Well, without knowing the exact model of tv and remote, I can just give my best guess.
Try using the volume up/down on the TV and / or the remote.
On the TV, try pressing both the volume up and down at the same time.
Stick the remote right in the face of the TV (direct in front of the remote sensor) and hit the mute button.
Try tapping the mute button in very short single bursts rather than pressing it for a half second like you would any other button.
If any of those work, please come back and reply with the model of the TV and remote, because someone somewhere probably has the same issue and would love to have it solved!
Feb 24, 2011 | Mitsubishi Televison & Video
I lost my sound on my Samsung LN-T4061F tv. it was plugged into my stero.. was fine.. and now no sound. Not even on the regular tv. HOw do I get the sound to work at least on the regular tv?
hi,
i think ur tv's internal mute function is ON. change it to OFF through the following setup.
1. Press the MENU button to display the menu.
Press the ? or ? buttons to select "Sound", then press the ENTER button.
2. Press the ? or ? buttons to select "Internal Mute", then press the ENTER button.
3. Press the ? or ? buttons to select "OFF", then press the ENTER button.
Press the EXIT button to exit.
ok
Dec 14, 2010 | Samsung Televison & Video
How do I get the code for my samsung TV remote control?
Please check the bellow link related to your issue:-
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?PG_ID=-1&AT_ID=5716&PROD_SUB_ID=0&PROD_ID=41
However these are the Remote Control Codes for different Samsung Models:
With the TV in standby, press the
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
  • With the TV in standby, press the
    {P.STD} {HELP} {SLEEP} {POWER} buttons on the remote.
    or
    {P.STD} {MENU} {SLEEP} {POWER} buttons on the remote.
    {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
To exit, simply Power Off the TV.
Well i tried these codes on my SAMSUNG HITRON 21" CRT TV but did not worked. however at last i tried :
{DISPLAY}{MENU}{MUTE}{POWER}
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Nov 01, 2010 | Samsung TV Remote Control
Same problem as don5625.my moxi box will not control volume mute or power on my olevia lcd hdtv
Is this the style of Moxi remote that you have?
If so try these steps to find your TV
1. Turn on the power to your TV.
2. Press and hold down the MOXI and OK buttons.at the same time until the LED at the top blinks twice.
3. Press the numbers 9910 on the remote and the led should blink twice again.
4. Press the mute button. If the TV mutes then press OK to lock in the code. If the TV does not mute press the up arrow once then press mute and continue to press the up arrow once then press mute until the TV mutes once the TV mutes press the OK button to lock in the code.
*** Note this may take a couple minutes of trying to cycle through the code list to find which one will work with your TV *****
Good Luck...
Jan 05, 2010 | Olevia LT37HVS 37 in. LCD HDTV
I to just purchased a sylvaniia LC370SS9 and cannot get the right code for a charter moxi DVR remote no help from charter and tried all the codes from sylvania and all there other brands
Good Luck...
Nov 06, 2009 | Sylvania LC320SS8 32 in. LCD Television
Installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Locked out, channel or child lock how to re-set
I know one code please try if it helps 1 press mute button once on remote control handset. 2 once again press &HOLD remote hand set mute button. 3 while keeping mute button pressed press menu button on tv set. good luck
Sep 17, 2007 | Toshiba CF36G40 36" TV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
