Question about Dell Inspiron 1525 Laptop
Unexpected I/O error has occurred--Status:Oxc00000e9
I am also experiencing the same problems. I am also running a Dell Inspiron 1525. The hard disk Diagnostic reported many errors with the hard disk drive. I have been unable to boot to a cd or my nic card. The only solution i see from here is to replace the hard drive....Not what I want...but i have no choice.
    Scholar:
  • 124 Answers
If you have error codes from the diagnostics, then your drive is failing or has already failed.
Check with Dell to see if you still have a warranty on it. It is covered, if your warranty is still in effect.
Booting to the CD requires that in the Boot Up (BIOS) that you have selected the CD as a bootable item - and that there is something to boot TO in the drive...
Posted on Jun 14, 2009
  • 147 Answers
Enter into the setup of your laptop and there is a utility to repair the hard disk . try it before purchasing a new one
Posted on Jun 23, 2009
I have dell inspiron 1525, with windows 7, and this message appear whenever trying to login to my pc.. "Windows failed to start, a recent hardware or software change might be the cause. File:...
The hard drive may had a BAD SECTOR ( corrupt section )
try to format with normal mode,NOT quick format.
try using LLFTOOL ( hard disk low level format ) http://hddguru.com
quite bit longer to fix the bad section,but works.
akee.4shared.com
Aug 15, 2011 | Dell Inspiron 1525 Laptop
Error Oxc00000e9 can this be fixed please
Sadly reformatting your hard drive and re-installing youre OS is the only solution. Had the same problem before after the Windows update i think.
Jun 18, 2011 | Dell Inspiron 1525 Laptop
Error code 2000-0142 hard drive 1 self test unsucessful status 79
It appears that your laptop's system board cannot not communicate with your hard disk drive. Either your hard drive is defective or the system board. Usually it's the hard drive.
Feb 07, 2011 | Dell Inspiron 1525 Notebook
I did a diagnostic run and error message 2000-142 Hard drive dst test status 79 came up. what can I do to fix this problem
The dell diagnostic is an inbuilt tool that helps to identify the hardware failures...
This 0142 error occurs if the Hard drive has gone bad.. It is due to a hardware failure in the hard drive.. So toy have to replace it... If you have warranty on the computer you can call dell(18006249896).. If you dont have warranty then call any local computer shop and replace the hard drive
Nov 01, 2010 | Dell Inspiron 1525 Notebook
There is a black screen coming and its written: error code 142 massege error code 2000 strike 0142 massege harddrive 1 strike self test unsucceful .status 79 DELL inspiron 1525
Remove the hard drive on the left side hand edge of the laptop and put it back again making sure that its properly press. This will require you to use a + screw driver. If the same thing occurs, unfortunately, replacing the hard drive will resolve the issue basing on the error code pertains to the hard drive being undetected. Please let me know of the outcome. Thank you and regards.
Aug 28, 2010 | Dell Inspiron 1525 Notebook
Error 2000-0142
Hi there!
The error code you have there means that the Drive Self Test failed. You can try to power down computer, disconnect and reconnect hard drive from the system board. Run the diagnostics , if no error occurs then it's a cable/connector issue, if it failed with the same error, replace you hard drive,
Hope this helps!
May 30, 2010 | Dell Inspiron 1525 Laptop
My dell inspiron 1525 has a memory write / read failure and i tried to reseat the memory and that did not work. Please help me
This could also be a problem with the hard disk. Part of the hard disk is usually used as a virtual memory. If the hard drive is defective, you could experience this kind of failure.
Check your hard disk drive using CHKDSK C: from a command line prompt. Check the outcome of this command. If you find any errors, run the command CHKDSK C: /F to fix the errors. Beware that the second command will prompt you to reboot your computer.
Nov 29, 2009 | Dell Inspiron 1525 Laptop Jet Black
Windows boot manager file: /boot/bcd status: oxcoooooe9 info: an unexpected I/o error has occurred I am experiencing the same problem on a Dell laptop (Inspiron 1525: Windows boot manager - file:...
Try check your hard disk with the other machine. Try running hard disk diagnostic test. If there's a problem with diagnostic test i suspect your hard disk is faulty. If you tried connecting with other machine then same problem, suspected also hard disk faulty. You might need to change it.
May 09, 2009 | Dell Inspiron 1525 Laptop
My dell inspiron 1525 wont start up
The repair occurs when there was an improper shutdown/power failure. Depending upon the size of the hard disk, it could take a few hours (especially large capacity hard disks) as it need to do several passes over the whole drive.
Just let it run until it finishes, you know if it is still running by the flashing disk LED.
Apr 07, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Laptop Logo
6,970 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
